  • June 23, 2025, 10:25:21 AM
Author Topic: stalker mufflers  (Read 994 times)
Offline Greg Howie
stalker mufflers
« on: November 06, 2009, 02:29:19 AM »
Has anybody taken one of these stalkers mufflers apart. the  say heat it up to disassemble the muffler . Just wondering how that went ?. Anybody brave enough to dissemble their new muffler ? I ran my st 46 for a short run and it got real hot. sounded choked like a helicopter or something bussing inside a jar . super quite but I feel it is really restrictive . What are your thoughts and experiences with the stalker mufflers stock .
Oh ....I see ,you mean the ones on a string ?
Greg Howie
Online John Miller
Re: stalker mufflers
« Reply #1 on: November 06, 2009, 08:39:43 AM »
I've heated one of the all metal versions before tghey went to CF bodies. Heated it up, awful stinck from the glue, and removed the baffle. Glued it back together with hi tekp epoxy.
Offline Alan Resinger
« Reply #2 on: November 07, 2009, 05:59:33 AM »
Greg,
Use a heat gun to heat the end of the muffler.  Like John said the epoxy used to hold the muffler together really stinks when heated enough to break the bond.  Do this operation in a well vented area.  Is you muffler the metal type of one of the CF tube types?  You need to take a bit more care with the CF type as you don't want to get the DF too hot during this operation.
I am curious as to why the engine would get hot.  Was this a bench run with the muffler on?  Was it a ground run?  Is this a brand new engine?  If new, what kind of prop are you using.  What fuel?  What RPM?
Alan Resinger
Offline Greg Howie
« Reply #3 on: November 09, 2009, 02:22:26 PM »
Yes it was new . Run on a test stand with the all metal muffler on ,now that you mention it probably not the best way you run a new engine. I also used nitro fuel in it . Now I hear that they don't like nitro unless you put in a few head shims. Chulan told me to run it for about one hour and it would be OK . I did not run it again . It still feels tight as can be . Hopefully it didn't get damage it . It has tons of compression .  I used 22% oil Sig 10% nitro .The same I use in my OS 40 . 20% Castor 2% klots . It was a one of engine black head plane bearing 46 he sold as a special on his web site many moons ago. I used an 11x6 ew rev-up
 He had said 18% all synthetic and that I felt would ruin it. It ran strong and 2-4 awesome . I was afraid to run it too rich as I had read that's bad for it too ! . So I pinched it back and forth from rich to lean for a few minutes and she was cooking hot . Not discolored or glowing red or anything like that just hotter that I am used to feeling an engine get on a short run like that .   Like I said very low noise level . I called Chulan after running it just that once and talked to him about it. He didn't think there would be a problem to just run it some more but I haven't .
 I am thinking a few head shims and no muffler would be best for the next run. But thinking that that muffler will never work out the way it is. So I was thinking about gutting the muffler . Anybody use it stock muffler with out cooking their engine ?
« Last Edit: November 09, 2009, 02:47:35 PM by Greg Howie »
Greg Howie
Alan Hahn
« Reply #4 on: November 09, 2009, 02:50:35 PM »
I would put on a smaller prop than usual---that will decrease the load and help with the cooling.
