CLICK HERE--><--CLICK HERE
List "YOUR" set up for the OS .46LA
Started by Bill Little, April 02, 2011, 11:57:37 PM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
Ron Hess Sr
I have a os la 46 and the break is to strong,it comes on @8 and stays on until level again? suggestions on how to 4/cycle more. Thank you. Ron.     here is the setup.
11.5x4 apc -T.bolt plug. metal backplate.
10/22 powermaster 1/2-1/2.
.282 venturi and ST.nva and 1-head gasket.
scott dinger muffler with no pressure.
B.line air filter with green screen.
6.oz uniflo tank.
Paul Taylor
#26
I took one right out of the box and bolted on Ryan's Tutor II. Ran two tanks of fuel through it and went flying. Set it between 9600-10200 depending on the weather conditions.  We run Lou's brew 10/22 on muffler pressure on a clunk tank swinging a TT 11.5x4.5  One flip starts every time.
I also have one with a standard OS front mounted NVA metel backplate. Standard muffler running pressure to a clunk tank. APC prop 11x4 same fuel and rpm as above.
Set it and forget about it.
My Therapy involves Balsa wood and bad decisions.                               https://www.wpmpa.com
Everyone becomes a memory. The question is: will you be a good one or a bad one?
Kindness echoes. So does cruelty. People remember both.
Bill Little
Quote from: Ron Hess  Sr on September 18, 2011, 09:02:16 AM
6.oz uniflo tank.
HI ROn,
Sorry for being late, but I just haven't felt much like spending time on the computer for a few days.  Chemo starts tomorrow........
Anyway, the LA.46 is generally run in a "wet 2" mode since that is what the stock timing likes to do.  Props in the 11-1/2 to 12-1/4 diameter and pitch from 3-3/4 to 4-1/2.  One excellent set up is the APC 12-1/4 X 3-3/4 prop ans set just off peak rpm for launch.  To get a real 4-2 run you will probably have to lower the blowdown which will cause some loss of power.  Derek Pickard gave a run down on this in a Stunt News (??) article a while back.  He raised the top edges of the intake ports in the cylinder.  He also talked about cutting grooves in the top of the piston to achieve the same basic result.
It doesn't appear to be the case where too many are getting a true 4-2 run on the stock .46LA.
Big Bear
Chris Wilson
Here is an alternate setup that probably doesn't fit your template guidelines! Enjoy.
http://www.davisdieseldevelopment.com/diesel_conversion_0S46LA.php
MAAA AUS 73427
gwassenaar
Quote from: Bill Little on April 04, 2011, 02:01:50 PM
My purpose is to gather information in one thread so that fliers (like Frank has already contributed) can see what different people are doing and have a "clue" when they start to use theirs.  The OS .46LA is very popular (as it should be ;D ) but not many people actually ever say "how" they have set theirs up or how they "run" them.  Just, "I put an OS .46LA in the Nobler............"
Prop, fuel, venturi, NVA, muffler (yes, Steve, I should have included that ;D ), type of run, etc., used will give people a start point.  Too often we are guilty of just saying "use a LA .46" which leaves questions in some minds.  Putting these set ups in a single thread will save time, IMHO, for those who have not used the .46LA yet.
Mr. Little, perhaps the posts on the LA 46 engine a bit lower in this forum could be transferred here?
Also, I think it would be useful when people specify the glow plug they use. See my discussion on the use of the Enya 3 plug?
Scott Pahlow
Hi Guys,
This is my first post. I have a few LA .46 engines. I am a beginner. (retread) I fly profile Twisters , Cardinals , and I have an arf Brodak Pathfinder. All with the LA .46. I use a Curtis Shipp backplate, 7mm Stuka Stunt delrin venturi, (longer) and Randy Smith style NV from same. I like the rubber gasket to keep the needle setting rather than the "collet " style of the Super Tiger NV. I haven't taken the head off. I do use a bru-line green air filter , and a Sig GP003 plug with idle bar. I use the Admissin tongue muffler from SS. It seems to run hotter. I have used muffler pressure. I like the way it runs with the pressure. I have used normal vent and uniflo vent I like the uniflo better. I use 11-5 , APC. All my engines are converted from RC , if it makes any difference. I mix 3 gal of Wildcat 15% premium and one gal of Fox Superfuel. It comes out to abouit 12% Nitro and 22% oil - mostly castor. Yeah my planes get oily! I launch 9800-10000 on 60' lines for about 4.8 second laps. They start right up , speed up the last lap or two. Wet 2 stroke the whole run. It works well for me. So that is my 2 cents worth. Thank you all for your posts that help me. #^
Scott Pahlow
Paul Taylor
Because I got a new LA .46 coming in the mail in a few days I started looking here for more info on this engine. Then I remembered some time ago I got a PM from Pat Johnson with some very good information.
