  • June 19, 2025, 12:36:29 AM
Author Topic: Wasp 061  (Read 2039 times)
Offline RK
Wasp 061
« on: August 13, 2015, 09:29:25 PM »
I am looking for someone to make a Venturi for my RC Wasp 061. Any help is appreciated !
Thanks, RK Flyer
If you come to a fork in the road,,,,Take it!
Offline Bill Adair
  • AMA 182626
Re: Wasp 061
« Reply #1 on: August 13, 2015, 11:16:06 PM »
RK,
Any respectable machinist should be able to turn a collar to fit the Cox Tee Dee .049 venturi. It should be threaded inside for the Cox venturi, and a snug fit in the Wasp carb opening. Simply JB Weld into the Wasp carb opening.
Mine works perfectly, and has been run a half dozen times or more. Parts must be cleaned with a good solvent (Acetone) before using the JB Weld.
The Tee Dee venturi is available from Cox International in Canada, and is threaded the same (1/4-32") as a standard glow plug.
Offline RK
Re: Wasp 061
« Reply #2 on: August 14, 2015, 11:29:37 AM »
Thanks Bill, That's a great idea, I"ll check with Scott Riese in Portland! He just made a venturi for my Fox 40!
RK Flyer
Offline Bill Adair
  • AMA 182626
Re: Wasp 061
« Reply #3 on: August 14, 2015, 03:57:19 PM »
RK Flyer
Scott and I fly at the same club field in Portland. Say hello for me.
Offline Dave Gardner
  • AMA 717
Re: Wasp 061
« Reply #4 on: August 24, 2015, 06:17:43 PM »
At Larry Renger's suggestion, I'm having some adapters made to use the TD 049/051 venturi, using a fine thread NVA.  I've ordered a couple of venturis from Cox International.....one in anodized red!
I have a simple drawing for the adapter, in .pdf, presumably attached!  In any case, the o.d. of the adapter is .275" to fit the 7mm bore in the Wasp.  The 1/4-32 thread takes a #3 drill (.213) for the pilot hole.  A small shallow flange on the adapter is probably beneficial for location...maybe .020-.030 thick
The overall depth of the adapter is .200.  This is a little piece....don't lose it!
If anyone wants to use the drawing (AutoCad derived, converted to .pdf.), please feel free to use it!
Dave G.
Dave G.
Offline Bill Adair
  • AMA 182626
Re: Wasp 061
« Reply #5 on: August 24, 2015, 07:12:03 PM »
Hi Dave,
Nice!
Mine have no flange, but yours should be more durable with that extra surface area for the adhesive.
Put me down for one or two please, and let me know the price.
Offline Phil Krankowski
Re: Wasp 061
« Reply #6 on: August 25, 2015, 09:01:17 AM »
I could use 2 of those too
Phil
Offline Howard.Y
Re: Wasp 061
« Reply #7 on: August 26, 2015, 08:12:43 PM »
How much clearance should there be between crankshaft and case on an AP Wasp .061?
