  • July 11, 2025, 01:56:20 AM
Author Topic: Longer con rods in high timed engines.  (Read 4652 times)
Offline Chris Wilson
« on: January 15, 2014, 05:38:43 PM »
Hi all,
         just wondering what the effect of using a slightly longer rod in a high timed engine might be for stunt use?
Say for example I have an engine with 160º exhaust timing and I get a rod made that is 1mm longer in order to reduce that timing does it unduly effect the transfer timing?
Thanks.
MAAA AUS 73427
Offline Brian Hampton
Re: Longer con rods in high timed engines.
« Reply #1 on: January 15, 2014, 06:37:57 PM »
Hi Chris
The transfer/boost timings would be reduced by close to the same amount as the exhaust, probably within a degree or so because of rod angularity. Depending on the length of the piston you may end up with some SPI though and the head would need to be raised by the same amount to keep the same compression.
« Reply #2 on: January 15, 2014, 06:41:19 PM »
Hi all,
Thanks.
Hi Chris
That can be a very complicated retro fit that can kill many things,and cause lots of grief... first it will also change the main intake and boost port timing, It can give you sub port induction ( bottom of piston uncovers) It will raise the C/R, it can interfere with the head, causing much damage, it can and most likely will affect the piston/sleeve fit. in motors like new ST and T.T. motors you may not be able to bolt the head on without interference . If the ports are short ,top to bottom, and it is a square or short stroke engine, you can drastically affect scavenging. Others problems are numerous, You will need to look at all of this before doing that type of mod.
« Reply #3 on: January 15, 2014, 07:06:07 PM »
Thanks for the rapid replies guys, and I am roughly aware of the rod angularity changes, primary comp ratio change etc - its more the effect on the transfer timing.
Its also the sort of thing that can be reverted easily though.
The TDC fit concerns me too.
The engine in mind is  (or was) a Super Tigre X45.
Thanks again.
« Last Edit: January 15, 2014, 07:44:33 PM by Chris Wilson »
MAAA AUS 73427
« Reply #4 on: January 16, 2014, 05:38:49 AM »
Chris   Many years ago in the 1980-90's when I was doing a lot of work on the ST/40-46's I built several that had the sleeve dropped .005-.015" . Hemi the head to keep compression down and control flame front. Cut head fins down to keep heat in motor. Most ST motors run to cold. These motors ran very well and had more power with large props in large planes.  I stopped flying those large models and went to 600Sq" and have for years run the much smaller 11/5 prop with a stock timing. These mods were common on the older cross flow motors Also those motors used a lot more fuel.
« Reply #5 on: January 16, 2014, 07:57:14 PM »
Chris
On those ST's (or even a G51) it's not possible to use a longer rod because the piston comes to within about .005" from the top of the liner. I'm guessing your engine is similar to this one at http://sceptreflight.net/Model%20Engine%20Tests/ST%20X45FI%20SP-TS.html
« Reply #6 on: January 16, 2014, 08:44:43 PM »
Um, ............. ok then.
You got me as the engine in your supplied link is exactly what I have.
A longer rod is a moot point here, thanks Brian.
MAAA AUS 73427
« Reply #7 on: January 17, 2014, 09:11:19 PM »
The Pylon engines use a longer stroke and a longer rod.  They apparently found that at high rpm's it produced more horsepower.  Harder to get a good setting though.  If they set it off a touch too lean it will overheat, sag, and require a new piston and liner.
The only way to figure it out is to read some of the literature on two strokes and figure out how much you are going to change the timings.  From some stuff I read the engineers the time(or rotation of the crank)vs the open area of the port greatly affect the engine.  The curve has to be within a certain range to get a good running engine.  Once you've got that you have to adjust the various timings, the size of the passages, etc. to suit the intended use.  Once you've done all that, as Randy Smith has proven, an oversquare engine is more tolerant and easy to set without losing significant power for engines that have to maneuver.
Phil C
Offline Brian Gardner
« Reply #8 on: January 17, 2014, 10:14:44 PM »
Longer rods also affect the acceleration and deceleration around TDC. How heavy is the X45....that's something else to consider....like others have said it's a tangled web of sub piston induction, deck heights, thransfer timing (which you could raise back up again), but in the long run a lot of screwing around
« Reply #9 on: January 18, 2014, 11:55:35 AM »
   ... for little ultimate gain. Particularly when a brand new 46LA is under $100.
