  • June 22, 2025, 03:15:18 AM
Author Topic: Merco question  (Read 1043 times)
Dwayne
Merco question
« on: December 26, 2007, 05:31:43 PM »
Hi
Could someone please tell me if there is a difference between a black Merco .40 and the regular Merco .40?
Dwayne
Re: Merco question
« Reply #1 on: December 27, 2007, 12:32:56 PM »
Ian   I believe  this is your  cue  y1
Offline rustler
Re: Merco question
« Reply #2 on: December 27, 2007, 03:07:17 PM »
Yup, I can comment on this one. The first side exhaust Merco 40 was with the original width bypass, and so far as I know, was natural finish. Later the bypass was enlarged greatly, (also the 29, 29diesel, and 35), and I know these as black anodised. There may be some transition engines, possibly original bypass/black, but more likely large bypass/natural. The only difference technically is the bypass width. Theoretically the large bypass may give more power, but bearing in mind all the bits of wood, chewing gum, araldite, epoxy, etc. which folks use to reduce bypass area in some engines, this may not be an improvement for stunt.
Ian Russell.
Re: Merco question
« Reply #3 on: December 28, 2007, 09:31:48 AM »
Back in the early 90's the local hobby shop started stocking Merco's.  We bought one of those black .40's and the engine that came in right after was virtually identical but in a natural finish.  The .40 we bought was nothing but garbage.  It's like the cylinder is tight in the middle and loose at the top.  Definitely not impressive.
Offline rustler
Re: Merco question
« Reply #4 on: December 28, 2007, 04:34:27 PM »
Andrew's comments are worth noting. Bear in mind that Merco has had various owners and various build qualities over the years. Dwayne - best to asses your motor on its own merits. It may be great, it may be not so great. During the bad periods, the point is the engines were aimed at the r/c market, where the owner would stick a starter on it and basically it could not fail to run and give some sort of adequate service.
Ian Russell.
