  • July 14, 2025, 04:02:35 AM
Author Topic: Magnum Pro 45 - again....  (Read 1003 times)
Offline Matt Piatkowski
« on: October 14, 2015, 07:28:50 PM »
Hello,
The piston in this engine has a hole on the side.
Should this hole be pointing towards exhaust port or away from it?
Matt
Re: Magnum Pro 45 - again....
« Reply #1 on: October 15, 2015, 03:31:28 PM »
The hole in the piston must be at 180 degrees w/r to the exhaust ports otherwise the engine does not suck the fuel at all.
Configuration tested today using 10% Omega fuel with no extra castor added and 11.5 x7 wooden two blade prop.
RPM = 7900 - 8200, time of flight = ~ 8 minutes using the  6 fl. oz. Sullivan plastic tank.
Issue is solved and closed.
Matt