Offline Douglas Ames
« Reply #10 on: January 18, 2014, 03:47:39 PM »
Thanks again.
Are you talking about an increase in stroke by 1mm or increasing rod length by 1mm (new piston with raised pin)?
The latter will give you more piston dwell at TDC and a more favorable rod angle.
AMA 656546
« Reply #11 on: January 19, 2014, 02:21:27 PM »
Hi Doug,
             talking purely about a longer rod as a way to reduce the exhaust timing - commonly enough done with model diesel engines.
I guess its up to the use of a tuned pipe to tame a 160º exhaust timed engine for stunt and I am thinking about using a pipe from an OS Max 46 VF for the job with (under advisement from Randy) a longer header to see how it goes.
As to the mucking around, its all good fun here.
MAAA AUS 73427
« Reply #12 on: January 19, 2014, 03:07:01 PM »
I ran an MVVS 40 on pipe very successfully for a while, it had 160 deg exh. You couldn't run a typical stunt 4/2 switch, rather the rattly 2 clcle in level flight which loaded up and came on song going verticle. It worked great in a heavy model, but was hard to get right in a light model.
The correctly timed engines were vastly more user friendly.
« Reply #13 on: January 19, 2014, 04:09:07 PM »
   It accomplishes the same sort of timing changes that dropping the liner does. And the other undesirable side effects.
« Reply #14 on: January 19, 2014, 07:45:38 PM »
If I remember correctly, the shorter rod improves torque, all else being equal (timing, stroke, etc). Probably better to make a new liner with suitable timing.  H^^ Steve
Offline Andrew Tinsley
« Reply #15 on: January 20, 2014, 04:03:13 AM »
Hello Brian,
Which MVVS 40 are you talking about. There were (I think) different liners for stunt and R/C engines. I am playing around with some MVVS 49s and I believe they are the R/C timed versions. I am not too sure as they came without carbs/venturis. Can you, or anyone else, give me some timing figures so I can work out what I have?
Andrew.
BMFA Number 64862
Offline Lauri Malila
« Reply #16 on: January 20, 2014, 12:53:40 PM »
Steve,
A longer conrod gives a THEORETICAL mechanical benefit, a better lever action at power stroke, that is favorable in low RPM/high torque ideology.
The original question was stupid at first glance but when I spent some time pondering it, it suddenly became interesting :) . If we are only talking about a small increase of rod lenght, like some tenths of a mm or max. 1mm, the cylinder head relocation is a rather simple job to do.
The modification may be beneficial in turning a normal schnuerle engine into a 4-2-4 running engine also because raising the b.d.c. effectively fucks up the scavenging, as you can forget the original port angles. It seems that inefficient scavenging is an important factor in a classical stunt run, together with bad thermal balance. My only worry would be the exhaust port, personally I prefer it so that in b.d.c. the piston edge is clearly below the bottom of exhaust port.
Basically, these things cannot be calculated, trial & error rules!
Lauri
« Reply #17 on: January 20, 2014, 02:31:18 PM »
Hello Brian,
Andrew.
There were at least 3 different liners that I have seen, a high timed RC one, a low timed CL one and the later Akrobat liner that can be distinguished by its trapezoid shaped transfer ports.
Somewhere I have an original email from Josef Svardja who I believe was a designer at MVVS that tells  about exhaust port hieghts - just have to find it so please be patient.
Cheers.
P.S. A snippet from an old test -
     "Also on the inside is the altered porting. Whereas the exhaust  to transfer  used to be around 140 to 120 degrees, the exhaust  lead (blow-down) has now been reduced  to 140/130  timing. This  is done for a better stunt run at the cost of all-out power."
ACLN 67.
« Last Edit: January 20, 2014, 05:12:15 PM by Chris Wilson »
MAAA AUS 73427
« Reply #18 on: January 21, 2014, 01:00:30 AM »
I don't have the engines anymore, but I may possibly have the book I kept all the specs in. Peter Norrie has (did) one of my old models with the 50 that I made a piston & liner for. It worked pretty well. Dunno if he still has it.
