  • June 21, 2025, 04:17:38 AM
Author Topic: Saito 30 and Shark 402?  (Read 820 times)
Offline Ken Deboy
    • Silk and Dope
« on: May 20, 2007, 11:10:05 PM »
Would they be a good match? What prop and tank setup would work good? Where does the vent on front of crank case need to be routed?
There is a fine line between "hobby" and "mental illness"
Offline L0U CRANE
Re: Saito 30 and Shark 402?
« Reply #1 on: May 20, 2007, 11:54:47 PM »
Ken,
No help, here, on the proposed engine/model match...
If the vent on the crankcase front is the bottom-end breather, it will pump some oil as the engine runs. Just lead it somewhere where it will:
1) Not cause a mess on the model, and
2) Won't oppose the normal 'drainage' of this blow-by oil used to lubricate the bottom end.
NEXT!
\BEST\LOU
Offline Bob Zambelli
« Reply #2 on: May 21, 2007, 09:53:43 AM »
Ken - I have used the SAITO .30 in many planes, including the Nobler, Argus, Ringmaster and Sterling Mustang (profile). I even flew my profile Cardinal with one.
I also have on in my Little Cherokee which has a Nobler size wing.
It does extremely well in all these applications.
I cannot comment on the Shark as I have never seen one.
The .30 does in fact have the breather nipple toward the front, opposite the cam housing. Route it somewhere outside the cowl.
Figure on 2 1/2 ounces of fuel AFTER the engine is completely broken in.
Regarding props, you have to match up to the plane but I would start with 9, 9 1/2 & 10 inch diameters, with pitch in the 5 to 7 inch range. The APC and Master Airscrew are excellent.
