  • July 05, 2025, 12:37:02 PM
Author Topic: Low compression: effects, cause cures?  (Read 3188 times)
Offline frank mccune
« on: April 06, 2015, 08:11:27 AM »
    Hello all:
    Recently, I have been running some old engines that have me confused.  I think that the problems originate with poor cylinder compression.
    The problems are as follows:
Difficultly in starting
Very sensitive needle valve settings
Very narrow range of speed
Engine quits or sags when battery is disconnected
     The engines in question are four lapped c.i./steel and four aluminum pistons with rings in a steel cylinder. The lapped engines show NO leakage anywhere in the engine.  The p&c fits are great with no leakage and there is no leakage around the plug or head.  The cylinder compression is very low.  The ringed engines have very poor fits of the rings to the cylinder and are not included in this question other than to demonstrate that they too share the same problems.
    Now to the questions: What causes low compression other than engine design?  I am comparing two Veco .19 engines that look the same but one has great compression and the other does not.  I can also do the same comparison with two Fox .29 engines.  None of these engines have any compression leaks.
   What are the cures for low compression other than replacing the p&c with new ones or having the cylinders chromed or pinched?
    I have experienced this problem all of my life with model engines.  Some were great and some would never be any good.
    Any ideas or thoughts?
        Tia,
        Frank McCune
Offline Lauri Malila
Re: Low compression: effects, cause cures?
« Reply #1 on: April 06, 2015, 09:05:21 AM »
Frank,
Since you are comparing 2 similar engines, I'd first check their head volumes. It's easy, just remove plug, turn piston to tdc and measure with fuel & 1..2ml syringe.
Also check the squish clearance.
Lauri
« Reply #2 on: April 06, 2015, 09:23:23 AM »
     Hi Lauri:
     Thanks for the reply! I will try that today.  Both engine parts "look' identical but a test may reveal something.
                                                          Stay well my friend,
                                                          Frank McCune
« Reply #3 on: April 06, 2015, 09:48:12 AM »
Frank, I think you need to separate out things a bit.
Compression ratio has to do with the gross geometry of the engine: it's the volume of the whole cylinder (ignoring ports) at bottom dead center divided by the volume at top dead center.  (Some people measure the volume from port closure instead of BDC -- but I'm pretty sure that stated compression ratios are from BDC).
Plain old compression, being the pressure generated at top-dead center, has to do with the compression ratio and with how much the engine leaks compression away.  I have some really good engines in this regard that you can put at TDC, leave them for an hour, and when you touch the prop they'll pop away from TCD.  I have other engines that you can put at TDC, blink, and there's no compression left.
I suspect that you care about leaking.  Most of the tests I know involve dribbling fuel in various places, turning the engine, and looking and listening for bubbles.  Common places for leakage are around the piston (you'll see bubbles in the exhaust port), at the liner/head mating surface (you'll see bubbles under the head), around the glow plug, and through the glow plug.
Finding out where your engine is leaking tells you nearly all you need to know about what to do next.
« Reply #4 on: April 06, 2015, 10:00:33 AM »
    I am not convinced that the problems you are having are entirely based on the compression (or, technically, the piston/liner seal). I have had all sorts of compression seal levels but not these sort of issues.
     But, overall, the sorts of variations in compression and unexpected variations in the compression and fit you notice are the same as most of us had back in the era. One ST46 would have great compression, the next, felt like you left out the glow plug gasket. As far as I was ever able to determine, the actual batch of iron used for the ring made all the difference. Some batches seemed to have ideal properties, the next might not. I expect the same sort of thing was going on with the pistons, and given that many of them were very poorly made (in terms of quality control) in the first place, it was just a crap-shoot. Thats why we all carried multiple backup engines and a box full of parts, and hoped you could find one that would work on a particular day. The reason people latched on to Fox 35s was not the performance, it was that it was reasonably repeatable from day to day - once you got one that worked, it worked for a long time.
   I hate to say it (again), but the cure to all of this is to use *modern AAC/ABC/AAO/AAplasma cylinder/piston assemblies*. Getting rid of iron piston/steel liner engines, or even worse, ringed engines, was the greatest step forward in stunt since Bob Palmer put flaps on the Go-Devil. That's why I never recommend anyone seek out older engines unless they absolutely have to. Getting a modern engine more-or-less eliminates the sort of wild variations and difficult handling properties you are talking about, and that's why almost no one uses anything else. I haven't thought much about how my piston might be doing since about 1988, it's just off the radar, you gas it up, flip, and fly it.
