  • June 16, 2025, 11:58:30 AM
Author Topic: McCoy .35 Red Head, NVA?  (Read 1516 times)
« on: July 15, 2014, 10:07:38 AM »
Probably should place this in the Classifised?
McCoy .35 red heads, are guys replacing the NVA or buying repros?
What to use and where to get it?
Thanks in advance.
Charles
Offline Jim Thomerson
Re: McCoy .35 Red Head, NVA?
« Reply #1 on: July 15, 2014, 11:31:46 AM »
I have replaced McCoy NVA with Super Tigre NVA.  Work fine.  The McCoy needle is 2-56 thread, as were a number of needles of the time.
« Reply #2 on: July 15, 2014, 12:08:08 PM »
JIm,
 Continue to use the same McCoy bar assembly and just replace the needle? Correct?
What about tongue mufflers? Obviously with straps.
Anyone making nice ones?
Offline John Craig
« Reply #3 on: July 17, 2014, 02:37:37 PM »
The PA needle valve assemblies are very nice.  Randy has them to fit most engines.
http://www.aeroproduct.net/       ( engines & accessories )
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
« Reply #4 on: July 27, 2014, 09:51:50 AM »
A modern Fox 40 needle valve (barrel-shaped with a rubber washer sealing valve) worked for me on my 29 redhead. - Just make sure you have a washer in before the nut on the end of the spraybar!
Eventually however I reverted back to an original McCoy setup, as the fuel nipple on the Fox spraybar was a tad inaccessible.
Tim
(Other spraybars that will fit are K@B and PAW.)
« Reply #5 on: August 03, 2014, 10:45:55 AM »
I've been trying to get a photo of the replacment NVA, or optrions that are used, for the McCoy 35 red head.
I really don't want a large hole in the side of the fuselage for how the McCoy NVA is made.
Does anyone have a photo of your replacement NVA that you're using on the McCoy?
Thanks in advance,
Charles
