  • July 09, 2025, 03:05:39 PM
Author Topic: My EVO 36  (Read 2264 times)
My EVO 36
« on: September 01, 2008, 08:13:06 AM »
Well last Saturday I made it out to the field to do some mowing and flying.  the Minor's and Rob Hein were there already.  After mowing enough to be able to fly I parked the mower, besides it was starting to make noises, now know bearing has went bad in mower deck.  But, back to the EVO 36.  It is kind of strange looking the way the case is molded.  Had it on my test mount.  Started with Top Flite 9X6 power point.  Fuel is SIG 10% half and half oil.  Had the big muffler on the engine.  Took awhile to get it started and it was winding up(no tach as battery went dead), but, wasn't worried as plenty of smoke was coming out of the muffler.  Let it cool and refilled tank and tried to start.  Dead plug.  Changed plug to a Fox Idle Bar and all it would do was just pop and kick.  Finally Howard Terrell let me use the electric finger.  It started and same type run as needle was opened as far as the limiter would let me.   Another blown plug.  So I went with the SIG #3 plug and it still did not want to hand start.  Howard suggested I remove the muffler and the limiting pin.  Three flips and it was running.  I then opened the needle a good two turns to get a for cycle out of it.  Without the muffler it starts like a champ.  Howard then suggested I put the small venturi in or drill out the venturi that came in the engine and go to an OS Needle Valve assembly  which I think I will do.  More on this as it may go in either the Moon Gieseke Nobler or the Brodak ARC Vector 40.  Still have a lot of work to do in the shop.  DOC Holliday
Offline Balsa Butcher
  • High Desert Flier
Re: My EVO 36
« Reply #1 on: September 01, 2008, 09:03:48 AM »
My Impressions:  So far, no flight time but about 1/2 hour of break in time. Started with 9X6 prop - mistake.  Started right away and went into the stratosphere - rev wise.  Immediate shutdown by me.  Switched to a 10X5 prop-better results.  I like the remote needle valve but the limiter is a pain.  After moving it moving it past the "gate" there is enough adjustment so it is still on - for now anyway. Didn't even try the large venturi.  Went immediately to the smallest.  My suggestion to Horizon is ditch the largest venturi and include an even smaller one.  Evo 36's have lotsa power but could use better fuel economy.
Currently using an "Evolution" 11x5 prop, Power Master 18% lube, 10% nitro,added 3 ounces of synthetic oil (probably unnecessary as Evos run cool, probably because of all that finning).  With the 11x5 prop I get 10,300-10,400 RPM in a fast 4 cycle and real steady.  Pinch the line and get a nice 2 cycle break.  4 ounces of fuel gets a little over 5 minute run but with further running I think that will improve.  Note on the prop:  I have used the Evo 11x5 and 11x6 props on another plane and found them excellent.  Still running the same glow plug.  Engine likes to be primed then reverse bump started.  Seems to work better than "flipping".  No starter necessary.  Tube muffler used.
« Last Edit: September 02, 2008, 07:49:49 AM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
Walter Hicks
Re: My EVO 36
« Reply #2 on: September 01, 2008, 07:02:21 PM »
EVO .36
   I put my EVO in a TF Tutor II. Worked best with the small venturi. I used  several props, APC 10.5x4.5.
Engine ran very well. I got rid of the limiter. Used lots of fuel!!! It may  not be broken in yet. I dont have any 5% nitro
I may be able to get a 6 min  run then. I was using Powermaster 10 %  18 nitro fuel.  I will try some 3 blades and
other fuels in the future. It did fly the Tutor II ok.
Offline dennis lipsett
Re: My EVO 36
« Reply #3 on: September 02, 2008, 02:23:37 PM »
I use an 11/4, medium venturi, P/M 10/18 or Omega whatever is there in the box. Hand start in 4/5 flips, decent 4 break, 4.5 oz will just get the pattern in with 2 laps left.