« Reply #5 on: April 07, 2015, 07:20:33 AM »
    Hi Ty, Tim, Brett et.al.:
    Thanks for the replies.  I guess that I should stop beating myself to death working with 1950's technologies.  The new engines are vastly better than what we had in the 50's!
    As stated, there are no leaks and the p&c fits are great!
    Yes, I eid the piston heating, knurling and the striking the piston with a hammer, but all that I got was a warped piston,one that
was knurled and wore out again very quickly or the piston broke at the knurl lines! Lol
                                                           Stay well my friends,
                                                           Frank McCune
« Reply #6 on: April 07, 2015, 10:00:00 AM »
    It's not that big a deal, just run them as it was done back in the day - pick the best and use that one, if it goes over the hill, use the next best!
     I have had exactly zero luck with any of the piston-growing tricks, too. The chances of breaking it are pretty darn high compared the likelihood of an improvement.
« Reply #7 on: April 07, 2015, 10:15:38 AM »
Hey Frank:
What Brett said -- they is what they R.
If you have a good P&C fit then there's no need for piston growing or knurling or any of that -- you do that stuff to fix a bad P&C seal.
Beyond that you could check to see if someone put in lots of head shims.  I doubt that.  Just run 'em and be happy; if that technology was as good as modern, we would have never switched over.
« Reply #8 on: April 07, 2015, 10:29:55 AM »
It's a stretch to blame poor compression on the "iron and steel" technology.  Keep in mind that K&B Torpedo, Orwick, O&R, Madewell, and many other 40's and 50's engines were made exactly that way.  They universally had great compression with no leaks, and they stayed good for a very long time, with the correct fuel.
« Reply #9 on: April 07, 2015, 10:56:34 AM »
      Yes, and steam engines opened up the West. There are *very good reasons* that you don't see them running around today.
    None of the engines mentioned can cut the mustard as competitive model airplane engines today - not even close. They weren't competitive stunt engines *in the 50's*, with the possible exception of the K&B.
« Reply #10 on: April 07, 2015, 11:56:08 AM »
I have 8 Orwick engines from the 40's and 50's.   They do very well "cutting mustard".
F.C.
« Reply #11 on: April 07, 2015, 02:21:50 PM »
I have expanded the pistons by tapping them with a hammer on around 30 to 40 McCoy Red Head 35's and 40's. I broke the first one, but the engine was no good without trying. The rest have all worked great. I have won and placed in many local contests flying a Magician with a McCoy 40 in advanced PA and Classic. Over the last 15 years that engine has had the piston expanded 3 times. A Nationals winner it is not. But, that old McCoy 40 will run a great 4 stroke from beginning to end of the flight with just a beep into 2 where it needs it. But if old engines are not your thing get an OS LA and have fun. I am to old to try to win the NATS, so I have more fun flying old stuff. Oh, I also have a first place trophy from the SAM Champs in Old TIme flying a Ringmaster with a McCoy 35 Red Head. Of course, there were only three of us flying. LOL
Offline Andrew Tinsley
« Reply #12 on: April 07, 2015, 03:13:42 PM »
I actually like and used to work on steam locos, I refer them to diesels locos. I run modern engines and I run things like Orwicks on ignition. Both are easy to start both are the same day in and day out.
If you are enticed to get rid of those old style engines, just let me know.
Andrew.
BMFA Number 64862
Offline Phil Bare
« Reply #13 on: April 07, 2015, 04:28:05 PM »
You can grow most any machined  meehenite iron piston by heating it. The trick is to get it to the right temp and letting it cool in a box of sand.  I have a piece of 1/4 x 2 CR steel that I use clamped in my bench vise with about 6 - 8 inches hanging out of the vice jaws.
I clean the piston well and then set it on the end of the 1/4 x 2. I heat from the bottom side of the 1/4 x 2 until the piston is cherry red through out. I have a bucket of sand that I use in order to prevent chilling the piston.  I prepare the sand by making a hole about 5 inches deep and about 2 inches or so in diameter. I place the bucket of sand on a bench under the end of the 1/4 X 2 so that when the piston is cherry red, I can just sweep it off the 1/4 X 2 and into the hole in the sand an cover it up as quickly as I can. I let it stay in the sand and cool until the next day. This prevents chilling and shrinking .
I haven't figured out any method of fixing a 'modern' engine after the plating has peeled off the liner and trashed the piston......
Regards, Phil Bare
John Leidle
« Reply #14 on: April 08, 2015, 05:54:07 AM »
  Hi Tim,   a design engineer might use your formula to determine compression ratios but try raising the exhaust port & see what happens in a 2 smoke engine
  john
 P.S.  I'll be down in 9 days please don't drink all the beer .
