  • June 20, 2025, 10:20:18 PM
Author Topic: More castor  (Read 3351 times)
Offline Rick Bollinger
  • AMA 931589
More castor
« on: June 08, 2015, 08:46:38 PM »
I am running my first LA 46. It is on a Brodak p40 64 ft lines. I have been through all the engine set up threads. Tried venturies from .257-.281 Stock nva and st nva. 11x4 up to 12.25x3.75 . OS #8 plug and 1.5 v fox long rc miracle. Sig 10-10-10. 4oz brodak standard wedge. Running in a solid 2 the problem is it runs away about 1/2 way through. Does not matter if running pressure or not. My last set-up, No pressure, .057 os ventury, st nva, stock 3030 muffler, 12.25x3.75 apc, miracle plug. Set just below peak. Still runs away. Changed fuel to some that I added an extra 5% castor to and what a difference! Has my problem been lack of castor the whole time? Now at total content of 25% of which 15% castor. 5 plus mins on 2.5 oz, 64ft center to center about 5.1 seconds. I am getting close.
Rick Bollinger
AMA 931589
Offline Akihiro Danjo
Re: More castor
« Reply #1 on: June 08, 2015, 10:43:49 PM »
Your .257 venturi with ST nva is toooo small. 10/10/10 should be good for LAs. You may need a larger tank.
Aki
Offline Bill Johnson
Re: More castor
« Reply #2 on: June 09, 2015, 04:51:04 AM »
That might be the problem, Rick. I'm running mine so that when the plane's held vertical, it's just still rich of peak. Back in the horizontal position, it's much richer (still 2-stroke) and RPM drops a couple hundred.
Mine's a factory C/L engine so it's a 7mm venturi, OS NVA, GMA 10-22, APC 11.5 X 4 or 12.25 X 3.75.
« Last Edit: June 12, 2015, 02:56:19 PM by Bill Johnson »
Best Regards,
AMA 350715
Offline Brian Hampton
Re: More castor
« Reply #3 on: June 09, 2015, 11:06:20 AM »
I had a similar problem with an ST G51 that would break from a 4 stroke to a screaming 2 stroke with even a quite small attitude change and would take about 2 level laps to settle back down to a 4 stroke again. Without going into all the boring details of things I changed over about a month, a fortuitious switch from 20% oil to 25% instantly turned it into an exceptional engine. The problem was overheating due to lack of oil flow as it was extremely economical, a little less than 3 ounces for 6 minutes.
  • AMA 931589
Re: More castor
« Reply #4 on: June 09, 2015, 07:40:43 PM »
The small venture I don't believe is hurting me. I have plenty of power and speed. I have not tried fattening up the needle since I added more oil so I may be able to do that now. I do like the 5+ minutes on 2 1/2 of fuel should be over 8 minutes on four oz. I hope the weather cooperates this weekend I would really like to get this worked out.
Rick Bollinger
AMA 931589
Re: More castor
« Reply #5 on: June 09, 2015, 09:29:17 PM »
   I wouldn't be too proud of the fuel economy. Fuel consumption does two things, makes power and provides cooling. If you ain't burning fuel, you ain't doing either. My ST.51s used close to four ounces for the pattern, a bit more in cooler weather, I don't have much experience with the LA.46 but would think something in the four ounce range for the pattern would be in the ball park.
Re: More castor
« Reply #6 on: June 10, 2015, 12:18:04 AM »
Yup, burn more fuel! Many use 4.5+ oz in .46 LA's at normal altitudes. Adding more oil will also require more fuel load, as it happens. The engine needs to be rich enough to not go lean in the overheads at the end of the run, and I suspect you're launching too lean. Using a tachometer? You should. I would wonder how much running time your engine has? Maybe not enough? Most seem to run well from #1, but fuel load still needs to be decreased after 30-40 flights. Where's yours fit in this realm? Or is it one of those rare ones that needs more running?
