  • June 20, 2025, 06:29:55 AM
Author Topic: Hi zoot crank ID  (Read 3490 times)
Online Gordon Tarbell
Hi zoot crank ID
« on: June 12, 2017, 11:14:42 AM »
How to ID fox 35 hi zoot crank from stock? I have a fox 35 in possession that supposed to have all the bells and whistles . How do I know the crank is the one from Randy? The cyl head is different also.
Gordon Tarbell AMA 15019
Re: Hi zoot crank ID
« Reply #1 on: June 12, 2017, 12:42:46 PM »
The crank counterweight  it NOT round, many many other ways but this is the biggest thing you can see
Offline Gerald Arana
« Reply #2 on: June 12, 2017, 05:35:04 PM »
What do you mean by "not round"?
Thank you, Jerry
Offline Mike Bufkin
« Reply #4 on: June 13, 2017, 12:18:25 PM »
Will anyone make these again ?
lots of Fox 35's floating around.
Offline Bob Matiska
« Reply #5 on: June 13, 2017, 05:22:28 PM »
Well, since MECOA has apparently bought out Fox engines, maybe they will. Of course, the Hi Zoot crank wasn't engineered or made by Fox, but by others, so that introduces a new factor into the equation. I wonder how many pre-orders MECOA would need to make it worthwhile for them to produce it?
Bob in NEPA
AMA 56267
Offline Brian Gardner
« Reply #6 on: June 22, 2017, 06:29:41 AM »
Possibly.
Offline Mike Bufkin
« Reply #7 on: June 22, 2017, 01:33:53 PM »
Hope so Brian,
I could use several of them.
« Reply #8 on: June 22, 2017, 03:20:43 PM »
I have been checking into making them again  But I would need  order of 100  to do them, or  close to that
I  also would look at making  CNC backplates  and  Smith Hemi heads
Offline Al Ferraro
« Reply #9 on: June 24, 2017, 05:55:07 PM »
The High Zoot crank and the Gardner piston & liner helped power my Fox 35 Stunt engine to a new speed record at the 2017 Brodak contest. 112.5mph from a dead stop start, 118mph actual in air speed on Powermaster GMA 10% nitro stunt fuel.The Zoot crank had to be spinning close to 20,000 rpm in the air and was smooth as silk. The third place entry also had a Zoot crank too. If you didn't go to Brodak you missed a great show.
Al