Here is his PM.
Paul,
This is one of my favorite subjects as the LA46 is one of the best engines I have ever owned.  Here is the Top Secret setup!:::
Starting with a ST style NVA through the body in the usual place, I use anywhere from a .257" (stock LA25) venturi up to a .275" venturi.  With 5% nitro and 24% oil, this produces fuel consumption anywhere from 2 3/4 ounces up to 3 3/4 ounces.  Starting Props are 11.5 X 4W APC and the 12 1/4 X 3 3/4W APC.  These props are very good but a little heavy.  A modify 12" props to approximate the lap times.  The wood props weigh 1/3 the weight of the APC props and reduce GP by that much.  A "Rabe" rudder helps negate the effects of the wood props.
Other minor mods to consider:  Install a metal backplate.  They are supposed to make for a more consistent seal.  The second is to decompress the head a little.  I open the chamber a little with a ball shaped stone in my drill press.  Primitive, but it works.  Opening up the combustion chamber is better than shims as the plug stays a consistent distance away from the face of the piston.  The decompressed head does not seem to make all that much difference and is just an option to play with.
Hope that helps.
Pat
Some good info from Pat.
And for those of us to don't know.... what is a squash band? I saw that in a few post here.
phil c
Quote from: Paul Taylor on February 18, 2012, 07:11:28 AM
Hope that helps.
Pat
Squash band or Squish band-  If you take off the head you see a more or less flat circle with a dimple in it so the glow plug shows.  That leaves a band around the face of the head, the squish band.  Usually it has a slight angle in it, maybe 2-3 degrees.  It's purpose is to squeeze the charge into the dimple with a lot of turbulence so it burns cleaner.  To do that it needs to be about .010-.015 away from the piston at Top Dead Center.  Since higher compression is needed to run at higher rpms, Pat's method of opening up the plug cavity lowers compression so it matches stunt rpms and still lets the squish band work.  Let's you run bigger props without overheating.
Chris Wilson
MAAA AUS 73427
I'm still running the same setup I developed over 12 years ago when I first comverted an RC LA46 to Stunt use (The CL versions weren't available yet) in a Scarinzi Blue Angel for VSC (Too far back to remember which one).  It still works very well here in Tucson (2200 ft alt) or in CA at sea level.
Run Style:  solid 4, Breaks a little toward end of flight on overheads.
Venturi:  .280
NVA:  ST (.156 dia valve body)
Prop
Make:  APC
Diameter and Pitch:  11.5 X 4,  9600 RPM Launch, on 66 ft lines (center to center)
Fuel
Brand:  Brand has changed several times over the years bu mix has remained constant.  Used Power Master GMA 10-22 half and half for last several years.
Nitro%:  10%, except in summer here in Tucson switch to 15% when temp goes over 100 degrees.  Have on occassion used 20% but only effect is about 10% more fuel usage.
Oil% and "Blend": always 22% half castor half synthetic.
Quantity used:  Varies a little from one engine to the next but typically about 4.5 oz  some have used as much as 5 oz (3.8 to 4 oz with port mods listed below).
I've modified the transfer ports to re direct the intake flow toward the rear of the cylinder on a lot of LA46's and it does improve fuel consumption a little and seems to broaden the torque curve...although this is subjective but does make sense dynamically.  Less of the incoming charge in the cylinder lost out the exhaust port.
It works and is worth while however I would caution anyone who tries it that the crank case is very thin in the area that needs to be modified and it's easy to break through to the outside world.  I did a "how to" thread on the other stunt forum many years ago on the redirect machining required.  Note that this is not a port timing change the engine timing is not changed.  I have tried modified timing changes but most did nothing really noticible at best and some were decidedly not good.  I also tried different head chamber shapes and squish band areas.  Not much improvement for a lot of work.  I did most of this work when the engines first came on the market with the intention of marketing some replacement parts but other than the redirected ports decided that the engine ran just fine for most folks without modification and that marketing parts would likely not be a very enterprising business.  I also got more responsibilities at Raytheon about that time and couldn't keep up with continuing to do engines.
