  • July 12, 2025, 04:18:19 PM
Author Topic: Looking for crankcase leaks  (Read 1324 times)
« on: October 21, 2018, 10:28:07 PM »
How do the engine experts look for crankcase leaks?  I've got a pair of Fox 40 Schnuerle-porteds, one of which I'm thinking of putting into a scale plane.  The other one runs crappy and doesn't give a "puff" when the transfer port opens.  I'm pretty sure it's leaking out the front seal (it certainly barfs lots of raw fuel out the front when I try to run it!) but I'd like to make sure.
All I can think of is to find a position where the transfer is open and the intake closed, put a muffler on it, and blow into the exhaust while looking for leaks.  Is there a better way?
Thanks.
Offline Dane Martin
  • heli pilot BHOR
Re: Looking for crankcase leaks
« Reply #1 on: October 21, 2018, 11:41:29 PM »
Syringe instead of blowing, and in a pool of alcohol. Test a good one, that'll be your "allowable" amount of bubbles.
« Reply #2 on: October 22, 2018, 09:03:07 AM »
It's a bushed engine, although it's certainly big enough to have ball bearings.  I suspect it's in the same case as a 60!
I think the other one is good -- I'm going to get it on the test stand and see if it'll work well enough for a scale plane.  If it does, then the leaky one is for spare parts only.
Offline dennis lipsett
« Reply #3 on: October 22, 2018, 11:13:29 AM »
I have a NIB Fox 40 bushing motor. R/C but that isn't a problem with a carb switch. Just a heads up if you cant reconcile the problem.
Dennis
« Reply #4 on: October 22, 2018, 11:36:27 AM »
Dennis
Thanks Dennis.  It's for a scale plane, so the carb isn't even an issue!
My engine has the carb on a flange, though -- am I mistaken about it being a bushing engine?
« Reply #5 on: October 22, 2018, 02:13:57 PM »
Tim,
The flange mounted carb is from an earlier version. Did it have the over/under muffler or exhaust flange mount and was it a little larger or the same as the one I show. Parts are not to the best of my knowledge interchangeable in any way.
Dennis
« Reply #6 on: October 22, 2018, 05:52:49 PM »
Tim,
Dennis
This engine.
