  • June 17, 2025, 06:54:41 AM
Author Topic: Did I wreck my OS40FP?  (Read 2435 times)
Offline Darryl W
« on: February 15, 2021, 12:38:22 PM »
Back in August last year it was a warm evening, maybe 80 degrees or so, I started my OS40FP-S and set the needle for 9,510 RPM with a Top Flight 11-6 wood prop and Omega 10/22 fuel. It ran fine as usual until a few minutes into the flight when it very suddenly bogged and sputtered around the circle so slow that I could hardly keep the plane in the air (a Mathis Stuka profile). This had never happened before.
Next day I flew it again, with a new OS#6 A3 plug and different fuel from a newly opened jug. Also replaced the fuel tubing, tightened the klunk tank stopper, and checked backplate, muffler and engine mount screws. It then started easily and ran fine except I could not get the RPM higher than 8,800 RPM! And subsequent runs have been the same. Anything above that it goes lean before it hits 9,000. It also seems to make a crackling sound which it never did before. This engine has only 77 flights on it, I bought it NIB and broke it in very carefully (at least I thought so). It had always been a good consistent runner.
What is going on with this engine??? Did I wreck the piston/sleeve fit by setting it too lean on a hot day?  HB~>  What else could be wrong?
Obviously I am not an expert on engines so I am relying on you guys for a diagnosis, any thoughts or advice are appreciated, as always.
Darryl Wurtz
Re: Did I wreck my OS40FP?
« Reply #1 on: February 15, 2021, 01:20:34 PM »
   Probably not, but you are definitely running too much pitch. You may have just over heated the engine and varnished things up. If it flips through and has what seems to be it's normal compression, you should be safe. Put the engine in a test stand, and put on a 9 inch prop and you can try the fuel you have been using since it's about a half and half mixture of oil. Start the engine and slowly needle the engine up until it gets to the peak 2 stroke and tach it and see what you get. Run it this way for a few minutes and let it cool, then repeat. Try an 11-4 prop of some kind on the next run and see what happens.  It should get into the high 9000 to over 10,000 RPM range with an 11-4. Your take off RPM will probably be in the 9000 to 10,000 range depending on the size and weight of the airplane. Play with the needle setting until you get your lap times and tension that you want. An 11-6 is way too much pitch and over loads the engine. Much has been written in the forums about props for FP and LA .40 and .46 engines. Do a search and check these out. The APC 11-4, 11.5-4, Thunder Tiger 11.5 -4 and some others are all available. You can't run the modern engines like a Fox .35 . I rarely run a 6 inch pitch on a Fox .35 even  unless it's a heavier, largish model.
Offline Darryl W
« Reply #2 on: February 15, 2021, 02:13:47 PM »
Hey Dan, thanks for those insights and yes I forgot to mention that the compression still seems to be normal as far as I can tell. The varnish thing had not occurred to me but that makes sense, and I do have the APC props you mentioned on hand so I will definitely give those a try. Bench run won't be for another month or two though, we are in the dead of winter here and I won't even mention how cold it is.
BTW off-topic, but I sure enjoyed that video of your Cox Stuka flight!
Darryl
Offline bill bischoff
« Reply #3 on: February 15, 2021, 04:09:25 PM »
Isn't "crackling sound" indicative of a plug that's too hot? Try a different plug just because it's easy.
« Reply #4 on: February 15, 2021, 05:15:09 PM »
Test is ' leak down ' . fueled , put it at top dead center. or the piston right up. even .
Turning it after 5 or 10 seconds , it should have compreshon still, assisting the piston down . if idll hold it for 30 seconds , life is marvelous .
Yep. I think the props the problem .  4 inch pitch is the go on the FPs , or otherwise close .
Some say ' the crackling ' noise , is when its ' right on ' and going bl**dy marvelous . cept with the 6 in pitch youll be at 150 % speed, maybe .
If it flicks ove bouncey , finger & thumb at hub, too. Youve nought to worry about .
Cheap & nasty fuel can wreck them , but getting a bit hots not the end of the world .
