  • July 13, 2025, 12:32:23 PM
Author Topic: Magnum Pro 45 hard to start and running with low RPM  (Read 5020 times)
Offline Matt Piatkowski
« on: September 07, 2015, 11:22:05 AM »
Hello,
My Magnum Pro 45 suddenly became very hard to start.
During last month, it always started after priming with the first flip and the launch RPM were 8,800-9,000 with 11x7 two blade wooden prop.
Now, I have to work hard to get it running and the static ground RPM are very low ( 6,500 max on the same prop.)
Checked the plug - it is fine.
Checked the fuel tank, fuel lines, fuel filter for some junk - none found
Checked the Venturi and the NVA - nothing suspicious found
Disassembled the engine completely and inspected everything - no internal damage found, all gaskets intact and in place but compression is weak.
The engine was "soft" during the last month but, again, it always started with a single flip. Perhaps the cylinder-piston "soft" fit became too loose a week ago?
I have removed the head gasket to increase the compression and got some of it back when the prop is flipped fast but the engine is not holding the air in the combustion chamber when the prop is slowly turned left and right, with the piston passing through the TDC.
How to increase the compression?
I have read the discussion about tapping the piston top to spread it but I do not think I will risk doing this.
Has anybody ever tried to machine the groove in the piston and use the matching steel ring in worn ABC engine?
M
Offline Brian Hampton
Re: Magnum Pro 45 hard to start and running with low RPM
« Reply #1 on: September 07, 2015, 05:37:36 PM »
Have you checked that the seal on the centre post of the plug isn't leaking. Or just try another plug.
« Reply #2 on: September 07, 2015, 05:49:01 PM »
The only fully reliable way I know to "check" a plug is to swap in a brand new one from a reliable manufacturer.  Just getting a glow doesn't mean that you've got a working plug.
« Reply #3 on: September 07, 2015, 09:58:24 PM »
New glowplug and a new, soft head gasket. Doesn't have to be very thick, but needs to be soft. I seem to recall copper is easy to soften, but can't recall exactly how...heat and cold water quench, maybe? Copper work hardens, as I'm sure you know, so a new one may help. Might also lap one thinner between two plates with wet/dry sandpaper with oil for lube?
Most .46's will have very similar cylinder bores (except .46LA), so don't get too crazy about digging up the "correct" Taiwanese Magnum part. One for a PRC Magnum .46 is likely to fit, or a Thunder Tiger .46.  y1 Steve
« Reply #4 on: September 07, 2015, 10:24:00 PM »
if it is a Magnum Pro 45 with a two piece case, it is a clone of the OS 45 FSR, and  was made by thunder tiger, there are still piston sleeves around
try to find one or a  used engine  that have good piston sleeve fits are cheap finds at swap meets  and Ebay, or keep a watch out for one on the forums
« Reply #5 on: September 07, 2015, 10:29:09 PM »
The classic method is to blacken the copper sheet with an acetylene-only flame, then turn on the oxygen and get it just hot enough to burn off the carbon.  Then remove the flame.
The sheet will cool quickly enough in air to quench.  I've seen this done with 18-gauge brass car parts, so 5 thou gasket material should be fine.
« Reply #6 on: September 08, 2015, 08:46:59 AM »
There's not enough metal in the piston to cut it for a ring. Send the Piston and sleeve to RayAracing and tell him medium pinch.
Offline Chris Brainard
« Reply #7 on: September 08, 2015, 12:38:43 PM »
I contacted them requesting the same service on this very same engine but was told the sleeve diameter was too big. If they say they can do it, I've got three sleeves I'd like them to service.
Chris
Offline frank mccune
« Reply #8 on: September 09, 2015, 09:07:01 AM »
     Hi Chris:
     You are correct about the maximum size that Ray can shrink.  He told be that one inch was the maximum size that he could shrink.  I was hoping that he could shrink my McCoy .35 engines but due to their finned cylinder sleeves, the diameter was too large.
        Be well,
        Frank McCune
« Reply #9 on: September 09, 2015, 11:51:24 AM »
Guys,
Thanks for the input.
Tried to start it with:
1. 3 different medium and hot brand new plugs, each showing bright orange color of the platinum spiral.
