Engine basics => Engine set up tips => Topic started by: John KruziK on December 06, 2009, 06:28:23 PM
Whats the difference between a red head and blue head McCoy Thanks John
AFAIK, the only difference is that the Bluehead is for R/C.
Possibly reds have a sintered iron piston, blues conventional c.i. pistons. Better check with a McCoy expert.
Hi John,
From all I have learned over the years, the McCoy's Head Colors are only different to signify C/L (Red) versus R/C (Blue).
A friend of mine bought a C/L McCoy 40 Stunt that had a Blue head, NIB, back in 1967, Probably just a mix up on the line. I have put restrictors (venturis) in place of the R/C carbs in Blue Heads and found no difference in the runs. Nor could I find any difference in the internal parts. All the R/C Blue Heads had the intake cut down to hold a carb.
Mongo
I have one like that, too. They may have run out of red that day!