This, in my humble opinion is the best stunt engine available for under $250.00.
Ray Rowh
Your milage may very but this works most days.  Stock LA46s- plastic back plate were resealed with RTV, 2 of them have the metal back plates that  have been sealed with RTV also- Ven is 265 w/ stock OS nva listed for 20 through 40 LAs - APC 10.5 X 4.5 RPM 11,200 for flying in the wind - APC 11 X 3 RPM 10,800 to 11,100 this is a wet 2 - APC 11 X 4 9,800  - Top Flite, Zinger, Brodak narrow and wide blade in 11 X 5 and 11 X 6 with RPM range 8,400 to 9,000 will give a nice break as long as the outside temp in below 85* with less than 70% hum. Made sure to check the balance on all props!  Thunder Blot idler bar long - Power Master 5%- 22% half and half - Big Art tube muffler, to fine tune use one of those flexable extentions and cut the length to what ever works the best for you.  Tank is a clunk 6oz(on muf pressure) with fuel used between 3 3/4 to 4 1/4. Out side temp, hum, and nitro does change this here. Lap time on my Cardinal (44oz) with 62' - .015 lines run 5:05 to 5:40.  Landing time is always less than 7 1/2 min.  Back when we could get away with running a tongue muffler getting a good 2-4-2 run wasn't that hard with most any 11 X 6 wood prop and on good days an APC 11 X 6 could be made to work.  The hole size and number of holes in the tongue muffler make a big difference too.  I think we're 1,000 above sea level here in Akron Ohio.  All these numbers come from 4 different LA46s, one has 6 hard years of crash and burn, two had 15 or 20 flights when I bought them 5 years ago and one was new 3 years ago.  My flight book and I got really wet the last time out and some of these numbers are hard to read, but the LA46 will do anything you want it to do once you get the right set up.  Roger Strickler and Gary Tultz helped me work out different things to try and the one thing that surprised me is the different weight in props.  One bag of T.F. 11 X 6 wood props can very as much as 3 grams from prop to prop.  Here's the difference is some others APC 10 X 6 is about 31.5 grams - Master Air Screw  22.7 - Xoar wood 17.2  Merry Christmas and a Safe New Year - Ray
AMA 858923
RandySmith
""This, in my humble opinion is the best stunt engine available for under $250.00.
Randy Cuberly"""
Hmmmmmm   I would put up an Aero Tiger against it any day of the week, will far outperform the LA 46 and last about 3 times or more longer
Reptoid
Quote from: RandySmith on December 25, 2012, 11:00:45 AM
Randy Cuberly"""
So....He should have said "under $239" ? VD~
All kidding aside; do you have any new ones in stock?
Merry Christmas
       Don
       AMA # 3882
RandySmith
Quote from: Reptoid on December 25, 2012, 01:43:59 PM
Merry Christmas
Yes they are in stock , and are 239.00 ... so maybe try 238.00  ... nO that would not work either, there are other motors :-_
Garf
#39
LA 46, stock venturi, Super Tigre NVA, aluminum backplate, 1 extra head gasket. Fuel, home brew 5% nitro, 15% castor, 5% klotz, 3 to 4 oz. Prop, XOAR 12 X 4, Tower 40 muffler. Pulls my Fronkensteen 4 with authority. Setting, wet 2.
Quote from: RandySmith on December 28, 2012, 11:40:29 AM
Well Randy I'm afraid I have to disagree with you.  I have two Aerotigers and they are great engines but definitely will not handle the prop or the airplane weight that the LA46 will...
Believe what you will, I've tried many times to fly a larger airplane with an aerotiger and it doesn't work well!
So "Sorry Charlie" but it just ain't so!!!
The advantage of the Aerotiger of course is that it's smaller and lighter but put it in a 650 SQ in 57 oz airplane and it will suffer.  The LA46 with more displacement is just a different animal and will fly a bigger airplane easily.
In a Nobler size airplane at 45 to 47 oz. the Aerotiger shines.
In my opinion you're comparing apples and oranges!
