  • July 08, 2025, 02:52:44 PM
Author Topic: Magician 15 engine selection  (Read 1325 times)
Offline nathan Metzner
« on: July 29, 2010, 06:19:25 PM »
I have recently put in an order for a Magician 15 plan. I can't wait to get it and start my build. My question is will an O.S. LA .15 be too much motor for this plane? Would it be benificial to build her a little heavy to slow it down?
Nathan, New guy, Newbie, Youngster, Pleeb, So on and so on
Offline Leester
Re: Magician 15 engine selection
« Reply #1 on: July 29, 2010, 07:42:11 PM »
Nathan, the LA15 would be just fine. No need to build it heavy, you can slow it down if it needs it by prop selection and line length.
Leester
ama 830538
« Reply #2 on: July 29, 2010, 07:47:35 PM »
  No! The weight has a pretty small effect on the speed. And the smaller the airplane, the more critical the weight is from a wing-loading.
« Reply #3 on: July 30, 2010, 09:07:06 AM »
Cool I know I could slow her down with prop I just haven't had much luck with that lately. It seems that my engines are just too touchy with prop selection. I haven't even broke my LS in yet so I don't know if she'll be the same. It seems like one pitch up or down and I can't get a solid run on my other engines. So I shouldn't mess with the weight any fair enough. Just build her how she was meant to be built. Thanks for the input guys.
« Reply #4 on: July 30, 2010, 01:05:30 PM »
   You shouldn't even consider anything but 4" (or less) of pitch. That will keep is spinning fast enough to ensure good fuel draw. Running more than that will make you run at low RPM and that will give up tremendous amounts of power, and it won't draw fuel as well.
      I think that a 15LA is tremendous overkill but it should be manageable as long as you don't try to kill power with the needle. Read the G-34 thread for my approach - same thing here. Reduce the choke area until you get the right speed with the chosen prop, and a solid continuous 2-stroke in-flight. What gets most people in trouble is trying to slow the engine down with the needle and trying to make it 4-stroke.
Offline Dalton Hammett
« Reply #5 on: July 31, 2010, 10:45:14 AM »
Nathan ----  I have one with an LA .15.    It's a good combination,  a lot of fun to fly.  Don't put a huge tank on it, that engine is very economical.....
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
« Reply #6 on: July 31, 2010, 12:55:22 PM »
Thanks dalton I'll do that. It's good to hear that my combo should work. As long as I build i right  n~
