or you could just buy Viton, Hi Temp O-Rings ,and use them , That is the same type that I have supplied with my RE mufflers for many years now.
The ones I use are black and harder than the typical O-Rings, the orange-red silicone O-Rings also have worked pretty well in many engines and take heat pretty well.
Remember nothing is going to last forever, and the closer to the engine, the shorter their lifespan will be