2. Freshly charged 1.2 battery ( showed 1.425 V no load voltage)
Got some burps and one 15 sec. run that died with the glow plug starter still connected.
The venturi is overflowing with fuel but the combustion chamber seems to be almost dry.
Removed the spark plug and injected 3-5 drops of fuel directly into the chamber.
The engine started for 5 seconds and died.
The engine was disassembled completely in search of some junk in venturi, NVA, filters, ports and wherever - found none.
I carefully assembled it making sure the liner and piston WERE IN THE CORRECT POSITION ( everything was marked before disassembly to avoid Oooops..).
I honestly do not know what is going on....this engine was running like a dream for at least 20 flights.
Anybody has the liner and piston for sale?
M
Offline Bill Johnson
« Reply #10 on: September 09, 2015, 12:49:47 PM »
Is that the second time you've had it apart, Matt? Just wondering. It's hard to believe it won't even start due to low compression. Low power, yes.
I've got some good FSR parts at the house. I'll look and see if I have a piston/liner.
Best Regards,
AMA 350715
« Reply #11 on: September 09, 2015, 01:09:20 PM »
Bill,
Yes...I disassembled it for the second time and found nothing.
Fuel lines - clean
Fuel filter - clean
NVA - clean
Venturi - clean
Ports - not damaged, clean
All gaskets - intact and sealing properly.
Compression - low but not zero.
Glow plug - bright orange platinum spiral glow when removed from the engine and tested with the glow plug starter.
Put everything together very slowly and carefully following my marks, scratched on all interfacing parts ( liner, piston, crankcase ) before disassembly.
The engine does not even want to burp now!
Perhaps the glow plug does not ignite when screwed into the engine head and powered by the starter because there is some electrical short circuit somewhere?
How to check it?
Puzzling and annoying..
M
How to check it?
I have no idea what happened
« Reply #12 on: September 09, 2015, 01:12:14 PM »
See the attachment.
Will these fit?
No response from the sellers yet.
Offline Target
  • C/L Addict
« Reply #13 on: September 09, 2015, 01:42:56 PM »
How to check it?
M
How to check it?
I would believe that you would be able to see the "glow" at night in a darkened room with the muffler off, if the piston was below the exhaust port...
Hope this is your problem and an easy fix.
R,
Chris
Chris
AMA 5956
« Reply #14 on: September 09, 2015, 05:28:32 PM »
See the attachment.
Will these fit?
It's much more likely that a Thunder Tiger .46 piston/cylinder would fit...made by the same company. I have a TT .46 that was given to me in parts. The piston/cylinder looks to be good. Have you got a mailbox on this side of the border? Free plus postage.  H^^ Steve
« Reply #15 on: September 10, 2015, 04:42:13 AM »
Everybody,
I have contacted the Thunder Tiger Corporation directly via gmail and received their response.
To: Thunder Tiger Corporation
Hello,
I have Magnum Pro 45 model engine that needs new liner and piston but I could not find these parts anywhere yet.
I was told that this engine was manufactured by Thunder Tiger years ago so you may still have spares.
Do you have the liner and piston for this engine?
If not, perhaps Thunder Tiger 46 liner and piston (Thunder Tiger 46 spare parts No:AN0328) will fit?
I would be grateful for comments and suggestions.
Thank you,
Matt
To: matt.piatkowski@gmail.com
Dear Sir,
Thanks for contacting us. It is true that we once manufactured Magnum engines around 20 years ago, however, we do not have any Magnum engine including its parts in stock. Parts for our existing engines can not fit Magnum at all.
Best regards,
Customer Service
Thunder Tiger Corp.
My comments: I have just learned that Magnum Pro 45 is about 20 years old ( assuming the TT Customer Service person knew what he/she was talking about ).
                      It is rather unlikely that I will find the original, unused parts on eBay or elsewhere but I will keep trying.
Randy wrote: "if it is a Magnum Pro 45 with a two piece case, it is a clone of the OS 45 FSR, and  was made by thunder tiger, there are still piston sleeves around
                     forums".
My comments: the engine has a two piece case therefore, based on Randy's opinion above, the parts from OS 45 FSR will fit and I will keep searching for these parts still having a decent fit.