Remember that the muffler outlet has a similar effect to a venturi change. See Randy's pinned articles at the top of the Engine Forum. Either bigger venturi or bigger muffler outlet will improve the pumping efficiency. Have you put a rubber ducky on the muffler? Big or small one? More prop load burns more fuel but increases heat, too. Another thought...you're running a fuel filter between tank and NV? A big one? I'm not a fan of those tiny ones...too much chance for them to clog after very few flights to suit me.  D>K Steve
  • AMA 931589
Re: More castor
« Reply #7 on: June 10, 2015, 03:39:47 PM »
I am running a crap trap fuel filter. and the stock muffler. Rubber ducky? Do you mean the dubro rubber exhaust deflector? If so no. I am flying the beginner pattern so I do not need the full tank. That is why I was only running 2 1/2 oz. I do not think that I am over lean but I do not have a reliable tach. Could I go richer? yes But I have not had the chance to try it yet to see if it runs away. Since I am running more oil it may stay consistant. I would like to get it in a rich two just off of a four. If it does I may need to go to a larger venture to get the rpm back up.
Rick Bollinger
AMA 931589
  • AMA 931589
Re: More castor
« Reply #8 on: June 10, 2015, 03:44:01 PM »
And to date I only have about 1 hour on this engine.
Rick Bollinger
AMA 931589
Offline David Felinczak
  • Always Remember
Re: More castor
« Reply #9 on: June 12, 2015, 12:53:12 PM »
1. OS LAS / MAX etc. do not like synthetic /castor mix. All castor good(no overheating).
    Mfg. recommends at least 22% castor/gal.
2. I have 2 Randy Smith G51 and a G34 ringed engines. I run Brodak 5% and/or 10% nitro
    with 11.5% synthetic/11.5% castor and I add 2-3% additional castor to a gallon of fuel per Randy's   recommendation and both engines run a great 4-2-4 break and are still like new.
    The G51 powers my profile Pathfinder MK II and the G34 is on my profile Cardinal.
     Each model has power to spare!!!.
David Felinczak
865337
Re: More castor
« Reply #10 on: June 12, 2015, 04:41:08 PM »
Ah, knowing it's the Beginner's Pattern makes the fuel load sound a lot more reasonable. But I'd go with the stock venturi and use a layer or two of pantyhose mesh over it to effectively reduce the venturi size...and keep "the stuff" out. That's another reason to use muffler pressure...keeps the micro bugs and micro seeds out of the fuel tank and thus, filter. Plus, it prevents rich/lean when going up/downwind. Yes, there are other fixes for this, but muffler pressure isn't a bad thing.
Try some different props. The 11.5 x 4 APC works well for me, and locally, Tim and Tom use the 11 x 4.5 Thunder Tiger Cyclone. I still say to change the tank to uniflow, add muffler pressure, and launch richer. If it sags overhead, it's clearly too lean. Try doing 2 OH8's instead of the WO and see if it goes lean. I'd suggest getting a tachometer (Hanger 9 Mini-Tach, $28) and use it to set the rpm before every flight...and I mean, EVERY flight.
Have you read the "sticky" topics at the top of this engine forum about OS .46LA setups? Randy Smith's articles? Some good stuff in that lot.  y1 Steve
Re: More castor
« Reply #11 on: June 13, 2015, 06:09:24 PM »
#1...I ran the one .46LA that I've flown on 10-29GMA and had no problems with it for the first gallon. This was a very early production .46LA, and they were known to have thin nickel plating on the cylinders. After that gallon, I changed to 10-22 GMA, which is 11% castor, 11% synthetic. I didn't see a difference, other than the reduced snot on the model after each flight. I may have run it on 10-18 Wildcat Premium at VSC '09, but I wouldn't swear to it. I did have fuel mileage problems with that airplane, even at Tucson's altitude, and dropped to a .272" venturi/.157" spraybar (I should have added some Coleman Lantern Fuel to whatever glow fuel I ran). Once they're broken-in, many claim that Wildcat Premium 10-18 is better than 10-22. I'm not saying it is, but I'd try it, once the engine's fuel consumption has stabilized...indicating that it's run-in ok.
#2...Different engines, doesn't apply at all, sorry.  H^^ Steve
  • AMA 931589
Re: More castor
« Reply #12 on: June 14, 2015, 06:54:35 PM »
I ran it this weekend at Polk City and it did pretty well. I launch around 8600 rpm with the .257 ven. and super tigre nva. It goes over lean around 9250rpm. This is with the 12.25x3.75 apc. plenty of power and plenty fast. Now that I have a little time before Muncie I will try the middle venture. Also the 11.5x4 apc.
Rick Bollinger
AMA 931589
