I read a number of threads regarding the TT GP 42. General conclusion was that pretty much everyone liked it. Opinions ranged from as good/better than a LA 46 to not as good as a LA 46, but good anyway. Anyhow, I've acquired several.
Installing the venturies, on the first two I put in the OS FP 40 venturi, which measures about 0.282" or 0.283". Then, reading the instruction sheet for the motor, the dang thing isn't a 42 after all, it's a 40 (0.396). So, the question on the venturies. As I said, the large OS venturi is about 0.283". The FP 20-25 size I previously bought measures 0.268". The current FP 20 size they're selling now measures 0.259".
So which size have you guys used? I always put the 0.268 size on the LA and FP 40 engines.
I'd appreciate your thoughts/experiences.
Herman
