  • June 16, 2025, 11:21:21 AM
Author Topic: Blank  (Read 1330 times)
Online Rusty
Blank
« on: March 02, 2021, 07:34:43 PM »
Blank
« Last Edit: March 10, 2022, 07:54:58 PM by Air Master »
Re: Mac's Muffled Tune Pipe and Rossi 53
« Reply #1 on: March 03, 2021, 06:16:35 PM »
you need to furnish the RPMS  you will  run at  and  the  exhaust timing of the  engine. Then you can get a base setting
You will  also need  to confirm  if , and where  the baffle  is in the  pipe
Offline George Truett
« Reply #2 on: March 03, 2021, 07:28:58 PM »
This sheet was supplied with OPS tuned pipes for years, it will at least give you a starting point.
