Engine basics => Engine set up tips => Topic started by: Kim Mortimore on April 21, 2008, 03:09:45 PM
Randy,
You mentioned "heat cycling" during break-in. Do you agree with the short runs and cool-off method of break-in, or do you recommend running full tanks?
Kim Mortimore
Randy,
Kim Mortimore
HI Kim
This will vary some but using short runs of 2 to 6 ounces per run is best, use only a few ounces for the first several runs, then use more fuel as the motor is coming in. For very stable motors like the PAs you can use 4 to 6 ounces each run, be sure to follow the instructions for each type of engine, There are differant break in procedures for AAC and Lapped cast iron or ringed setups.
The cool downs are very important, they let everything "normalize" and the metals get back to the sizes they all are when cool. this can be a problem with pinch fit ABC or AAC , If you try to rush things the piston is the last to cool down, this makes for a very tight fit some times, and engines that kick back and are hard to start.
Then on the other side I have had Steel-iron piston\sleeve set ups where the piston would grow so much that the engine would lock up if not ran very rich after it got up to tempurature.
If you have any specific questions about one type of engine breakin I will be glad to address that
Very informative answer. Thanks, Randy.
Kim
