  • June 21, 2025, 01:34:03 AM
Author Topic: LA Vs FP 25's . Boost Port .  (Read 1829 times)
« on: August 13, 2023, 11:31:14 PM »
Putting replacement wrist pin pads in the LA 25 & FP 25 ( Clone - a GP 25 Magnum ! )
Is evident the LA 25 is a ' 46 ish ' device , in that its got only the TWO TRANSFER PORTS , No Boost Port - Whereas the FP clone has the boost port & passage .
So , the Question is , Is one better behaved - better ' switch ' in and out of the power up & down hill - easier to set - a class above ? ( we'd guess the LA 25 . )
Havnt run the LA 25s yet . The GP 25s in the Me 262 twin ( engined ) churned away steadilly - towed 70 ounces on 70 foot lines well , but seemed very ' un switching ' .
Is the LA set up superior ? more gutless ? is it worth LAing the FP clones by bunging the boost port  , or will it loose a lot of power ? .
The GP's run 1/4 bore intakes with 4 m.m. spray bars . Just for the record . And its for aerobatics Not Racing . Thanks .
