  • July 17, 2025, 06:02:54 AM
Author Topic: Mufflers for McCoy Redhead .35 and OS Max-II .15  (Read 3872 times)
« on: January 16, 2014, 11:45:36 PM »
I just got McCoy Redhead .35 and O.S. Max-II .15 engines to go on a couple of old C/L planes I'm refurbishing.  I'm looking for mufflers for them.  I see some custom strap mufflers being made, but at $35 or more for them, they're twice the $20 each I paid for the engines.  At that price, I'm better off buying new engines with included mufflers.  Can anyone point me to a budget way to make mufflers for these engines?
Mark
Re: Mufflers for McCoy Redhead .35 and OS Max-II .15
« Reply #1 on: January 17, 2014, 06:51:56 AM »
I can't speak about the OS but my experience from back when mufflers started to be used was that the McCoys didn't like to be muffled very much.  Back pressure and added heat soon cooked them and they didn't want to run normally.  I'd suggest another engine to muffle.  Perhaps you can pick up an Enya or newer OS on EBay.  I have a few K&B Stallions I'm eventually going to try to muffle.  They may handle it better.
Offline 55chevr
« Reply #2 on: January 17, 2014, 06:55:59 AM »
If you shop around on EBay you can get a buy on a muffler.  Might take awhile to find something that will fit and has a mounting strap for your engines.  You got a bargain on the engines. Because they predate standard mufflers you have an up hill task finding compatible retro fit mufflers.  A better option might be to buy an engine with a muffler as a unit and sell off the engines you have.
Joe Daly
George Hostler
« Reply #3 on: January 17, 2014, 08:07:20 AM »
I just got McCoy Redhead .35 and O.S. Max-II .15 engines to go on a couple of old C/L planes I'm refurbishing.  I'm looking for mufflers for them.  I see some custom strap mufflers being made, but at $35 or more for them, they're twice the $20 each I paid for the engines.  At that price, I'm better off buying new engines with included mufflers.  Can anyone point me to a budget way to make mufflers for these engines? Mark
Mark, regarding the steel fin OS Max-II .15, you may be able to use an Enya .15 muffler. It is like a universal in that it has a separate backing strap with two long screws. If you have a modeler nearby that already has a muffled Enya, might be able to see if his muffler would fit your set up. If it does, then shtterman http://myworld.ebay.com/shtterman?_trksid=p2047675.l2559 on E-Bay has a new one http://www.ebay.com/itm/221334202168 for $16.99 plus $3.90 shipping. You may also find a used one for less than that. An unmodified legacy Tatone Peace Pipe .29-.40 may also work on the .15.
Regarding the McCoy .35, IMHO (in my humble opinion), you'd want a large chambered free flowing muffler to prevent overheating and possible ruin. A legacy Tatone .29-.45 Peace Pipe muffler may work. Recently I checked my .35 RH and the unmodified opening will fit and can be opened up for better flow. Also, I checked mine and an MDS muffler I have would work. I bought it used and I think it is for a .28, but it is large chambered and heavy (3.1 ounces). I've attached a photo of my Testor .40 Series 21 Black Head with a YS muffler. Heavy and large, the muffler runs on it freely without overheating.
These occasionally come up on E-Bay and more or less go for song. I've bought a number for under $15 each shipping included. You have to careful though. One modeler did not show photos of the muffler exhaust entrance on two of his Tatone .29-.45's. When I received them, the opening was drilled/filed out large enough to make them useless except for a select few engines. Also, the sizes can be deceiving. The .09-.19 Peace Pipe has a 3/16" dia. exit hole and is small chambered, suitable for .09-.10 engines. It works fine on my Enya .09-III TV but wouldn't try it on larger. I've included a photo of the .29-.40 Peace Pipe on an Enya .19-VI TV. They use standard ANSI thread #6, #8 screws and straps can be made out of steel steel or brass if missing.
Good luck, and as usual, YMMV (your mileage may vary).
« Reply #4 on: January 17, 2014, 08:26:43 AM »
I used one of the Peace Pipes when they first came out on a Fox .35 Stunt.  Had to let engine warm up good before setting needle.  It was much quieter than the open exhaust.   Made for hard starting and setting needle.  Too bad you didn't save your hard earned cash and get a newer engine that was designed with a muffler.  I know OS engines of .35, .40 and .46 range keep showing up on the bay.  In fact if they haven't sold yet, there is some good bargains here on the Classified section.
Offline ericrule
« Reply #5 on: January 17, 2014, 09:19:28 AM »
I agree with Dave's comments about mufflers on the McCoy .35.
As far as a strap for the OS why not just get some 1/16 x 1/4 brass (from the K&S rack in your local hobby shop)? You can put a 90 degree bend on one end, wrap the strap around the back of the engine to get the curve you need, put a second 90 degree bend on the other side of the strap then cut off the excess. Drill a couple of 1/8" holes throgh the strap to line up with the mounting holes in the OS engine. Run 4-40 socket bolts through the holes and you've got a perfectly usable muffler mounting strap. Very low cost, yet efective. Just a suggestion.
