Well now. It happens that there has been some R&D done with the MACS Muffler for stunt use here in the PNW, by Scott Riese, in PDX. Also flown a bunch by Nils Norling over in the Madras area, on a Profile Oriental. By all accounts, it works really well on a STOCK .40FP. I ran it myself on a stock .46LA, but it did require a different propeller. I liked the run, the fuel economy, and that muffler makes a wonderful handle for carrying your plane to/from the circle. Well, you do want to let it cool off a bit after a flight. It's a bit ugly to some. I had it on a Humongus, which isn't beautiful.
The only bad thing about it is that you have to search for THE propeller that gives you a launch rpm right about 10.2k for the .40/.46 size MACS Muffler. And of course, makes your airplane "happy". Basically, fiddling with props, line length and therefore tip weight to find joy. The engine still needs to be rich enough that it doesn't sag lean in the later (higher) part of the pattern. The bad thing is that the tuned length is fixed, so you're tied to that rpm. With the CF stunt pipes being adjustable, I think that actually would make things easier or at least way better when you eventually get it sorted.
It happens that I have a NIP MACS Muffler for a Magnum XL .25/.28, and I think it might also bolt onto an XLS .36. I'm not at all confident that it would bolt to a .20/.25FP or LA .25. I can tell you that they typically interfere with the LG leg on a side-mounted engine on a typical tail-dragger LG. Great on a trike or monowheel! On an upright or inverted engine, they usually interfere with that wing thing. I have always wondered if the .25 sized MACS Muffler would require a higher launch rpm, or if ol' Mac always made all of his mufflers to launch at 10.2k (or real close, maybe +/- 200 r's).
I've never owned an OS .20FP or .25FP, but I have seen a lot of folks have "run away" problems with the .25FP, and some were Expert class fliers. Not having ever had one or messed with somebody else's, I always figured that there should be a fuel/prop combination that would make the .25FP run steady...more oil, less pitch, maybe.
Some have said the .25FP cylinder liner is too thin and makes them unstable. Yet, the .46LA cylinder is very thin, and they're very nice. Not to mention the Fox .35 Stunt, which also has very thin cylinder walls, and...well, never mind. Maybe somebody would take apart their .25FP and .25LA and tell us what is different?