Forget all the old ways on this one, use R/C fuel, a moderate prop load and go fly.
dennis
Offline Leester
Re: My EVO 36
« Reply #4 on: September 22, 2008, 12:43:14 PM »
I just put mine on the test bench and following the advice here, small venturi, removed limiter, 11/4 power point. With the electric finger I only hit it twice and it ran. Had it at 8600 seemed fine, used some old 10% Omega. It will go in my ARF Nobler as I previously had a Mag 36 and the Evo matches up.
Leester
ama 830538
Offline Leo Mehl
Re: My EVO 36
« Reply #5 on: September 23, 2008, 05:10:08 PM »
Bench ran mine with a 11-5 Zinger and 10% fuel with thw medium venturi and it started after the first flip. I read the instructions and it sait either a 11-5 or 11-6 prop. Later changed the remote needle to the OS carborater needle from the older Os carbs and screwed it into the small venturi and it5 worked great. You have to take some of the end off the needle body so it works right in the venturi but I like this better than the remote. #^ #^ #^ #^ #^ HB~>
Offline Peter Hess
Re: My EVO 36
« Reply #6 on: October 02, 2008, 10:47:20 AM »
I can't add much to the very informative reports about the Evolution 36, but, for what it might be worth, here is what I have so far experienced.
Based on early reports, I immediately switched to the smallest venturi.  I used the stock remote NVA, did nothing to over ride the NV limiter, and used the stock plug. I used the tube muffler and muffler pressure.
I used 5% Omega to which 2% castor and one ounce of Aero 1 were added.  I must say that it felt very strange using pink fuel with so little oil as compared with the Power Master GMA fuel that is used in all my other motors.
For break-in I used a carefully balanced Zinger 10 x 4 prop.
I decided to start the break-in with the two minute heat cycling technique with a couple of brief fuel line pinches to increase the revs.  The first start was a two-flipper and the motor ran smoothly.  The needle valve was adjusted to get a strong four cycle run at 10,400 rpm.  It was apparent from the start that this is a strong motor.
After a total of eight two minute runs the runs were increased to four minutes with several 10 or 15 second two cycle bursts (using the needle valve) during each run.  The motor responded almost instantly to changes in the needle settings and solidly held the needle valve settings.
During the last several runs I turned in the needle valve as quickly as I could to the stop and let it run there just long enough to get a tach reading.  The transition from a solid four cycle to two cycle was almost instant and there was no coughing, sputtering or other complaint.  With the needle on the limiter the motor peaked at 11,500 rpm.
Throughout the break-in I was surprised by how cool it ran.
Based on this beak-in running you might say I am, so far, delighted with this motor.  Although I consider it ready for flying I want to experiment with props before putting it in the air.  I fully expect my delight to continue.  If my experience with my second EVO 36 is the same as with the first I will be one happy camper indeed and will feel indebted to Pete Bergstrom and Horizon.
Peter Hess
Canton, CT
AMA 485070
Offline Leo Mehl
Re: My EVO 36
« Reply #7 on: October 10, 2008, 03:50:12 PM »
I forgot to mention that this engine with a well balanced prop is on of the smoothest engines I have ever ran on the bench. The crank shaft is well balanced and if you take the back plate off you will know why. HB~>
Alan Hahn
Re: My EVO 36
« Reply #8 on: October 12, 2008, 09:44:47 AM »
Leo,
Give us at least a hint as to why (for those who don't have one)!
Offline Leo Mehl
Re: My EVO 36
« Reply #9 on: October 12, 2008, 10:55:38 AM »
Alan, only half of the crank shaft is cut down and the crank pin is set on the half that is cut out. It is real noticeable when you remove the backplate. It sure makes it run smooth this way. I was really impressed with this machining of a factory engine. It's worth a look. HB~>
Offline Leo Mehl
Re: My EVO 36
« Reply #10 on: February 02, 2009, 05:54:29 PM »
I am now using the large venturi with a Super Tigre needle valve assembly thru it. Works good. HB~> HB~>
