  • June 15, 2025, 12:52:35 AM
Author Topic: VECO 60  (Read 1783 times)
Offline Lyle Spiegel
VECO 60
« on: May 26, 2022, 01:41:56 PM »
I have come into possession of Veco 60 / R/C with Perry style carb and original muffler.  No box or instructions. Doesn't look like it has ever seen fuel. I think it has front BB ( don't know about interior), and ring(s)?  1) What is preferred fuel ? 2) What is best break-in procedure? what size break in prop?
Is it worth effort to convert from RC ? what do I use for venturi & NVA? How would it perform vs ST 60 controline?
Lyle
Lyle Spiegel AMA 19775
Re: VECO 60
« Reply #1 on: May 26, 2022, 11:55:58 PM »
Lyle,
I think that engine is very similar to the somewhat later K&B .61? Steel sleeve, aluminum piston, CI ring? You might search under K&B and find more info here on Stunthanger.
If it has ball bearings, so much the better. If it has one in the front, for sure it has one in the back....
I have never run one for control line, but rebuilt a K&B for a friend who did.
With that combination of sliding metal, I'd use at least 22 or even 25% oil and probably half of it castor. I'd probably start with 5% nitro, since that engine has got plenty of moxy to haul a good-sized plane. You can go check Randy's fuel suggestions in the article pinned at the top to see what he recommends.
Because of the metallurgy, the break-in routine is more old-school: light prop load, run it rich, lots of lubrication, don't let it overheat but you want the ring to wear in and seat. Start with a 4-stroke and work your way up to a middle 2-stroke as you put heat cycles on it. Don't run it hot and collapse the ring. Just guessing here, but for break-in, I'd be thinking about an 11x4 prop, maybe a 12x4.
I believe the engine I worked on came off of a Score, which was no lightweight. I don't think the K&B setup is as well understood as the ST.60, which seems to be the easiest of the era for most guys to run. Not sure what size venturi was in the engine I tore down. I don't see that listed in my notes. Sorry.
Offline Christopher Root
Re: VECO 60
« Reply #2 on: May 27, 2022, 08:08:28 AM »
I’ve got one of those engines.  MECOA helped me get replacement parts and break-in tips.  I think the K&B .60 is a direct descendent of that Veco engine
Re: VECO 60
« Reply #3 on: May 27, 2022, 07:36:48 PM »
korekt .
Were quite popular before they realised how heavy they are .
A Patternmaster / Strega etc , it would save noseweight , and work well .
The sturdyness means its pretty smooth & stable .
theolde ' pinch the fuel line & release - 2 sec max to return to 4 stroke , & youre in .
Id be 30 5 castor initially , then 25 , and not 20 till a few hours up . Nitro would wake it up ,
but theyre pretty powerfull , somaybe not neccesary . not for run in initially definately .
We presume its one of these : http://sceptreflight.com/Model%20Engine%20Tests/K&B%20Lee%20Custom%20.61.html
the olde . 3 in bore intake witha 5/32 - in. - 4 m.m. spraybar'd be about right . ( 280 to 320 ish pending on airframe weight ) .
mightve been in the 80 Oz ' MARUT ' & others .
INDEED ! .
Re: VECO 60
« Reply #4 on: May 27, 2022, 08:53:13 PM »
The guts of one KundBeast .61
You can see the front and rear bearings, and the slidey metal parts....
Re: VECO 60
« Reply #5 on: May 27, 2022, 09:28:56 PM »
  Is it really a .60, or .61?? I think even when they said Veco on the side, they were a .61. In my time, I know I have seen a few guys use them successfully. I think they were pretty easy to handle and K&B even upgraded the design years ago with the "Twister Head" , that allowed the whole head/cylinder to rotate to change the head clearance and compression ratio. These were just heavier than a ST.60 and maybe made a bit less power. I remember Russ Gifford using these and don't remember him ever having any issues. I think he liked them for their dependability and they were plentiful and cheap. I have a few in my stash, including a Twister Head model and want to try them out some day when I get a testing mule model that I can change engines on easily.
   PS to ask; Is the Veco/K&B .61 what Windy used in his first Sweeper or one of his other giant stunters??
Re: VECO 60
« Reply #6 on: May 27, 2022, 10:22:07 PM »
If it's anything like the Veco 19's I've worked on, good luck getting the rear bearing off the crank.
Motorman 8)
Offline Peter in Fairfax, VA
Re: VECO 60
« Reply #7 on: May 28, 2022, 04:03:34 AM »
Dan,
You are a good enough metal worker to knock out a copy of the Brodak system.  The design is solid and serves me well on the ARF Pathfinder, allowing a swap between the OS LA 46 and SF 46 no problem.  It clamps the engine, as bolts do.  No pinning of an engine is needed, provided the clamping is kept tight.
https://brodak.com/engines/motor-mounts/motor-mount-system.html
Peter