RandySmith
Quote from: Randy Cuberly on February 22, 2013, 05:42:39 PM
There is a guy in cal. flying a 60 ounce TP, Ted Fancher design, Aero Tiger powered 60 size ship, with authority, PTG was stunned when he saw it.
so that blows your theory that it has not enough power. sorry
It also knocked many of Bill Werwages  ST 46s  out of several of his airplanes, and It will pull a USA-1  which is about 750 sq in..........
The Aero Tiger will also turn the same prop that Walker used on his  Impact running a VF 40... with authority.
They will also last many times longer than the LA will.
regards
goozgog
My two cents worth. This is flown on
modified .40 sized Cardinals with 62'
lines.
- Standard OS venturi and NVA. (Not remote NVA)
- metal back plate
- Gently cut back squish band.
- APC 12.5 x 3.75 prop
- Omega 5% fuel with 5oz of castor added.
- Idle bar plug
  This set up 2-4's beautifully and seems to
work well in the wind. The added castor does
turn everything brown but it gives me
more consistent runs.
  I own 6 LA .46's but, (and this is my point)
the oldest one with many hundreds of flights
is also the best. It's getting a little sloppy in
the bearings but I know it will start and it's
very consistent. I would fly an LA straight
out of the box, but they seem to improve
over time.
   The LA.46 isn't as good as my PA.40 or my
Ro-Jett but it's almost as good.
Cheers! - Goozgog
Keith Morgan
Ron Varnas
Great thread on the LA 46 setups, just one minor thing a lot of the guys are not specifying what type & brand of plugs they use in their setups ?? ???
RJV Melb. Australia
Geoff Goodworth
#44
Now it's been flown by a few people who like it, here's my LA 46 setup:
Model—my Shoestring 40, designed with Bob Reeves around the Brodak P-40 wing (see Control Line World Jan 2011) which weighs a porky 59 oz
Engine—stock with an FP 40 backplate (I bought a couple before they all disappeared)
Venturi—stock (the large 7.1mm/0.280" dia from when FP 35/40 was supplied with two venturis)
NVA—stock OS through-the-venturi part
Plug—OS No6 supplied with the engine
Muffler—Standard factory E-3030 with the outlet drilled out to the diameter of the outlet tip, i.e. the casting draft removed (5/16" dia).
Propeller—APC 12.25 x 3.75. I had been using a Bolly Clubman 11.5 x 5 until I crashed last year and broke it so I'm saving the remaining Bollys until I can fly better.
Tank—3 1/2 oz Brodak deep profile uniflow, no muffler pressure—currently gives about 8 minutes flight time
Fuel—22% oil, 50/50 blue Coolpower and castor, no nitro
Garf
Fronkensteen 4 (heavy), OS LA 46, Tower 40 muffler (large exhaust), XOAR 12 X 4 prop, Fuel-5% nitro, 15% castor, 5% Klotz. 3.75 oz gets a pattern.
Steven Kientz
Stock nva, 11x 5 zinger prop, Brodak tank on a 58oz. rebuild of a Tutor II(STUNT PIG). Actually all that was left of the plane was the wing. Don't know what lap times or for that matter fuel(doctored up some r/c fuel). I do know it is thoroughly broken in(2nd airframe) and runs great right out of the box.
Steve Kientz
AMA 855912
Brian Massey
Here's my LA 46 set up on a 53 ounce Trophy Trainer;
NVA: Stock
Venturi: Stock
Back Plate: Stock
Muffler: Scott Dinger
Head shims; Added 2 (3 total)
Fuel Tank: 6 oz round Sullivan cluck tank on pressure
Prop: Brian Eather 12.5 x 4.5 reworked to 12.25 x 4.2
Fuel: GMA 10/22 (50/50)
Glow Plug: Stock
Fuel Consumption: About 125cc's for a 7 minute run.
I fly at an elevation of 250 feet above sea level, in a mostly dry climate.
I've done a lot of experimenting with this setup, and I can get a 4-2 break with the right tweaking, but it seems easier to set to run the wet 2 stroke. When I get the 4/2, it does it very well with the right power when you want it. When running the wet 2 stoke, the 4/2 break never seems far away.
Brian
AMA 55421
Madera, CA
adam collver
Can you run the 46 out of the box stock?
Mark Scarborough
Adam, that is pretty much the best way,, the only exception being some like a smaller venturi,,
personally,, I use a .270 venturi,, with 10% nitro,, etc etc,, see above,,
