  • July 17, 2025, 10:06:53 AM
Author Topic: McCoy .35 vs. Brodak .25 swap?  (Read 1791 times)
Offline frank mccune
« on: September 05, 2016, 07:29:17 AM »
       Hello:
       Is it worth the time and hassle to replace McCoy .35 RH Stunt engines with a Brodak .25? The planes in question are the CG Shoestring and the Sterling F-51 Mustang.
       I posted this question in the Classified Section for some reason and got very little response. Lol
        Tia,
        Frank McCune
Re: McCoy .35 vs. Brodak .25 swap?
« Reply #1 on: September 05, 2016, 09:48:15 AM »
It would be well worth your trouble to switch to an OS 25.  You could try the Brodak first, then switch to the OS.
Offline David Ruff
« Reply #2 on: September 07, 2016, 05:36:02 PM »
LOL.
I am running an OS 25 in an Oriental.  It is light.  I cut off the rear NVA ala Phil Cartier and will run a front NVA setup.
Retired Army
Offline Phil Krankowski
« Reply #3 on: September 07, 2016, 06:28:40 PM »
Seeing that the McCoy and the OS are very different mounting dimensions, and I understand the Brodak shares the dimensions of the OS...  The exchange will be less than trivial.
Do you have plans for accommodating the difference in dimensions?  The McCoy is quite a bit wider.
Phil
« Reply #4 on: September 08, 2016, 09:06:13 AM »
    Hi Phil:
    Thanks for the reality check! Why go through so much work for so little possible gain?
    I have not tried the McCoys yet but I have run the Brodak and it is a great running engine.  What I was looking to gain, easier starting and less weight.  I would save about 1.5 oz. with the Brodak which may allow me to avoid using very little tail weight if any.  The F-51 is quite a small plane so less engine weight would be great.  I have a couple of kits for the F-51 so perhaps an old ST G20/.23 would be a good choice for those kits.
        Thanks for the replies,
        Frank McCune
