  • June 14, 2025, 10:07:52 AM
Author Topic: tight fox 15 CL Schneurle  (Read 3141 times)
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« on: September 10, 2023, 09:06:48 AM »
I have 2 Fox 16 engines.  I was given some combat planes drilled for foxes.  Both engines are swap meet finds one I think was nearly new in the box
Engine 1 starts from hand flip, runs for 15 seconds, and stops cold seized.  The motor has got very tight.  Since this one had a lot of tar-like oil, I crock-potted it and took it apart.  One of the circle clips was destroyed and stuck in the intake port.  A little scoring but not bad at all.  It ought to run once cleaned out.
The Scoring is not bad, but the piston is very tight above the ports.  Hand flipping seems like a bad idea
Engine 2.  Very clean inside,  Stated on hand flip, while setting NVA it stopped sticking tight as well.  Fearing the worst, I pulled it apart.  It is very clean inside, both pin clips are in place and no scoring but the piston is very tight above the ports.
I am tempted to lap the bores and try again.  But after running a few seconds the both got a lot tighter.  Hand-flipping seems like a bad idea.
Any idea what is happening?  They will be sport engines on old-school combat planes so they just need to start and run smoothly/
Dave Siegler
NE9N extra class
AMA 720731
Offline kenneth cook
Re: tight fox 15 CL Schneurle
« Reply #1 on: September 10, 2023, 06:52:39 PM »
            Dave, I assume this is the Fox .15 BB since you mentioned circlips. I really like these engines. Fox instructions suggest not to lap the pistons in these engines. I've done this however when mine were new. Make certain the rod is traveling freely on the wrist pin from one side to the other. These engines tend to really varnish up on the wrist pin. This can not only offer a tight feel, it makes the wrist pin turn which can also disengage the circlips.
                             Fox instructions for the .15 suggest not to lap the piston in any way. I had to on mine because it was tight like your mentioning. I didn't want to wipe out the rod so I gave it a bit of a polishing using the piston itself and Brasso. I then took it all apart and gave it a hot soapy water bath with a bristle brush.
          Hopefully, someone didn't use the incorrect screws if they were using the muffler that came with the engine. The holes for the muffler are through holes with the cylinder directly behind them. Using a screw too long could hit the liner distorting it.
« Reply #2 on: September 10, 2023, 11:37:01 PM »
   No manufacturer ever recommended, or will be likely to recommend, "lapping" an engine by the end user. Having to do that is a manufacturing defect. Unfortunately, you can't get it replaced any more.
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #3 on: September 11, 2023, 05:07:16 AM »
Hello
Here is a useful article about lapping your engine . The Parra lapping tools are for pistons 12.5 to 16mm so should cover many 2.5cc engines besides Parra engines.
http://www.control-line.eu/lapping-tool.html
Regards Gerald
« Reply #4 on: September 11, 2023, 05:16:23 AM »
I have run a number of Fox 15 BB's on models and my son Otto still uses a couple on combat wings but they are a bit more 'sensitive' compared to modern engines like the Fora 15's or even a OS LA 15's and do not like mufflers (which some sites require) or suction feed so much. We have found the Fox 19BB or 25BB to be a much better engine for slow combat along with the OS/Magnum FP/GP 25 but the Fox 15 will do but has to work harder.
Regards Gerald
  • sport flier
« Reply #5 on: September 11, 2023, 05:30:59 AM »
No,  the cases do not have ball bearings.  Fox made bushed versions as well as BB versions.Bot  engines were all oridional
Dave Siegler
NE9N extra class
AMA 720731
« Reply #6 on: September 11, 2023, 08:10:49 AM »
Sounds like the problem is with the bore or the case. Does it get better when you loosen the head bolts?
« Reply #7 on: September 11, 2023, 06:11:09 PM »
Never had one, or even held one, but aren't these ABC engines? General rule is to bump start ABC engines by back-flipping. When it's right, it'll take off running forward. I'd be inclined to run maybe 4-6 oz of fuel through it the first time it starts, just for being so annoying. I do hate bench running engines.
IF they are ABC, I would apply a heat gun to the cylinder fins and head to get the cylinder to expand some, before starting. That means you'd need 110v here, or 220v in some other places, which isn't always handy. After a run or two, they should loosen up enough to be more civil. Typically, ABC engines suggest all or mostly synthetic oil to prevent varnishing, but since these are sleeve bearing, I'd think you'd want some castor in the fuel. Not sure how much.  D>K  Steve
  • sport flier
« Reply #8 on: September 11, 2023, 06:54:09 PM »
it's just as tight when the liner is out of the case,
I will try the heat gun trick.  I have done that on Novel's in the past.
it's not ABC it's a steel Cylinder and piston
Dave Siegler
NE9N extra class
AMA 720731
« Reply #9 on: September 12, 2023, 10:07:49 PM »
Hello Tight with the liner out and steel liner and piston  , I think some hand lapping is in order...
They only get tighter when hot and a really tight fit will only wear out the rod if you try running it in that way, in fact sometimes the rod is shot before you get a nice fit on the L/P . Some Fox engines especially the cheaper sports models had bad fits weather too loose or too tight. Their best engines like the ABC Deluxe 40 were usually really nice fitting.
Regards Gerald
« Reply #10 on: September 12, 2023, 10:08:23 PM »
Regards Gerald
« Reply #11 on: September 13, 2023, 11:33:29 AM »
If the mounts are drilled for the Fox, then other 15's will fit like cox conquest, nelson, rossi. If you want to pay the freight, I can properly blueprint your engines.
MM 8)
