  • June 19, 2025, 01:15:46 AM
Author Topic: Tongue muffler Holes  (Read 1838 times)
« on: July 14, 2016, 07:48:43 PM »
Venturi size gets talked about allot but what about the exhaust. Is there a formula for how many and how big to make holes in a tongue muffler? I've got an OS max S 15 side exhaust, the one made after the steel fin and before the FP, and I need to make a light weight muffler for it.
Should I calculate on the area of the exhaust port, copy it or reduce it? Not using muffler pressure but want to cut down the noise a little without loosing power.
Re: Tongue muffler Holes
« Reply #1 on: July 14, 2016, 09:15:41 PM »
You can use 12 -  5/64th  holes, you will still hve good power, and you can tweek it by tapping 4/40  and blocking up 1 or 2, or...  opening 1 or 2 holes to a larger  size, this will depend on venturie size
