  • June 19, 2025, 12:45:07 PM
Author Topic: Mounting bolt size ?  (Read 3270 times)
Offline Rob Killick
« on: February 11, 2010, 03:59:30 PM »
Hi ,
What is the best bolt size for mounting a modern .60 size engine (PA , or Ro-Jett) ?
4-40 , or 6-32 ?
Thanks ,
Rob K.
Rob Killick , MAAC 33300
Offline Bill Gruby
Re: Mounting bolt size ?
« Reply #1 on: February 11, 2010, 05:22:44 PM »
 Of those two choices go with the 6-32. The 4-40 is too small to hold that kind of power. If they will fit I would even go to 8-32, but I am not familiar with the hole size on those engines. My 2 cents worth.
  "Billy G"   H^^
Bill Gruby
AMA 94433
MECA 5393-10
Online RandySmith
« Reply #2 on: February 11, 2010, 06:16:37 PM »
Hi ,
4-40 , or 6-32 ?
Thanks ,
Rob K.
Hi Rob
Most people use 4-40 or 6-32, I use 4-40 on all my ships and have used them with motors up to 88 size.
One grade 8 4-40 will secure 100 pounds and I have never had a good alloy  4-40 break,
The biggest prolem I have seen is the blind nuts...NEVER use the cheap thin ones, I use the DuBro T Nuts, you can  see how much thicker they are at the flange.
B roken  T nuts is the only problem I have ever had with mounting motors with 4-40s
Always make sure your holes are straight and indexed correctly, use good mounting wood and use some type of motor pad, wether that is steel  alum.  or linen phenolic.
Online Paul Smith
« Reply #3 on: February 11, 2010, 06:20:44 PM »
I've found that the 3mm is a good compromise between the weak 4/40 and the overly heavy 6/32.  They are readily available in the proper sizes, including blind nuts.  I've used these on my last three 40-to-51 size projects.  They are standard equipment on Viko F2D's.
I guess it's something of a weakening of usual stance to operate in the French system of measure.  Maybe it's time to bury the hatchet.
« Last Edit: February 12, 2010, 03:42:54 AM by Paul Smith »
Offline dennis lipsett
« Reply #4 on: February 11, 2010, 06:45:04 PM »
It is correct to use the smallest bolt that will do the job, Usually 4-40. Larger or really high rockwell grade bolts can guarantee you a broken case in the event of a crash if hit on hard surfaces. Of course the rest of the engine might be reduced to junk also.I use Great Plane bolts not because they are good but because they will shear or give way in the event of a mishap. The only cavet is exactly like Randy said never use cheap T bolts or blind nuts as your just asking for misery when the threads or the prongs give way.
In my R/C days I usually held 60 sized wings on my models with 8/32 nylon bolts when the standard was 1/4/ 20 Simply because in the event of a serious mishap they would sheer off and cause no damage to the structures.
Dennis
Offline Rob Killick
« Reply #5 on: February 11, 2010, 07:23:50 PM »
Gentlemen ,
Thanks for the information ...
I will most likely use a grade five , 4-40 allen head capscrew (readily accessable from my employer).
I'd prefer to go to a stainless (due to a lower shear strength) , but I guess "free" is better than none at all y1
Thanks again ,
Rob K.
Online Paul Smith
« Reply #6 on: February 12, 2010, 03:47:35 AM »
In the 4/40 size, the Allen head capscrews are not so much of a weak point.  It's the blind nust or threaded plates that cause the failures.  In a profile setup with 4/40 bolts running through to Nylocks, it's just fine.  But in a high value plane where you need to dig out the bad nut, a 3mm is a better bet.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #7 on: February 12, 2010, 09:35:38 AM »
Completely agree with Randy, 4-40 cap head screws are plenty strong for anything we can hold onto and you can buy Dubro blind nuts in an economy pack. The thin blind nuts I bought from Small Parts are only used for accessories and hatches.
« Reply #8 on: February 12, 2010, 11:37:50 AM »
    I still use 4-40s and clearly they are adequate as far as strength goes. I have also used a lot of the stamped - Carl Goldberg and other brands -  blind nuts with no issues.  Although after Curt Contrata mentioned his issue I switched to DuBro, and might go back to nut plates if I ever build another airplane.
     But we did find a good reason to use 6-32s - they are much easier to extract with a screw extractor if they break off.
Offline Martin Quartim
    • StuntHobby
« Reply #9 on: February 13, 2010, 12:07:32 PM »
I also use 4-40 with my 70 4s engines and I wouldn't use a 6-32 because in case of a crash it could harm the engine more then if using a 4-40.
Now, I have seen some Saito 72 coming out of a plane nose because the guy was a sloppy modeler:
 1 - did not care to balanced the prop
 2 - did not use washers and lock washer
 3 - did not use an engine pad
Martin
Offline Allan Perret
  • Proverbs
« Reply #10 on: February 14, 2010, 08:01:01 AM »
I use 4-40's up to 40 size engine.  Over 40 engines I go to 6-32's.  I agree that a good quality 4-40 bolt is strong enough, but the 6-32 blind nuts have a larger diameter flange which minimizes the crushing of the wood mount.
Allan Perret
AMA 302406
Slidell, Louisiana
  • Proverbs
« Reply #11 on: February 14, 2010, 08:04:57 AM »
I wasnt aware of this issue.  How do the thin ones fail ?  Does the threaded barrel part shear away from the flange ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline don Burke
« Reply #12 on: February 14, 2010, 09:50:44 AM »
The thin ones will gradually sink into the bearer, the flange stretches and bends.
don Burke AMA 843
Menifee, CA
Offline Bob Reeves
« Reply #13 on: February 14, 2010, 05:16:20 PM »
And will break, if you do what I do and relieve the underside of the mount just deep enough for the nut once it breaks you have no way to get the screw out without cutting the head off.
Offline Steve Scott
« Reply #14 on: February 14, 2010, 08:06:10 PM »
I'm considering going to a 3mm bolt size.  I find the 4-40's are too small for the bore in the engine mounting flange.  If there is slop there, it is hard to get an accurate engine thrust setting.  I build mostly profiles and have had some unpleasant experience with some unintended up/down thrust issues.
I figure most engines are drilled for metric so why not use metric mounting hardware?
« Reply #15 on: February 14, 2010, 08:20:00 PM »
I don't think I've seen 3mm x .5 T-nuts or brass inserts. However, our LHS (Ultimate) has reduced their stocks of hardware quite a lot in the last couple of years. It's pretty sad to see.  :'( Steve
« Reply #16 on: February 14, 2010, 10:55:33 PM »
I've been using 6-40 screws to mount my .65
  • Proverbs
« Reply #17 on: February 15, 2010, 07:22:08 AM »
Do you use blind nuts or brass inserts ?   I wasnt aware they are available in 6-40 ..  What made you choose 6-40 vs 6-32 ??
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #18 on: February 15, 2010, 11:20:19 PM »
Allen,
I got the screws from either Micro Fasteners or Small Parts, don't remember which at the moment. I bought a box of a hundred for something like 10 bucks. I also ordered blind nuts to go with them, but truth is, I don't use them much. All my engines are mounted in  aluminium blocks so I had to pick up a 6-40 tap, but that's it. I chose 6-40 over 6-32 because the thread is obviously finer and it put more threads in the tapped hole. Makes it easier to snug up the bolt.
