  • July 08, 2025, 06:25:40 AM
Author Topic: McCoy .35 RH and Series 21 .35 hybrid, is it worth the trouble?  (Read 3032 times)
Offline frank mccune
« on: November 07, 2015, 03:36:28 PM »
     Hi All.
     I have a McCoy .35 Lightning Bolt engine that has a poor p&c fit.  I also have a new McCoy Series 21 .35 engine  I have been told that by swapping the p&c , I will obtain a great running McCoy RH that will last forever. Anybody make this swap and if so, what are your opinions?
     I have been told that  the Series 21 p,c,and con rod will drop right into the RH case with no modifications.  I was also told that the RH case has  to be bored .005" to accept the Series 21 cylinder.  The  RH Lightning Bolt Case is a must as it has the bridges in the cylinder for the Series 21 Dykes ring.  What does this mean if I am swapping the Series 21 cylinder?   Do I transfer the Series 21 cylinder to the RH case or do I use the RH cylinder in the RH case with the Series 21 piston and rod?
      What are the facts of making this hybrid?
        Tia,
        Frank McCune
Re: McCoy .35 RH and Series 21 .35 hybrid, is it worth the trouble?
« Reply #1 on: November 07, 2015, 03:59:25 PM »
You have two conflicting statements that can be easily tested: it should be obvious if the series 21 sleeve is too big for the RH case.  If the sleeve does seem to fit correctly and if the deck height of the two engines is identical, I'd stop right there, use it, and be happy.
« Reply #2 on: November 07, 2015, 04:08:16 PM »
Frank, no need to use the Series 21 cylinder jug if the RH jug has the bridges.  All you will need to do is swap the piston and ring.
I have several that I have swapped the whole set and some that I just swapped the piston.  All keep the great 4-2 run of the Red Head!  I recommend it highly!  I would also get a new ring form Frank Bowman, they seem to last longer than the original ring.  The .29 is the only other swap where the cylinder will drop in.  You have to bore the RH .40 case or simply use the piston only. Nothing on the .19 works.  If the RH rod has any wear, I use the Series 21 rod.  I fly OTS with a Super Clown and a Hybrid .29!  Great engine runs!  I am putting a Hybrid .35  in a memorial Goldberg Cosmic Wind that my best friend's Dad used in 1963 to teach me how to do "tricks".  I ended up with that RH.35 and there was not enough compression left to start it.  It will be a surprise for my friend.
Send me a PM if you need any more info.  It really does create an almost PERFECT Red Head .35!
« Reply #3 on: November 08, 2015, 06:01:31 AM »
      Hello Bill & Ted:
       Thanks for the replies.  I am quite interested in making the swap.
       Bill, I thought that I may be able to swap the jugs in order to obtain a better fit but was too tired to type the question. Lol
        I will post a report of my efforts both good or bad.
        Be well my friends,
        Frank McCune
Offline Andrew Tinsley
« Reply #4 on: November 08, 2015, 07:49:00 AM »
Hello Frank,
I second what Bill says, the total swop is the best way to go, but if you can't bore the RH case to take the cylinder then just use the piston and rod.
I am a bit wary of suggesting the usual way to get a better P/L fit and I will probably get some flak. However quite a few people use a small hammer and or a drift, to tap the top of the piston. This will give a much better fit IF you know what you are doing! Sometimes I have overdone it and have had to lap the piston in again! I take NO responsibility if you break your piston! Seriously, this does work if you are gentle with the hammer. Other  people may chime in about this method of fixing Red Heads!
The RH pistons are of sintered manufacture and this is probably why it works so well and why the piston wears out faster than most. The same firm that made the RH pistons also used the same process to manufacture pistons for the Johnson range of engines, so I am told. Looks as if the sintering schedule was different, because the Johnson pistons were very long lived.
Andrew.
BMFA Number 64862
« Reply #5 on: November 08, 2015, 10:02:27 AM »
I do what Andrew said. Those pistons can be expanded multiple times. I have over the years done it on some at least 3 times. The last ones I did I also heat treated the pistons in hopes of making them a little harder. I am not a fan of dikes rings myself, but they do work. At least while they are running. I have some lightning bolt Red Head 35's that run almost as good as the Red Head 40's. Great power in a good stunt run. But then it is still old school and not modern technology. But as with all old iron they do have some charactor where the newer ones just hum around the circle. To each his own.
« Reply #6 on: November 08, 2015, 01:41:12 PM »
Hello Jim
I think I am right in saying that we  even fly stunt with spark ignition engines! So compared to that, the Red Heads are pretty modern technology!
It is a pity that the RH 35 were produced down to a low (very low!) price. The design if properly executed would have made a pretty good performer. I have rebuilt several of them with better materials and I would brag (just a little) with more accurate machining of the parts. The resulting engines have performed flawlessly to this day and give excellent old fashioned "break" type runs.
Andrew.
BMFA Number 64862
« Reply #7 on: November 08, 2015, 02:03:18 PM »
LOL Andrew. Yep, we are kind of a throwback a guess. My first love is definitely spark ignition. Those things just intrigue us motor heads. The McCoy's and Fox's come next. I have flown and still have some Fox 59's  that I also love. Maybe we just love noise. LOL.  The McCoy Red Heads were a great design, and have a wonderful 2-4 break. But give me an Orwick, Anderson Spitfire, or Atwood 63, for real fun.
I bet your McCoy's that you have reworked with new parts really do run nice. That is part of the fun of the hobby. Taking old engines and making them run better than new. It's a dirty job but somebody has to do it. Somehow us antiques will keep the old stuff flying if just for fun.
Offline Chris Fretz
« Reply #8 on: April 04, 2016, 05:30:52 PM »
I've been wanting to give this a try for a wile now! I only have one lightning bolt McCoy 35 though. I have a bunch of series 21 engines though. Can you put a 29 series 21 piston an cylinder into a 35 red head case?
Formerly known as #Liner
AMA 1104207
Advanced
