Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
June 17, 2025, 05:18:00 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Help Enya 35V Model 5225 stops upon removal of battery
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help Enya 35V Model 5225 stops upon removal of battery (Read 1851 times)
Allen Eshleman
Trade Count:
0
Captain
on:
November 08, 2021, 02:16:35 PM »
This morning, we were trying to fly my brother Ron's newly built Shoestring Stunter that has an Enya 35V Model 5225 on it. It ran well on the stand. We are using 29% castor fuel. It started easily but upon removal of the battery, it stopped. So we changed glow plugs and had the same result with 5 different plugs, the last one being a brand new Thunderbolt long and a new Odell??? long. Same result. Almost like clock work. Remove the battery and it stopped. The tank is a 3 or 3 1/2 gravity tank. We also removed the fuel filter. Any ideas?
Logged
25 supporter
Trade Count:
0
Admiral
Re: Help Enya 35V Model 5225 stops upon removal of battery
Reply #1 on:
November 08, 2021, 02:29:13 PM »
Try some different fuel. I have had a gallon not work right in the middle of a jug, from one flight too the next. Try anything, even if the oil content is less, just for one test run and that should tell the tale.
Logged
EAA 1038824
Peter in Fairfax, VA
24 supporter
Trade Count:
0
Admiral
Reply #2 on:
November 08, 2021, 02:36:35 PM »
And the obvious: If it's too rich, it will quit when you take away the glow.
Logged
BillP
21 supporter
Trade Count:
0
Captain
Reply #3 on:
November 08, 2021, 03:53:05 PM »
Same thing happened to me...last quarter of a gallon of 29/5 all castor went from one week flying to the next week going bad. Might also want to check head and backplate screws for tightness.
Logged
Bill P.
Brad LaPointe
24 supporter
Trade Count:
0
Commander
Reply #4 on:
November 08, 2021, 04:49:18 PM »
Too much oil . Enya recommends 20% , I like 10% nitro 11 syn , 11 castor . This time of year 5% nitro works well .
Brad
Logged
Allen Eshleman
Trade Count:
0
Captain
Reply #5 on:
November 08, 2021, 05:00:59 PM »
The temperature was around 60 degrees. Could that have made 29% Castor too thick? Thinking about trying the 11/11, 5% or mixing some 11/11 with the 29. If we did that, what would be a good mix?
Logged
john e. holliday
25 supporter
Trade Count:
0
Admiral
Reply #6 on:
November 08, 2021, 07:03:01 PM »
As already stated, change fuel or my method go to a hotter plug.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
Allen Eshleman
Trade Count:
0
Captain
Reply #7 on:
November 08, 2021, 07:10:03 PM »
We were using hot plugs.
Logged
Ken Culbertson
25 supporter
Trade Count:
0
Admiral
Reply #8 on:
November 08, 2021, 07:28:34 PM »
Cold fuel? We used to heat our fuel in winter. Probably not, most likely too much oil for temperature. 60 is not cold though. How long are you leaving the battery on. Maybe letting the engine heat up some might work. I'd say "go electric!" but they quit when you take the battery off too!
Last Edit: November 08, 2021, 09:27:37 PM by Ken Culbertson
Logged
bob whitney
Trade Count:
0
Admiral
Reply #9 on:
November 08, 2021, 08:31:34 PM »
try taking a head shim out
Logged
rad racer
Dave_Trible
24 supporter
Trade Count:
0
Admiral
Reply #10 on:
November 09, 2021, 01:00:51 PM »
I prefer 28-29% oil for Fox and Red Head McCoy engines but it seems too much for the better-fit Enyas and yes the problem seems worse when it’s cool. I’d say viscosity is the culprit. My Enyas like 23% very well.
Logged
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Reply #11 on:
November 09, 2021, 01:36:20 PM »
60F should not cause any problems with the oil. If you keep the battery on does it keep running? With the battery on can you run it lean or rich as you adjust the needle? What prop, anything close to a 10x6 should work at least to get it running. Have you blown out the spraybar and wiped the needle to make sure there nothing in the fuel system? Do you have the pickup line aligned with the center of the spraybar? Last idea I have is check that the backplate bolts are tight and it is not leaking.
Let us know progress.
Best, DennisT
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
