  • June 21, 2025, 01:54:07 PM
Author Topic: Merco .49 Multispeed...  (Read 2133 times)
« on: October 26, 2007, 07:18:00 PM »
I got an ancient Merco .49 Multispeed in a bulk buy.   The 5-digit telephone number on the tag indicates pre-1965.
I'm trying the decypher the bolt size.  It's something in the area of 4/40, 5/40, or 3 mm, but not exactly any of these.  Was another thread standard about in Merry Olde back then?  I Merco still around?  How about a head gasket for a bore of .875?
I'm a bit perplexed.  The bolts are a bit buggered, maybe from the previous owner looking inside, bit the piston top looks un-run.   I'm itching to bark this beauty out on the stand right quick.
Re: Merco .49 Multispeed...
« Reply #1 on: October 26, 2007, 09:56:45 PM »
Paul,
"rustler" here on the board is the producer of the Mercos now, as I understand it.  Maybe a PM to him will help.  He does appear to know about all the older Mercos.
Offline Gary Anderson
« Reply #2 on: October 26, 2007, 10:04:10 PM »
Hi, I've got a few of the merco 49 engines and love them. They have a real nice 4-2-4 run, good power and a great stunt engine. I'm going to use one in my stiletto, I use one in a score and pulls the plane with out a problem. I believe you should use twenty-five per cent castor oil. Have a great day, Gary (Try search on this forum, type in merco and I believe you will get some info on this baby)
« Last Edit: October 27, 2007, 01:14:07 AM by Gary Anderson »
Gary Anderson
Offline Bootlegger
« Reply #3 on: October 27, 2007, 05:39:16 AM »
 :!  Try a 4-48 bolt as it is a national fine thread and it fits my Merco engines (35 and 40) . Should be available at bolt supply houses..
  Good luck... H^^
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #4 on: October 27, 2007, 11:20:26 AM »
The engine runs like a champ, 10,200 RPM down to 3,800 and back.  The inside looks brand-new.
The tag from Joe's Hobby Center carries the phone number WEbster 3-6567, a number some of the older flyers around here can still recall.
Per Rustler's site, these units were produced 1961-1963.  The phillips heads are an odd-ball size too, explaining why they're buggered-up, but not why the previous owner took 'em loose.
« Last Edit: October 28, 2007, 07:46:31 AM by ama21835 »
Offline Manuel Cortes
« Reply #5 on: October 28, 2007, 12:59:10 AM »
Hi all!
I´ve used (and I´m using, althought not competing very  hard lately  :P because work and family responsabilities) a Merco 49 in a modified Indigo for more than 12 years (you read well) the engine is better than new and is a real beauty in the air. I recommend you to restore and use it, you´ll like for sure.
My 2 plug ancient bulldog uses withworth 1/8" screws, later versions used different ones (Merco suffered several owner changes in his story)
Hope it helps.
Regards from Spain.
Manuel.
« Reply #6 on: October 28, 2007, 07:53:50 AM »
That sounds good.
I've heard of the Whitworth Thread for years, but this is the first time I've owned one.  And they do mike out to .120".
I used my digital camera and Photoshop as a high-price magnifying glass and confirmed the 40-pitch.  I'll canvas the industrial suppliers in towne to see if any still supports Whitworth.
I've alread confirmed that 4/40, 5/40 and 3MM are not close enough.
« Last Edit: October 28, 2007, 11:49:13 AM by ama21835 »
Offline don Burke
« Reply #7 on: October 28, 2007, 09:26:51 AM »
There is a Whitworth 1/8-40, ling to chart below.  The difference between it an SAE threads is the included angle.  Whitworth being 55º and SAE 60º.  What this results in is the Whitworth being a deeper thread than an SAE.  Although a 4-40 might be close, there would probably be not enough thread engagement and a percieved "tightness" putting one in a Whitworth tapped hole.
http://homepages.tesco.net/~A10bsa/bswgo.htm
don Burke AMA 843
Menifee, CA