« Reply #19 on: January 21, 2014, 07:47:27 AM »
Hi Chris,
I would be interested in anything you can dig out, I have plenty of patience, as my "filing system" is probably worse than yours! One of the engines was in an R/C plane (although it came to me without a carb). I am not too sure if this is really an R/C engine as the guy I got it from specifically said that it had lots of low down grunt but not a lot of power at full chat compared with another MVVS 49 that he had. I can't talk to him again as he was killed in an accident a few weeks ago.
Andrew.
BMFA Number 64862
« Reply #20 on: January 21, 2014, 02:04:51 PM »
Hi Andrew,
 the supplied snippet from a test was for the Akrobat liner  and if you are dabbling with diesel conversions here I have heard that even the high timed liners make for good stunt diesels - they simply don't seem to suffer from runaway at all!
Cheers.
MAAA AUS 73427
« Reply #21 on: January 21, 2014, 07:43:06 PM »
Hi Doug,
On second thought, I believe OS built the VF with standard RC timing also.  It might be easier to get that piston/sleeve assembly.  Using the longer rod and the high timed sleeve will shorten the power stroke, which is not good on an engine intended for lower rpm.  You might be able to find a piston/sleeve from a similar engine that will fit, or only need a light cut on the OD to fit.  Thunder Tiger and Magnum/ASP did a lot lot copying from OS.  On motors with the same bore the sleeves and other parts are often only a thousandth or so off.
« Reply #22 on: January 21, 2014, 07:58:52 PM »
  Using the longer rod and the high timed sleeve will shorten the power stroke....
How does changing the distance between crank pin and piston pin centers ever effect the distance between the crank pin and the crank center?
To change the stroke distance you would need to independently change what determines top dead center and bottom dead center (the crank arm distance) and a longer rod simply displaces the stroke.
Or am I missing something here?
MAAA AUS 73427
« Reply #23 on: January 22, 2014, 02:46:31 AM »
Thanks Chris,
You are right about diesel conversions of the 49. They run beautifully, best stunt run you can get, although I will probably get shot for saying so on a US forum! I must strip down my 49s and see exactly what I have in terms of sleeves, time to get out the timing wheel.
Andrew.
BMFA Number 64862
« Reply #24 on: January 22, 2014, 06:10:21 PM »
Andrew,
 still looking for the original information about the liner timings but please accept that my memory gives me a 6mm exhaust port height with the RC timed liner.
Now none of my MVVS's have that height so make of it what you will but I assume that the lower timed liners will be  ........ well, lower than that.
MAAA AUS 73427
« Reply #25 on: January 23, 2014, 12:59:35 AM »
I finally found the book I kept all this stuff in. The MVVS 40 I used on pipe was 125 transfer & 156 exhaust. I don't have the actual dimensions of the liner & ports though.
« Reply #26 on: January 23, 2014, 11:47:08 AM »
Thanks Chris and Brian, now to do some measuring!
Andrew.
BMFA Number 64862
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
« Reply #27 on: February 26, 2014, 01:34:44 AM »
Hi to all you American Aeromodellers out there!
One solution around using a longer conrod would be to make/have made a new piston with the holes for the wristpin slightly off-centre, ie. closer to the transfer port side of the piston. This will solve your transfer port opening issues, and give you a little more exhaust stroke (although this won't really make any odds, as the piston doesn't do anything when the crown is below the bottom of this port anyway).
Following this, you could always take abit off the bottom edge of the exhaust port to level it to your new piston, remembering an oval profile works best - (and don't forget to chamfer inside edge of port after rework!)
Also bear in mind that a new piston with offset wristpin will eliminate any risk of the piston fouling the cylinderhead with a longer rod, as you've effectively 'shortened' the stroke by moving the wristpin off-centre.
Hope this helps,
Tim
« Reply #28 on: February 26, 2014, 05:40:38 AM »
ST/46 and 60 did the long rod short rod in the early years. They moved the wrist pin location to keep the timing the same. There was no difference in power.More clearance is needed in the case for a longer rod.  y1
« Reply #29 on: February 26, 2014, 12:08:47 PM »
Super Tigre typically did the long rod short rod for the single and double ring pistons, the Single ring used the long rod, there wasn;t enough room at the top part of the pistons for 2 ring grooves, so they lowered the wrist pin hole and made a rod shorter , by the same distance.
