  • June 22, 2025, 04:20:54 AM
Author Topic: What is the thread size for O.S.engines?  (Read 2151 times)
Offline frank mccune
« on: May 27, 2015, 05:32:05 AM »
     Hello:
     I would like to replace the head screws in my older O,S. 35S and .40S engines with SHCS.  Does anybody know the tread sizes and lengths of these screws?
        Tia,
        Frank
Re: What is the thread size for O.S.engines?
« Reply #1 on: May 27, 2015, 08:38:03 PM »
Well...the closest size that you can buy or order is 5-40 thread. No idea about the lengths. Most or all of the engine tuners put 5-40s in the OS .35S, as well as ST G.21 .46's and .60bb's. The OEM thread was 3m x .6 pitch, which seems to have been changed to .5 pitch. This subject is occasionally brought up, and a search should turn it up.   D>K  Steve
« Last Edit: May 27, 2015, 11:18:13 PM by Steve Helmick »
« Reply #2 on: May 27, 2015, 09:11:24 PM »
The only place I know you can get bolt assortment for the OS 30 - 35 S   is Micro Fastners , the have the  6 pitch  3mm  screws  that OS used
« Reply #3 on: May 28, 2015, 05:01:28 AM »
   Hi:
    A big thanks to all of you who replied!
        Stay well my friends,
        Frank
« Reply #4 on: May 28, 2015, 07:55:17 AM »
The 5-40s will generally thread right into the older SuperTigres, but the Max-S thread seems finer to me.  I didn't push it, but the 5-40s wouldn't thread in any of my OS engines.
« Reply #5 on: May 29, 2015, 06:59:00 AM »
The 4-40 will  fit the 35S  fairly well, the 5-40 is too large, many people just use the 4-40 bolts
« Reply #6 on: June 10, 2015, 09:31:19 PM »
You can screw 4-40 screws into m3x6 holes?
I guess you wouldn't want to unscrew and rescrew it if you didn't have to.