Other choice ( a bit extreme, I suppose): machine the brand new piston matching the existing liner. I do have the CNC access but need the following:
1. Aluminum alloy definition for the piston
2. Piston surface preparation after machining
3. Machining tolerances
I can measure the existing piston fairly accurately using the micrometer digital caliper but how much more piston diameter I need to restore the compression?
Currently, the cold piston travels easily and with no resistance from the cold liner to the level about 0.15" from the liner top rim.
M
« Reply #16 on: September 10, 2015, 08:33:00 AM »
You're looking at a lot of work for that engine, Matt. Have you considered just buying another? Here's one on the RC forum:
http://www.rcgroups.com/forums/showthread.php?t=2313188&highlight=Magnum+Pro+45
I checked my parts but only have a 40 piston/liner.
Best Regards,
AMA 350715
« Reply #17 on: September 10, 2015, 08:18:56 PM »
Everybody,
I replaced the 2 blade wooden 11.5x7 prop (wide blade) with 11x7 APC scimitar style prop and the engine run consistently for 6 minutes with ~ 9,200 RPM.
Then, I waited 10 minutes for the engine to cool down, fueled the tank and started the engine with the single flip!
Again, 6 minutes of consistent run with RPM = 9,200.
I have no explanation why changing the prop only had such dramatic and positive effect on the engine having poor compression.
Perhaps the timing of the engine ( exhaust timing is ~140 deg.) and the entire internal fuel management was adversely affected by 11.5x7 prop?
Randy always talks about "proper engine loading by using certain props" but it is hard to believe that 0.5" diameter difference and different shape of blades had such strong effect.
Maybe the engines with poor compression are more sensitive for prop changes?
Matt
« Reply #18 on: September 11, 2015, 02:47:48 PM »
The engine is running great and the compression somewhat improved!
I am flying tomorrow.
M
« Reply #19 on: September 11, 2015, 04:16:52 PM »
M
That's good! Now, tell us WHY!
Some of this might be traced to "getting all the screws in the right place", an axiom probably first uttered by a Fox techie. The ASP/Magnum engines from PRC are somewhat subject to this same problem, due to "manufacturing tolerances". But once you get them put together right, they run quite nicely.
One thing I always do is to 86 the cross head screws and put in socket heads. Then, when assembling the engine, I run the screws down only to "contact", then start gently tightening them in a diagonal pattern, using only a standard hex wrench and thumb/index finger. About 3 or 4 laps around and it should be good. Once together and running, I'm an advocate of leaving the engine alone!   H^^ Steve
« Reply #20 on: September 12, 2015, 06:21:01 AM »
Steve,
All the screws in this engine are socket head and yes, I tightened the engine head screws in a diagonal pattern, using very small Allen key moves.
When the engine was completely disassembled for the second time, I inspected all mating surfaces of all the parts with a very strong magnifying glass ( 10X) an found nothing suspicious.
Remembering my Jett 60 dying in the air because of rust that got loose and damaged the piston, I paid particular attention to the piston of this Magnum. I have cleaned it with acetone, dried and used the concentrated light beam at angle to see possible scratches and dents. Of course I found some but they were the order of magnitude smaller than grooves dug in my Jett 60 piston by the rust particles.
Oiled cold Magnum piston moves freely in cold Magnum liner to the level 0.15" below the liner top rim and than the resistance quickly grows.
In my opinion, this indicates softer but still adequate ABC fit.
Magnum Pro 45 has two crankcase gaskets. One in front of the short, main crankcase block, one at the rear of the same block. Both gaskets were intact though heavily soaked in oil. After some more scrutiny, I have decided to replace the front one with the gasket cut from the beer can. I have sanded the paint from this aluminum sheet with 400 sand paper, cut the gasket and tried it tightening the four mounting screws of the front part of the engine in a diagonal pattern. Then, I removed the front part of the engine and inspected the gasket finding the regular and continuous imprint. Then, I put the front part of the engine in place and tightened its four mounting screws in a diagonal pattern.
The original Magnum glow plug ( with idle bar) received new copper gasket and I put back the aluminum engine head gasket I have removed after first disassembly. This gasket was in good shape: no holes, no scratches and no folds.
When I put the engine together, oiled it and flip the prop, the compression seemed to improve somewhat. I believe now that removing the head gasket during first disassembly was a bad idea, leading to a minute leak between the engine head and cylinder, weakening already weak compression.