Do some seaches on " FP 40 " too.
Offline BillP
« Reply #5 on: February 15, 2021, 05:24:24 PM »
I'd say too much prop. Mine ran many gallons of 5% omega with extra castor (to 20%) on an 11/4. The only time I've had engine crackling was when the engine ran way lean and got too hot...it sizzled like bacon in a frying pan when it dead stick landed.  The liner turned blue but the engine still survived and the cause was a plugged fuel line.
Bill P.
Offline Curare
« Reply #6 on: February 15, 2021, 05:33:32 PM »
Have you checked for junk in your spray bar?
Greg Kowalski
AUS 36694
Offline Darryl W
« Reply #7 on: February 16, 2021, 09:08:57 AM »
Last night I did the leak-down test and it holds compression for 30 seconds +, and it does feel bouncy when flipped. Next, I checked the spray bar, couldn't see anything but flushed it out anyway. I found the instruction sheet that came with the engine and I see it recommends on O.S. #8 plug, which is medium hot so I will try a cooler glow plug and also maybe going to 5% nitro as well.  Found 9 inch and and APC 11.5x4 props in my prop stash.
I will have to wait for warmer weather to bench run to see the result, but thanks again guys for all the comments and tips, much appreciated!
« Reply #8 on: February 16, 2021, 10:11:50 AM »
     I understand the waiting for warmer weather. I shoveled and moved snow this morning in -2 degree weather!!   You could take the engine apart and clean everything with some solvent and scotch brite or steel wool, but running it with some good synthetic oil fuel a few times at peak RPM a few seconds at a time with the smaller prop does the same thing if you are not comfortable in working on the engine. It's been discussed a few times before over the years and is nothing new. The hot plug you were using should not be a problem either. It may have been damaged in that runaway you had and could be the root of your problem now. Try the OS #8 during the bench run, but don't be afraid to go back to a new hot plug like you were using. When you over load the engine with too much prop and it over heats, it leans out and gets hotter. If there is any carbon build up in the combustion chamber , glow plug or on the piston crown, it will glow red also and cause the cackling and preignition that has been mentioned.  When the weather gets hot you can go back to the 10% nitro also. Running the flatter props at a higher RPM does take some getting used to. Your flight will go something like this if everything in correct.  Start engine, set RPM in the 9000 to 9200 range, when you launch the airplane it will accelerate out, the engine will unload and the RPM will jump a bit, and by the time you get a lap around again centrifugal force will increase the pressure of the fuel feed and the engine should go a bit richer in flight. Check your lap times or have someone else else check them to see if you are where you are comfortable and have some good line tension. Depending on the plane, and line length, anywhere from 5 seconds to 5.5 seconds is pretty common for most people. You can fine tune from there. If all is right and tight with you fuel system, you should here a slight break in the engine during maneuvers. If your are happy with the result, fly the snot out of it. It can probably be fine tuned depending on what you like. At this point getting some more help will be beneficial, but you should have a pretty good base line now for what the set up should be.
Offline BillP
« Reply #9 on: February 16, 2021, 10:34:16 AM »
I think you are chasing down a rabbit hole. Mine has such low compression it only starts with an electric starter. It isn't "bouncy" when cold and I could hand flip all day and not start... but immediately starts on elec. It's down on power but otherwise runs fine on 5% omega with added castor and hot plugs. Try 11/4 or 10/6  and see what happens before changing nitro or plug.
Bill P.
« Reply #10 on: February 16, 2021, 11:20:08 AM »
      If it has compression and moves freely, there is almost certainly nothing much wrong with it internally. I would look at leaks around the head or backplate, or clogs the intake system. At most I would clean it in case of varnish (crock pot/antifreeze, NOT with steel wool, or anything abrasive) but that seems unlikely using that fuel.
     If a particular type of plug worked before whatever happened, it will work afterwards, too.
    That is more pitch than is wise for performance reasons, but it won't damage the engine - I assure you I and many others have used much more demanding props (in my case, a Rev-Up 13-5 (really 4.5) at "incandescent lean" settings) and while it wasn't great to fly, it certainly didn't break it.
