  • August 05, 2025, 06:20:49 AM
Author Topic: Discovery retro problem  (Read 3608 times)
Offline big ron
« on: November 26, 2015, 02:54:10 PM »
I have a discovery retro 60 in an Impact with a 4 ounce clunk RC tank that I have not flown yet. My problem is that with the engine running inverted (position I started it in) when you turn the nose up engine goes lean and kills. The engine runs fine as long as plane is inverted. Tank is plumbed uniflow with the uniflow open. Running FAI fuel. Any help appreciated.
John Blanchard
Brusly, Louisiana
 AMA 1054488
Offline bob whitney
Re: Discovery retro problem
« Reply #1 on: November 26, 2015, 05:47:25 PM »
  sounds like your venturi could be too big
rad racer
« Reply #2 on: November 26, 2015, 07:31:34 PM »
Sounds like the tank needs attention, its in the wrong place, or one of the pickup or uniflow lines could be in the wrong place, or stuck, is it a hard plumbed tank or clunk?
« Last Edit: November 26, 2015, 08:58:15 PM by RandySmith »
Offline big ron
« Reply #3 on: November 26, 2015, 08:48:15 PM »
I pulled tank out everything looked right cleaned NVA put all back didn't do it on next run. Will test run some before I try to fly. Thanks
John Blanchard
Brusly, Louisiana
 AMA 1054488
Online Lauri Malila
« Reply #4 on: November 27, 2015, 04:03:34 AM »
Check that venturi & squish clearance is set correctly.
I souldn't use a clunk tank but I doubt it's that. L
Offline big ron
« Reply #5 on: November 27, 2015, 08:04:46 AM »
What should the measurements be?
John Blanchard
Brusly, Louisiana
 AMA 1054488
Online Lauri Malila
« Reply #6 on: November 27, 2015, 10:28:02 AM »
Squish 0,6mm, venturi 7,8mm.
The old Russian KC-2 plug is the best but I know that many use Enya #3.
Also, if you use synthetic oil, I recommend to test also with all-castor fuel. That is to rule out problems caused by wrong oil. L
John Leidle
« Reply #7 on: November 27, 2015, 10:36:04 AM »
  If I had that situation I'd lose the plastic tank & find a "new" metal tank.
« Reply #8 on: November 27, 2015, 05:13:58 PM »
I would take a good look at the clunk line in the tank. Maybe the clunk line is stuck where it shouldn't be. Sometimes they get stuck in the front of the tank, etc., when being transported or stored nose-down. If that's not it, I'd switch to a metal tank. Should be an easy fix. Engines really want to run, but those darned details can mess things up.  y1 Steve
Offline PerttiMe
« Reply #9 on: November 28, 2015, 01:51:27 AM »
I, too, would still suspect the clunk. Maybe getting stuck somewhere: against tank wall, around other plumbing, ???.
Eric Viglione
« Reply #10 on: November 28, 2015, 07:14:24 AM »
If all the clunk tank speculation turns out unfounded...From what I have seen, the DR don't like to hold an overly lean setting. If you are unfamiliar with this motor, it might just be you are not used to it. The one's I assisted launch on tend to be very fussy about the needle... You set it to where it feels like your launchers hands will go numb from the vibration and not a tick leaner or it will flame out. It will smooth out a little after take off, but not much. In order to do this, you need a light prop like Yuri makes with enough pitch to get the flight speed you want and get that needle setting.... The glow plug also has to be up to the task, make sure you have a fresh glow plug of whatever the manufacturer recommends. FAI fuel plus maybe 2 percent nitro seems to be about max in stock config, if I am not confusing my memory with the Stalker....sorry, it has been a while .
EricV
Offline Ken Burdick
« Reply #11 on: November 28, 2015, 09:29:50 AM »
I had a similar issue with a clunk that had a hole in the tubing that attached to the clunk!
Run the clunk outta town.
Online Lauri Malila
« Reply #12 on: November 28, 2015, 09:58:05 AM »
Normally the good needle setting before take-off is when engine oscillates between 2-and 4-stroke. How it works in air, depends on tank and tank position (sideways position). Pick-up tube inside tank, in rear right corner of tank, should be 5...10 mm outside the center of venturi when compared to fuselage centerline. But as you haven't flown yet, it cannot be the exact cause of your problem. But you can expect problems especially in upwind part of circle in strong wind and in overhead maneuvres if tank is mounted too much "outside", which is often the case when engine is mounted cylinder down in a narrow fuselage.
You still did not say what plug you use.
I found that the Thunderbolt plugs (big bore & 4-stroke) worked OK at first, but later the filament proved to be too flimsy to widthstand the high compression/vibration. L
