  • June 20, 2025, 04:51:59 AM
Author Topic: Merco 61 dual plug  (Read 4317 times)
Dwayne
Merco 61 dual plug
« on: August 07, 2013, 09:38:02 PM »
I have one given to me free, can anyone tell about them, venturi size etc.
thanks
Dwayne
Offline Andrew Tinsley
Re: Merco 61 dual plug
« Reply #2 on: August 08, 2013, 02:29:57 AM »
The Merco 61 is an excellent old style ringed engine. Think ST V 60 stunt engine and you are there. It has been claimed that the ST 60 was a knock off of the Merco 61, with some justification. Ignore the dual plug head, it was really an RC gimmick. I believe that only one plug lights up and that is the one you power up, or so I am informed by more knowledgeable people.
 In my experience just about any way you would run an ST 60 will equally apply to the Merco. They are a very underrated engine and will give excellent performance. they don't shake as much as the ST 60 and apart from the inevitable ring problems on occasion (Just like the ST 60 and 46!). It will give you sterling stunt service.
Andrew.
BMFA Number 64862
Online Bill Hummel
« Reply #3 on: August 08, 2013, 03:31:47 AM »
I'll echo Andrew's comments, and suggest venturi sizes of .295-.305 gives a nice run.  Mine prefer the "classic" lower rpm, 5.5 to 6" pitch engine run. Most any ST muffler should fit the Merco case.  Different builds by different companies during the Merco 61's era gave some inconsistency to quality and fits.  Still, a wonderful "old style" stunt engine.  Perhaps Ian Russell will jump in here with his excellent Merco info!
ama 72090
« Reply #4 on: August 08, 2013, 08:06:46 AM »
Echo ,
flogged pictures to illustrate std C/L intake  . Flower Pot - ish , Trumpet - ish Bore . 49s shown . Mine was .275
one for the 61 is .295 , but I'd have to check figures . Run In / loosened off , the 49 hauled two kilo / 72 Oz.
Four Strokeing , on 15% & 20 % Nitro Fox Fuel ( 27% Oil ) on a 12 x 6 wood . Didnt like a tight ( tounge ) muffler
as the needle got to touchy . The big S T silent muffler gave no power loss compared to a open exhaust .
But the SOUND on the open exhaust was ' way cool ' . Vicious Maserati / tuned Bonneville / big block open headers at idle , ish .  <=
Depite factory advice that its not a ' nitro ' engine  . Mine was 1972ish , Got a 61 same series to get over the lost the Merco Blues .  ;D
Right , the book fell out today ; the 49 stock C/L intakes 7.75 mm bore , so the other , in the 61 , is 7.95 mm . spraybars 4.05 mm dia.
« Last Edit: August 09, 2013, 03:18:17 AM by Matt Spencer »
« Reply #5 on: August 08, 2013, 09:45:00 AM »
The very early ones are quite a bit lighter than the ones that look cubic around the bottom of the crankcase. They are becoming difficult to find in good condition these days. The latter ones are plentiful. I think the very last ones were made for target drones, so I wouldn't expect them to be designed for a long life! If anyone knows anything more about the target drone engines, I would be interested if they can share their knowledge.
Andrew.
BMFA Number 64862
« Reply #6 on: August 08, 2013, 12:24:07 PM »
     Agreed that the Merco 61 in general was an excellent stunt motor, a "poor mans ST60" back in the day. I though it might run better than an ST60 in the cases I saw.  One thing that it was noted for was using FAR less fuel for the same prop/speed than the ST. One advantage it had for me was that if I used it, I wouldn't get inundated with advice from "ST60 Experts".
   I never flew my Merco 61, but I have at least one somewhere in my massive stack of stuff. I really ought to go through that stuff and start giving away or selling it.
Dwayne
« Reply #7 on: August 08, 2013, 04:16:04 PM »
Wow, thanks for all the replies. y1  I just weighed mine and it's 12.5 oz with out muffler and venturi not bad at all. I have the cores and plans for a Time Machine I'm thinking this could be a good match.
Thanks again
Dwayne
John Leidle
« Reply #8 on: August 09, 2013, 07:49:14 AM »
   I picked up an older 2 plug head Merco .61   well used .. so I had it reringed ,etc ,  it never had the power of the "newer" single plug .61SS  I have 3 of the newer models from 1990 or so. They are quite powerful. Now if only someone can help me with a rear bearing...............  Funny my Olympus is going to have a Merco .61 in it also  .
Offline Dennis Moritz
« Reply #9 on: August 15, 2013, 08:56:06 AM »
Hi John,
If you can't find someone on the Left Coast to help with the bearing and what not, send me a message. There are a few folks around here who are familiar with the Merco and ST of that era. I'll ask around.
Best,
Dennis
Offline rustler
« Reply #10 on: August 15, 2013, 03:20:53 PM »
G'day. Andrew and Bill have more or less said it all. The purpose of the twin plugs was to aid idling in the R/C mode. The test report shown is for the original light case version, which many prefer for stunt.
Enjoy.
Ian Russell.
John Leidle
« Reply #11 on: August 20, 2013, 08:06:01 AM »
   Hi Dennis,  I showed the rear bearing to Mr. Scott Reise or Portland ,Or.  ( left coast Portland) he showed me where they machined the rear bearing  thinner to fit in the case. I have decided to put the thing back together & use it.
Offline rustler
« Reply #12 on: August 20, 2013, 03:31:55 PM »
Quote from: Andrew Tinsley
  I think the very last ones were made for target drones, so I wouldn't expect them to be designed for a long life! If anyone knows anything more about the target drone engines, I would be interested if they can share their knowledge. Andrew.
Hi Andrew. The Drone Mercos ceased to be made after the "Cold War" ended and the military ceased ordering them. Other Mercos continued for a time after this. The Drone 61's would have any or all of the following features :-
No sandblasting of the castings.
No bushings in the conrod.
No bushings in the gudgeon pin piston bosses.
Exhaust bosses for attaching silencer undrilled.
Plain head, no fins.
Possibly a simplified carb, - not sure about this.
Quite a few of these appeared in "our" market after the military stopped ordering.
Ian Russell.
