  • June 17, 2025, 06:15:24 AM
Author Topic: What fuel for a Fox 40?  (Read 1038 times)
Offline Ronald Eshleman
« on: April 20, 2015, 01:11:58 PM »
What fuel mix should I use in a Fox 40 I just purchased on Ebay?
Offline Jim Carter
Re: What fuel for a Fox 40?
« Reply #1 on: April 20, 2015, 01:27:57 PM »
I know there are a lot of guys who will disagree but I have had a great deal of success using Brodaks 10/23 in my Fox 40.  I bought it new from Fox about four years ago and mounted it in my scratch built Big Tiger, a Claus Miklas design and I have absolutely no regrets.  It's the only plane I've ever had it in and the performance has been wonderful.  When I first ran it I was using the Brodak 10/29 for probably the first 36 flights or so then I changed to use the 10/23 because I wanted to reduce the oil residue on the plane and cooked on the head.  Again, I've been very pleased with the Brodak fuel.
Jim Carter
Offline Ron Cribbs
« Reply #2 on: April 20, 2015, 03:22:02 PM »
What type Fox .40? Not that it really matters as I would probably suggest the same for older or late model.
Powermaster GMA 10/22 or 5/22.
Works beautifully.
