  • June 16, 2025, 02:57:18 PM
Author Topic: McCoy Question  (Read 744 times)
Offline Joe Messinger
McCoy Question
« on: March 09, 2010, 10:50:34 PM »
Hello,
I have two McCoy red head engines (.35 & .19) which were given to me.  I don't have any functional use for them but wanted to get them running.  I disassembled the engines and cleaned them up. Both appeared to have been used very little.  Mostly just gummed up and not much carbon. I haven't yet attempted to start and run the engines.
The .35 has good compression and seems to be OK.  The .19 is leaking either compression or vaccum at the front of the motor.  Makes a hissing sound when the shaft is rotated.  The .35 does not.  I would think the crank bearing/bushing is worn on the.19 but it doesn't show wear any place else. I don't have any specs on the engine so I can't tell anything by measuring the crank shaft o.d or bearing i.d..
Anyone have suggestions as to what the probable cause for the leak might be?  Other than replacing the bearing or crank and bearing, know of any fixes?
Also, the engines are missing the clips on the NVAs that prevent the needle valve from turning and changing when the engine is running.  Any source for replacements?
Thanks in advance for any advice and suggestions you might offer.
Joe
« Last Edit: March 10, 2010, 02:15:59 AM by Joe Messinger »
Joe Messinger
Offline kenneth cook
Re: McCoy Question
« Reply #1 on: March 10, 2010, 03:11:43 PM »
    Joe, its not uncommon to hear the piston leaking down especially in those engines. You stated that they have compression, but did you try them with fuel in them. Any carbon that was on the cylinder walls and piston should be left on due to the inferior fits and quality of metal they were made of. I own several of the .19's which all but one vitrually wore themselves out. I had one engine run exactly one time before it was worn out. I own 6 of the .35's which I've had much better experience with. The lightning bolt cases had a bronze crank bushing while the other shiny cases didn't. The bronze version provides a better bearing surface. I just really haven't owned one of these engines to the point of wearing out a case due to the piston sleeve fit wearing out first. Its imperative to use high castor % fuel while running these engines. The needle valve assmby's can still be obtained through MECOA corp. I've even substituted a Fox .35 needle valve in them which works. I'm a fan of these engines and learned to fly with them so I make a valiant effort to baby the ones that still work. They do have a great sound and a very nice run to them. Ken
Re: McCoy Question
« Reply #2 on: March 10, 2010, 09:57:32 PM »
Kenneth,
Thanks for the help and information.  Good advice!
As I mentioned in my initial post, I probably won't use the engines but wanted to get them running in case I ever do.  I might try the .35 in a Ringmaster one of these days.  Can't think of anything I'm interested in for the .19.
I have a gallon of Fox 29% fuel that should be ok for the McCoys and I'll use that.
Again, I appreciat your advice.  Hope to see you at Brodak's this June.
Best regards,
Joe
Joe Messinger
