  • July 02, 2025, 10:16:33 AM
Author Topic: Magic Prop  (Read 15337 times)
Online Motorman
Magic Prop
« on: October 29, 2024, 08:21:55 PM »
Is there a magic prop for the Fox 35 stunt? I've heard about the rev up 10-6EW. Did anyone make a mold for that one? Is there a 9-6 three blade that would work? I think I remember some props GA had that looked like wooden spoons? Definitely want something light weight so I don't stress the internals.
MM :)
Re: Magic Prop
« Reply #1 on: October 29, 2024, 08:31:58 PM »
MM :)
  I always had the best luck in general with the Top Flite 10-6 (regular, not "Power Prop").
Re: Magic Prop
« Reply #2 on: October 29, 2024, 09:11:11 PM »
MM :)
Rev up 10-6EW.  If you can find one that will be Magic!  I ran a 9-6 three blade on one plane.  It was OK.  FYI, both of those props worked better on an OS35s
Re: Magic Prop
« Reply #3 on: October 29, 2024, 10:30:51 PM »
  10-6EW might be magic in very hot and near-calm conditions, you need all the blade you can get. It'll be absolute death in significant wind, the whip-up is typically disastrous.
Re: Magic Prop
« Reply #4 on: October 30, 2024, 12:20:55 AM »
Good point. My Fox 35 days ended in 1967.  We didn't know any better back then.  You put a prop on the engine and you changed it when it broke.  Wind up was just part of flying.  Things sure are different now!  H^^
Online Al Ferraro
Re: Magic Prop
« Reply #5 on: October 30, 2024, 08:50:28 AM »
  For me, the Bolly Clubman 10.5 x 5 is the go-to prop for a Fox 35. in a Ringmaster, Nobler, All American, fly great with this combo.
Al
Offline kenneth cook
Re: Magic Prop
« Reply #6 on: October 30, 2024, 02:18:37 PM »
         My preference for Rings, Streaks, is the Master Airscrew 9.5x6. For larger stunters I like  the APC 10x5.
Online Motorman
Re: Magic Prop
« Reply #7 on: October 30, 2024, 03:39:59 PM »
What's the difference between the Top Flite and the Top Flite Super M ? Is it just the type of wood?
Re: Magic Prop
« Reply #8 on: October 30, 2024, 06:46:56 PM »
  As far as I know, that is all. I have both types and aside from the wood selection, they look about the same to me. The variation from prop to prop is considerable, some are good and some are not so good, apparently depending on the flexibility and how they were sanded. I stopped flying Fox 35s long before I knew what I was doing with props, so I can't help you on how to screen them for the "good" ones.
Re: Magic Prop
« Reply #9 on: October 30, 2024, 08:26:03 PM »
I agree the Top Flight 10-6 or  10-5 if the airplane is smallish or light.   The RSM props were pretty similar .   I think the RevUp 10 EW is a little bit of an overload on the Fox-depending on the particular engine.   The regular 10-6 NOT EW is probably better.   I can't tell much difference with the Super M.   I think they were made from a stiffer wood which might cut down on blade flutter.  I believe Super M was how they called sugar maple.  Thats what I use for motor mounts.   I order a plank from a cabinet maker then get it cut up into the sizes I want.
Re: Magic Prop
« Reply #10 on: October 30, 2024, 10:50:54 PM »
BTW, I would "manage your expectations" when it comes to the "magic" part. "Pretty good" is a reasonable goal.
Re: Magic Prop
« Reply #11 on: October 30, 2024, 10:57:28 PM »
Brett--I've found that some wooden props are much better than others. So much so that they are "magical." You can select these by picking only the ones that have an AeroTiger attached to the hub area. Those are the magical props....
The Divot
Re: Magic Prop
« Reply #12 on: November 01, 2024, 03:51:48 PM »
RSM 10x5.5 would be very good if you can get some. It sounds like you want to avoid APC and other plastic props, but the 10-5 APC is a good match. If you can make a light CF copy of it, that would be a good idea. I know Mike Hazel (ZZProp) makes a CF copy of the TT Cyclone 11x4.5, which I would expect could be clipped and re-pitched to work very well.
I've rarely had good results with wood props, especially the TF paddle blades. Even the Clarence Bull produced BY&O 12-5 and Rev-Up 12-5 didn't show me as much performance as an APC or TT Cyclone. IMO, if you can't find spares, testing rare props is only useful in showing you that there is more performance to be found in a better prop...over the rubbish you currently call your best one!  H^^ Steve
Online Motorman
Re: Magic Prop
« Reply #13 on: November 01, 2024, 06:08:09 PM »
Thanks guys, all good information. I went through my prop box and found a Top Flite 11-6 power point. I cut it down to 10", narrowed the tip and re-shaped it to look like a regular Top Flite prop in plan form. It of course has the wrong pitch distribution for stunt but it will give me something to use for now. Just a side note: Don't buy Top Flite Power Point props. They vary wildly. I trying to think of the worst props ever made and I think they win. I was able to go through a stack of them with a pitch gauge to find blades of the stated pitch on both sides. I only buy them to modify into something else then use as a pattern for a composite prop.
