I have a problem with the run of my XLS 36,it appears to drop revs in some manoeuvre's
but picks them up again,may take a lap and a half to pick them back up,it seems to go rich
when it does it,but it may not do it all the time!I am guessing its only a few hundred RPM, but when the
winds blowing its a bit of a worry.
Any ideas much appreciated.
Prop 11 x 4 APC,Thunderbolt 4 cycle plug,11 castor/11 coolpower,5 nitro. 10,000 rpm ground release
0.244" restrictor venturi with PA needle valve,uniflow open to air.