After final assembly, I installed the engine in my Toucan ( formerly known as SIG Fazer) and tried to start it, using Omega 10-12% nitro fuel without extra castor added. and 11.5x7 wooden two blade prop. I kept priming and flipping the prop with no sign of life from the engine for at least three minutes, checking the battery in my glow plug from time to time and turning the needle one way or the other. THERE WERE NO BURPS. Suddenly, the engine started and run for about 15 seconds with the glow plug starter attached. When I removed the starter, the engine stopped.
I have removed the glow plug and check it. It gave strong, bright orange glow. Put it back and kept priming and flipping. This time I heard a little burp from time to time. Removed the glow plug again and injected some fuel into the combustion chamber. Put the glow plug back and the engine started for about 5 seconds.
After more priming ( the fuel was leaking from venturi) and from the tongue muffler, I have replaced the starter battery for the fresh one ( no load voltage > 1.4 V) and the engine started. It run for roughly 40-45 seconds without the starter attached but the RPM were low (~ 6,000 ) and the engine was lacking power. I have tried to slowly turn the needle to lean it and the engine died.
I have removed the engine from the plane and mounted it on my bench. This time the cylinder was up and I used the plastic 8 oz. tank with the clunk.
The story repeated itself: endless flipping, priming to the brim, removing the plug, checking the plug, putting back the plug e.t.c. I was getting little burps from time to time and got one short, weak run without starter attached.
Then, I removed the plug for the n-th time and kept mindlessly turning the prop "not thinking yet not dreaming" ( from "Enter The Dragon" with Bruce Lee). The engine completely flooded with fuel that was even leaking from the glow plug hole. " I flooded the engine" I thought lazily ready to use my long wood chopping axe
and smash this cursed thing to splinters.
Then I woke up from my "not thinking yet not dreaming" state, put the glow plug back and kept flipping without starter to get rid of all this fuel that was splashing from every engine opening.
It lasted for a while but there was no hydro lock.
Then, I attached fresh battery equipped starter and kept flipping. Again, only a single burp from time to time. I looked at the axe and hesitated.
"One last time" I thought "this time with another prop".
11x6 APC was installed and the engine started with the first flip. RPM went instantly to 10,400 and stayed like that. I turned the needle to get 9,200 RPM, just below 4 stroke, and the engine worked happily for 3 minutes.
I changed the prop to 11x7 APC, waited for the engine to cool down, fueled and started it with the first flip again, getting 6 minutes of stable run at 9,200 RPM.
I would not be able to fly today and tomorrow because it is "raining cats and dogs" in Toronto but I believe the problem has been accidentally solved.
Perhaps flooding the engine with fresh fuel helped to clean some residue of spirit, acetone and after the run oil?
The APC prop is heavier than the wooden one and has more rotational inertia. Perhaps this helped increasing the rate of compression change and the mixture properly ignited?
M
Eric Viglione
« Reply #21 on: September 12, 2015, 09:23:10 AM »
Steve, <Giant Snip>
The APC prop is heavier than the wooden one and has more rotational inertia. <-----
M
This is the deal right there, it's the flywheel effect of the heavier prop. Your engine is still tired, you are just now able to getting it running. A hot glow plug is going to help keep it running. The compression is returning because the fits are re-establishing themselves. I'm not up on the metallurgy of this particular engine, or if the liner has an index key, but assuming it's modern ABC, AAC, etc. you really need to stop taking it apart. Every time you reassemble, the fits have to re-establish themselves, and you put a little more unneeded wear on the thing. I don't even dry flip any of my modern engines unless I have to, like priming, or putting after run oil for storage. The fits are designed to be optimum at running temps. Dry flipping a modern engine isn't necessarily great for it.
A worn engine can run great, depending on what you are doing with it. For sport flying in fair weather, what the heck, have fun. If it starts flaming out, or gets harder to start even with the heavy prop, your time is probably up with that one.
As an exercise, getting your engine running has been interesting, but if the engine is tired and you want to compete in a wide range of conditions, you really need to think about installing a fresh P/L set or if one can't be had, find an alternate/spare engine and just swap the whole thing out... before it flames out at an inopportune time and you lose an airframe...that's just my opinion for what it's worth.
EricV