Online Mike Hazel
Re: Magic Prop
« Reply #14 on: November 02, 2024, 10:34:11 AM »
Actually, a better choice would be my "Z-Y&O 10 x 6".  This was made from a B-Y&O 11 x 6.  To make the original pattern I used a B-Y&O 11x6 and trimmed the diameter and also left the tips squared off.  I made this mold a long time ago.... Dan Rutherford trying out this prop which puts a timeframe on that.
Re: Magic Prop
« Reply #15 on: November 04, 2024, 02:12:07 PM »
   The "Magic Prop" for any engine/airplane combo is the one that works best on YOUR airplane. What works for your flying buddy Charlie might not be the best for you and yours. The best way to find out is to get the model in at least pretty good trim, and then test fly props. Check them for pitch against what they are marked, and then balance them if needed. There are good starting points for each situation, and then go up or down on pitch/diameter from there. A lot depends on model weight, design and shape (drag.) A Rev-Up 10-6 EW would be wasted on a Ringmaster, but on Mike Gretz's  Fierce Arrow it was what really made the airplane fly like I think it should. It's a fairly clean design, but weighs 50+ ounces. Planes that are smaller and lighter don't need as much prop. I have a pretty big collection of props I have accumulated over the years and was taught early on that if one prop did not feel right, try another. Different blade shapes work in different situations. Plastic props are heavier and can affect how an engine/airplane combo performs. I have a couple of Nobler ARfs that i finished up during my knee rehab, and one had a Brodak.40 on it. It was flying best with one of those grey plastic Thunder Tiger 11-4.5 props on it, but to get the best balance and turn I had to add some tail weight. I compared the TT prop to several other wood props and it's blade shape and arrangement is similar to the old Top Flight Power Props, I think they are called. I did not have one of those older wood props in 11" so I decided to make one using one of those Rev-Up 12-5 drone props that have been popping up hear and there over the last 30 years as blanks to cut one from. I measured the blade thickness at 3/8" increments from the tip to about 1" from the shaft hole and made notes. I made a blade template measure in length from the prop hole edge to the tip off of the TT prop, and transferred that shape to the Rev-Up. Then i set out to remove any wood that didn't look like a TT 11-4.5 prop, matched the thickness and airfoil as best I could, set the pitch, balanced it and put a clear finish on it. Next flying session, I put up 2 or 3 flights with t he B-40 Nobler to get ground RPM readings, lap times and engine run times recorded, then all I did next was change over to the wood copy I had made. At engine start up, the RPM  matched the plastic TT prop almost exactly. Lap times were right where they needed to be and the plane felt just the same as it did with the Thunder Tiger prop. Engine run time was right there also within a few seconds of the plastic prop. I considered the whole exercise a success. Next I tried copying Rev-Up 10-6 and 10-6W props in the same manor and re-pitching them to 10-5 and find that they work well on smallish profiles also. Years ago, I got one of the first SIG Primary Force ARFS flying and eventually upgraded the engine to an OS.32F. I was trying every combination of 11-4 props that I had, and as a last resort, I tried a Zinger 11-4 PRO, and that tuned out to be the Magic Prop for that airplane/engine combo. I had never had any success using Zinger props of any kind but in this case it was just what the doctor ordered. You just never know what is going to work until you try it and give it a thorough flight test.
Online Robert Zambelli
Re: Magic Prop
« Reply #16 on: November 05, 2024, 01:10:52 PM »
I tried a Sail 10-6 wood prop on a Fox 35 and it worked very well.
Online Motorman
Re: Magic Prop
« Reply #17 on: November 05, 2024, 07:24:22 PM »
I wonder how many of these 10-6 props really pitch out to 5.5.
Re: Magic Prop
« Reply #18 on: November 05, 2024, 08:59:01 PM »
    You don't check yours? Don't you have a pitch guage? If you don't, get one and then you'll know. Some peops are shy of indicated pitch, especially wood props. I find APC and the gray Thunder Tiger Props are usually pretty close. Master Airscrew are usually 1 inch less than indicated because they measure pitch differently than you would on a Prather Pitch Gauge. New wood props tend to vary, so do old ones. One odd fact i have seen is all those old Rev-Up 12-5 drone props that have beenbspread around all measure pretty darn close. When I moved out of Intermediate class a bazillion years ago, one ofthe first things I bought was a Prather PitchGauge. How else are you gonna know what you have?
Re: Magic Prop
« Reply #19 on: November 05, 2024, 10:47:34 PM »
     Almost all of them, and they will flatten out toward the tip. I think this is an attempt to correct for/compensate for the difference between the back of the blade and the zero lift line caused by the camber of the airfoil.
   There are a lot of things you can do with props, particularly with pitch distribution, but it takes a while to learn the basic ideas and even if you get the general idea, it was still mostly trial and error.   It's becoming a lost art, since most electric props fall apart if you try to adjust them, and most of the techniques are *far too strong*/touchy on tuned pipe airplanes.