Eric Rule
« Reply #6 on: January 17, 2014, 09:38:37 AM »
Hi Mark,
What the other guys have said about the McCoy Red Heads is true.  They had rather "soft" pistons and any amount of heat build up caused by a muffler will allow them to wear out pretty quick in most all cases.  The piston can be heat treated or switched to the Series 21 piston which uses a Dykes ring.  I do this to the ones I expect to get a large amount of usage like in contests.
Tom Lay used to heat treat the pistons which allowed a more normal life span when used with a muffler.  The Red Heads are about the worst of the old engines for this to happen to.
The OS should be no problem, just find a muffler than can be mounted and has a good amount of volume in the body of the muffler.
Big Bear
George Hostler
« Reply #7 on: January 17, 2014, 10:18:13 AM »
I hear what you all say and you bring up an interesting point on the venerable Testor McCoy Red Head engines. Out where I live, the nearest home to the flying field is a farm house a quarter mile away, next about a mile. A quarter mile oval dirt track is next door. I can fly without mufflers and my restored S-1 Ringmaster .35 RH will fly without it. Otherwise it would be nose heavy. Flying close to the ground, noise doesn't travel as far, too.
I've looked at the muffler issue, because it is possible that I may fly one of these days where it is required. A simpler issue, I'm thinking that I ought to build some CL planes that use muffled engines to begin with.
Since I have several .35 RH's, once I wring out the S-1, will try the larger Tatone .45-.65 Peace Pipe on it. It is large chambered and has a 3/8" dia. exhaust exit with a 1/4" dia. aperture ring just inside that can be drilled out. It weighs 2.3 ounces.
The RH's are really nice running engines and I am very pleased with them. From all and various inputs, I gather that similar to the K&B Sportster Schneurle chrome plated aluminum piston running in an aluminum cylinder series, that anything to cause overheating most certainly will lead to their ruin.
Regarding heat treating, has anyone ever tried chrome plating the piston ala KISS (Krome plated Iron piston running in a Steel Sleeve)?  S?P
« Reply #8 on: January 17, 2014, 10:19:20 AM »
If you feel crafty you can make a fairly simple and very light muffler. I've made these for Red Head McCoys, Super Stunt McCoys, Green Head Torps, Vecos and Foxes.
http://stunthanger.com/smf/index.php?topic=7960.msg67901#msg67901
« Last Edit: January 17, 2014, 07:53:08 PM by Randy Ryan »
Offline richardhfcl
  • AMA 82448
« Reply #9 on: January 17, 2014, 11:55:40 AM »
George,
     One of our Circle Cutter club members, Bud Bodzioch, chrome plated a number of McCoy Red Head pistons.  They
worked quite well in the steel liners, which, as you point out, are fairly soft.
Richard Ferrell
AMA 82448
Offline kenneth cook
« Reply #10 on: January 17, 2014, 02:15:41 PM »
        I've used the Tatone Peace Pipe on the redhead. For one it barely fits and it wants to flip off due to the mating surface of the Peace Pipe not being quite wide enough. I had to lap the exhaust stack flat due to it not being flat.  I had it mounted in a Bi Slob. While the engine did work it didn't last long and I certainly suspect the heat was the culprit. The hole needs to be much much  larger. Ken
« Last Edit: January 17, 2014, 04:15:37 PM by kenneth cook »
Offline 55chevr
« Reply #11 on: January 17, 2014, 05:14:47 PM »
I had a Tatone Peace Pipe on an Enya 35.  It would shake loose in one flight.
Joe Daly
George Hostler
« Reply #12 on: January 18, 2014, 03:49:47 AM »
George, One of our Circle Cutter club members, Bud Bodzioch, chrome plated a number of McCoy Red Head pistons.  They worked quite well in the steel liners, which, as you point out, are fairly soft.
Thanks, Richard, glad to know that someone has done this practically. I imagine the addition of chrome also helped to restore the piston seal in a worn engine, extending its life as well as adding new extended long life to the engine.
George Hostler
« Reply #13 on: January 18, 2014, 03:58:53 AM »
I've got the Tatone .29-.40 Peace Pipe on an Enya .19-VI TV. It has the hole drilled out. There, the chamber seems about right. A number of folk mentioned that these mufflers ruined a good number of engines back in their days. I gather that their chambers were too small and outlets restrictive.
One muffler that I've got that others have told me particularly bad is the Tatone Calument muffler. I've got the EM-4 for .09-.19, and it has a very small chamber. I used a Dremel-like tool to remove the internal baffles and still my Enya .19 and McCoy .19 RH ran hot. I drilled about 8 holes in it to convert to a "tongue" muffler, but all I did was basically make it useless as now it did not muffle well. I'll probably patch the holes with JB Weld and test it on a .09 engine, which in that case might work. Muffler isn't that light, either.
