  • June 17, 2025, 11:37:44 AM
Author Topic: Low/High comp. heads for Enya 35 #5224  (Read 1172 times)
Offline Frank Sheridan
« on: May 25, 2009, 06:02:50 PM »
Years ago I bought an Enya 35 that came with two heads and three venturis. The R/C version of this engine did not come with two heads, did it? There are always a couple of the 5224 R/C engines on Ebay. Which of the heads would the R/C version have come stock with - low or high? I also noticed that the later 35 came with a square venturi. Was this the only change Enya made to the 35? My old Enya 35 took quite a while to break in, and still had great compression years later.
Re: Low/High comp. heads for Enya 35 #5224
« Reply #1 on: May 25, 2009, 06:37:34 PM »
OK, I was wrong - the square venturi apparently came first. Sorry about that. I was barely out of diapers at the time.
