  • June 14, 2025, 11:03:04 PM
Author Topic: Magnum GP 25  (Read 1698 times)
Offline Allen Eshleman
Magnum GP 25
« on: June 15, 2022, 07:38:18 AM »
Does anyone have a cheap viable solution for reviving a Magnum GP 25 with no compression.  Man, it has power if I can get it started.  Maybe be sold for parts.  However, I do want the venturi and NVA.
Offline Geoff Goodworth
Re: Magnum GP 25
« Reply #1 on: June 15, 2022, 07:00:11 PM »
A piston and liner from the LA 25.
I had a GP 25 that would start and run happily in cold weather and never looked like starting when it was warm.
I replaced the piston and liner and the engine has been fine ever since.
It's been on a Ringmaster for quite a few years so, some years, it only gets one outing per year. I use auto transmission fluid as after run oil and it usually starts second or third flick after hanging on the wall for a year.
Re: Magnum GP 25
« Reply #2 on: June 15, 2022, 09:52:59 PM »
+1
Re: Magnum GP 25
« Reply #3 on: June 17, 2022, 06:04:21 AM »
That sounds like an easy try.  I will try that.
Re: Magnum GP 25
« Reply #4 on: June 17, 2022, 09:20:19 AM »
If the LA25 fits you could get an ABC from Brian Garner. The LA factory sleeve is Ni, if you want to refurbish your P/L Just get a medium pinch from RayARacing.com   I have used him several times, he does nice work. Assuming the Magnum is ABC.
Motorman 8)
« Last Edit: June 25, 2022, 05:58:50 PM by Motorman »
Offline BillP
Re: Magnum GP 25
« Reply #5 on: June 18, 2022, 11:04:31 AM »
Be aware the GP has a sprinkler venturi/nva so it's not a direct plug and play to an OS FP...
Bill P.
