CLICK HERE--><--CLICK HERE
Max S-35
Started by Perry Rose, June 09, 2026, 06:38:11 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Perry Rose
I was given two of these engines. I don't know their past.
Today I flew one and after one ounce of fuel, two in the tank, the engine slowed and stopped. Hot. RSM 10 x 6, my mix fuel, 3% nitro 23% oil 60.40 castor/Klotz syn.  On the second flight I richened it a bit and the exact same thing happened at the same time. RPM at launch low 8000. 4 cycle for the most part of the run. I'm thinking it's not broken in. Any other thoughts? It's mounted on a Twister,4 ounce Du-Bro tank on pressure/uni flow.
Dave_Trible
Quote from: Perry Rose on June 09, 2026, 06:38:11 AMI was given two of these engines. I don't know their past.
This is an ALL castor engine in most cases and especially if it has already had run time on all castor.  Also minimum 25% -quite like a Fox .35.  At temp it isn't lubing well enough and getting hot.  They are fine engines but were known to not oil well in the rod area.  Aftermarket rods had holes drilled in the rod ends to allow more oil ingress.  I would STOP running that synthetic detergent in there and get with the castor!!  I use 5/25 castor on them mostly (also Enya and Merco)
Tim Wescott
I ruined my 25S running it on 50/50 castor-synthetic.  Since I'm stubborn I put a lot more fuel through it than you have yours, so you may be OK.  Put all castor fuel in it and see if it has any compression left.
In the event it's not the fuel -- look at the piston through the exhaust.  See if it's clean or gummed up.  Make sure the fins aren't choked with castor gum and varnish.  Check for compression in both the crankcase and cylinder.  Do all the checks that I'm not mentioning because I'm not smart enough.
Tres Lawton
Perry,
Have you checked the NVA, fuel line, and fuel filter for gunk and crud?  If not, check and clean if needed.  Denatured alcohol works pretty good on castor gunk.  Also take note on the lube and rod issues mentioned by Tim and Dave, I ruined a S30 and a S35 con. rod and crank pin.  Luckily, I have spares of each that I now take better care of.  These are great old engines IMHO.
Good Luck
Tres
  If this is happening at the same time in the run on the same amount of fuel each time, I would look at the tank, fuel line, filter, etc. I have two of these in a couple of ARF Noblers, and I run what is more or less SIG Champion, 10% nitro and 20%  total oil, half Klotz and half castor and have no problems, and one of these two has who knows how many flights on it. After a flight, there is always castor dripping off the airplane onto the ground, marking it's spot on the pavement. If yours is quitting at the same time each flight, and the fuel has been used in other engines with no problems, something mechanical is causing that. Take the engine out, mount it on a test stand with a different take, and put a 9-4 or 9-5 prop on it and see how it runs. If that is successful, put the prop on that you used on the model for a tank full and see how that runs. I'm betting on something in the tank. Once the airplane is in the air, centrifugal force should be making the run go richer, if everything is correct if the fuel system, and take off RPM that low would barely be enough to keep it airborne at any respectable lap time. If it's quicker and easier, just try a different tank. Something is causing it to lean out, and doing it at the same point in the fuel flow. Another way to check is to look at the exhaust discharge and see if is dark or has some black streaks in it to indicate metal. Let us know what you find.
Like Like x 1 View List
M Spencer
" suitable for all OS engines " fuel , They got squeaky clean . Another minute and It'dve been squeaky tight . Two and thered be no squek left .
That was Close .
They'll go o.k. on 10 x 4 three blades .( too . )
60 ( or 72 ) x 10 ( or 12 ) wing , with a few of them on , and youd have a thing , if it was light . profile . Cranks equidistant from centerline .
Putting them in the 48 inh ( core ) one wasnt a good idea . Even if theyre the same weight as Veco 18s . IF you keep opening a needle ( somethings blocked )
so inner sags ( on launch ) and outer goes 5.000.000 rpm . Halerious , if your good at duck & dive .
The Brain keeps going , Do This . OS .35s at 60 X 10 wing . Is a Mosquito . Or Whatever yer want .
USED to run 20 % C. in the 70s . 3 % Synthetic would decarbonise as you go , but no more . Some'd say LACQUER is necesary for seal .
Not Cleaning the outsides at the crown was often said to be it , when decarboniseing . Decokeing . Thats about it for that , then .
cept LEES machine shop can do nylon buttons for the crankpin to stop the big end walking & rod going C L A N G . Clean the wrist pins if you strip them , & lands . etc .
Dave Hull
Matt--is that a model of an XB-70? The plane that went so fast that the paint on the leading edges burned off?
McDivot
M Spencer
Thats the ONE .   ;D   got 90 m.p.h. odd , in speed . However they didnt say it was with a Oriental . wing . ( 14 " spacing , eqaul ea. side . To Cranks . )  :P
Its had a few ' wipe outs ' . But still a favourite plane . Thinking 60 x 10 would be more than sufficent for two OS . 35s . ( Thats 48 x 8 , Veco 19 B.B.'s )
Will build to 40 ounce with OS 20s . But thats 60 oz. & o.k. But bigger fuselages are less Yaw , snatch , roll , spin etc, even in wind. Particularly .
Colin McRae
#8
This just sounds like a venturi that is too big. I've seen the same thing happen on different engines. You didn't mention what size venturi was being used. If the venturi effective area is too big it can possibly cause what you were experiencing. A large venturi might appear to run fine on the bench or in level flight but then go overly lean in maneuvers and not recover. And just trying to richen the mixture won't necessarily help.
I picked up a NOS Max-s 35 that came with a 0.300" venturi (effective area 0.0266 sqin) which is huge IMO. Won't pull fuel properly for stunt. If the engine goes lean in flight and slows down, the reduced rpm just compounds the problem reducing fuel draw even more and it can't recover and gets overheated. Muffler pressure sometimes helps if a venturi is 'slightly' big but will not compensate for a venturi that is significantly oversized.
Based on Randy's proper venturi sizing thread discussion for stunt, I put in a 0.275" venturi (eff area 0.0186 sqin) on my Max 35 and the engine runs quite well. I'm even going to try a bit smaller at 0.265" (eff area 0.0160 sqin) to see how the engine performs on my Banshee.
Colin
Old Old x 1 View List
Motorman
Those engines are famous for destroying the big end of the con rod. They will still start and run but very poorly then quit as you described. If they were owned by someone (RC flier) who used high nitro/wrong oil then big chance that's the problem. Pull the back plate and have a look.
MM :)
M Spencer
#10
Think the problems the yard of clearance to the backplate . A m.m. anyway . So the rod can walk back .
LOOKing at the backplate , youll see if its rubbed , lower maybe . The ANSWER is little nylon buttons
/ pads . Similar to the nylon FP / LA wrist pin ones . From Lees machine shop ( by the dozen ) .
AS ITS THE SAME ROD as in the 60s OS 40s , AND OS H-29 R 20.000 dual ball race speed or T/R engine .
Mate .  :o
https://sceptreflight.com/Model%20Engine%20Tests/OS%20Max-H40S%20%282%29.html thereyer seeit . These suckerve got the Same BORe ( size ) as the .35 S . But liner O.D. is greater.