    It's something very simple, but that doesn't mean finding it is easy. Clean the needle/spraybar, check the backplate and head screws (that they are *snug*, don't crank down on them with a cheater bar), put it on the test stand with a 11-4 or something like that, and fire it up. I would do it ASAP so if you have to keep going you will know it, but, to be honest with you, if it was cold out, I might be able to other things to do.
Offline Darryl W
« Reply #11 on: February 16, 2021, 03:14:34 PM »
Well the good news is that I didn't wreck my 40FP-S, that was my big worry. This forum is such a great resource of knowledge and experience. I will continue to track down the cause but when I say it is cold here, I'm talking Canada cold, 20 below for the past  two weeks.
I am not anywhere near being comfortable with taking an engine apart so I like the idea of a couple of bench runs with a 9 inch prop if it comes to that. I learned my lesson when a few years ago I wrecked a pair of old 1950's Fox 35's by thinking I had to soak all the varnish off the pistons...guess what happened to the compression. Duh!!! HB~> I have been wondering if there is any way to restore compression on those but that's a topic for another thread.  Maybe it has been already covered on this forum, I should do a search.  But I digress.
I will be happy when it gets warm enough to run my 40FP, at any RPM.
« Reply #12 on: February 16, 2021, 04:48:17 PM »
An 11-4 wood prop, as Brett recommends, is much safer than trying to run a .40 on a 9 inch prop.  Sure, a 9" will unload the engine, and allow it to run high RPM to clean out carbon.  But a 11" low pitch is just as good, and it will not fracture your finger, in case you don't use a Chicken Stick.
« Reply #13 on: February 16, 2021, 08:17:30 PM »
" I am not anywhere near being comfortable with taking an engine apart "
FP's are pretty basic . theres a pin / slot for liner alingnment . Chamfer in rod big end goes against the crank web ( forward )
Justa founda this . Good for a read , anyway .  S?P
https://www.youtube.com/watch?app=desktop&v=hHo51FObdIg Disassempling and re assembling OS fp 40 and Tower 40 engines 190726
A decent allen key, hardened . A soft one will soon round off .
A small V or - scraped to the piston front on top . NOT to the edge . So it can go in frontwise again .
Often the gudgeon / wrist pin , sticks a bit . In the rod. If its sat aeons . The nylon wrist pin pads will loose theie ends if you pry them out without warming the pin assy. BE WARNED ( so dont pull the white nylon pads )
The sticky wrist pin and mild corrosion on it, needing polising off . a brief rob with 600 wet & dry , if needed . Polish shiny on 1200 W&D.
WHY ' we ' pull the wrist pin pads, is to stick a piece of wire through , to do the above . Holding it with forceps etc .  P I N G , & its gone  . into the rafters or some such . Brings us too
CLEAR THE BENCH beforehand . Put out a few paper towels or sheet of paper , to lay it all out .
Soak & clean all the bolts , Then oil . Clean the crank & crankpin ( if its all gungey ) with maybe 3M green pot scourers. slightly used . then if needed polish . AND the wrist pin holes in the piston
with a 5 mm strip of 3M puledd into & twisted through .
 :P
Delacquering old diesels , the last 3/32 of the sides at the crown was left  untouched, on some, for the seal .
Castor Oil Rich ( 1/3rd ) and a good hammering for heat on the NINE INCH PROP  on the Fox may reseal the crown in two or three runs . The heat atracts castor. Crowns Hottest .
All pins/ journals should be free but not slack. dont SCOUR OUT OVERSIZE . just carefully clean off deposits .  H^^
thisisupthetop ofthe board here . https://stunthanger.com/smf/engine-set-up-tips/list-'your'-set-up-for-the-os-46la/ similar on FPs which are similar , elsewhere, in SEARCH .
DONT STRIP IT , if its clean & oiled . Gungey as heck & it may pay to.
« Last Edit: February 16, 2021, 08:47:04 PM by Air Ministry . »
