  • June 19, 2025, 09:43:24 PM
Author Topic: Motor Mount - wood grain direction  (Read 1045 times)
« on: August 26, 2015, 01:08:06 PM »
Guys,
Has anyone noticed a difference in vibration when running the motor mount wood grain vertical or horizontal? I never gave it much thought and just used the direction that fit the nose shape (sometimes the slight warp was just the curve I needed to shape the nose). Seems that running it vertical (when looking at the end) would have slightly more resistance to up and down movement. Any thoughts?
Best,     DennisT
Offline Lauri Malila
Re: Motor Mount - wood grain direction
« Reply #1 on: August 26, 2015, 01:26:17 PM »
Dennis,
I guess that with "vertical" you don't mean vertical as in good shear webs? Sounds to me like quarter cut. That is what I prefer, as bearers cut like that tend to be more straight, and their compression resistance is slightly better.
But for me the compression resistance is not a big issue, I use good hard al pads under engine and dural blind nuts that go all the way through the bearer.
L