Online Motorman
Re: Magic Prop
« Reply #20 on: November 06, 2024, 12:02:42 PM »
I certainly have a pitch gauge. I just havn't worked with any 10" props.
Re: Magic Prop
« Reply #21 on: November 06, 2024, 10:34:17 PM »
Also fellas, consider which part of this great land you fly in.  Going from Kansas City to Denver I had to use a different prop.   Even going to Muncie IN made a difference.  I have watched Jim Lee writing in his note book after trying some thing new with his planes.  I am bad in not keeping notes. D>K
Online Motorman
Re: Magic Prop
« Reply #22 on: December 13, 2024, 08:56:11 PM »
Those Sail props look nice. Sold by a guy in NJ too. I've got one on order, will report back.
MM :)
Re: Magic Prop
« Reply #23 on: December 14, 2024, 09:33:05 PM »
There were ' W ' & ' E W ' , back then , people cut down a inch or two bigger , to get extra blade width .
I used a 14 x 5 , thinned the blades a fair way ( to 2/3 thickness  ) and trimmed it to 12 inch .
good for hot days and high alt. flying sites . If theyre both , then it shows its merit .
Besides , what else could a do with a 14 x 5 Zinger . Twice the mass of a real prop,
like a 12 x 6 . Sand even side to side , as you go . Mark in a place or two , to match
material removed . Like 1/4 , 1/3 or 1/2 chord , plank sand to line & fine sand so
your disapearing the line , smooth hard edges & corners . Found a bottle of Fiishing
rod lacquer , will see how this goes . it says on it its ' Extra Hard ; , so may wear well .
You can see , IF the ENDS were an inch IN , thered be a fair bit off blade area on that .
But the MASSof the thing is such that you want to get rid of half off it , The THINNING makes it a good deal easyer for the engine to swing it .
These ' W ' s & ' E W 's were pretty much ' factory ' versions of this sort off thing .
Online Motorman
Re: Magic Prop
« Reply #24 on: December 14, 2024, 09:58:53 PM »
Some of my best props started off as Zingers.
MM :)
Online Motorman
Re: Magic Prop
« Reply #25 on: December 22, 2024, 08:40:58 PM »
Recieved the 10 x 6 Sail prop. If you measure the pitch on the flat part of the face it measures 6 pitch. This prop has so much Phillips entry that the actual chord of the airfoil measures a stone cold 7 pitch. The prop was a little off balance side to side. It had a 6mm hole so, I filed one side of the hole until I got to 1/4" and the balance came in ok. Wood grain and finish was nice otherwise. Didn't get to run it. OAT was 26F so I'm pretty much grounded for a while.
Online Lauri Malila
Re: Magic Prop
« Reply #26 on: December 23, 2024, 12:09:59 AM »
So, now you have a statically balanced prop with off-center hole? That’s not really the way to do it well. L
Online Motorman
Re: Magic Prop
« Reply #27 on: December 23, 2024, 07:15:13 AM »
It's ok if the 6mm hole was off center which was the problem. Now 1/4" hole is on center. Didn't want to carve on the outside because I might return it for the 10x4 which will probably be a 10x5.
MM :)
Re: Magic Prop
« Reply #28 on: January 07, 2025, 07:32:06 PM »
Never having heard of "Sail" propellers, I used DuckDuckGo and searched for them. They make a 12-4, which I'd try on a .46LA, but no 11-4 for my Magnum XLS .36's. Drat!  HB~> Steve
https://sailpropellerusa.com/gas-engine-sport-pros-beech
PS: I've never tried XOAR propellers, but would have liked to. I just searched for XOAR, and it appears that they are 100% big R/C sizes or quadrotor sizes, mostly CF and $$$. I know that the RSM props were made by XOAR under contract.
Re: Magic Prop
« Reply #29 on: January 07, 2025, 09:50:34 PM »
Steve,
Xoar makes lots of props "our" sizes:  9" and up diameter, 4" pitch and up. Check the PJA series made from beechwood. I have used these and the ones I received are very well made.
For example, they list an 11x4 that you could try on your Nagmum .36.
Re: Magic Prop
« Reply #30 on: January 08, 2025, 12:34:26 AM »
   I usually get Xoar props through an eBay seller, rchobbysolutions or rchobbyexperts. I think it was the one with solutions in the name. Search Xoar on eBay. They are the main importer for Xoar props for the US. I wanted some 9-4 and 9-5 wood props in left and right hand directions for a project I need to get back to, and while communicating with Xoar directly, who said they would make me anything I wanted for a $200 set up fee, they suggested going through this eBay seller. I contacted them, told them what I wanted, and they put the order in. It took a couple of months but didn't matter as I wasn't quite ready  for them yet, but they eventually came in and at $7 or $8 each at the time. They have stuff run out of stock but get resupplied pretty quickly. The Xoar factory web site is pretty big!! And kind of confusing, but was fun to look through. I found the props I wanted, and they were listed under a hgeading as being for "gas powered drone props" !! I didn't know such a thing existed!! But they are good quality and they work well. I think the Xoar 13-5 and 13-6 work better on a ST-60 than any other wood prop that I have tried, including the venerable Rev-Up 13-6.
