  • June 20, 2025, 06:54:53 PM
Author Topic: Fox 35 Loose Needle Valve?  (Read 1654 times)
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
« on: February 26, 2007, 06:12:44 PM »
Hi all,
While flying my Nobler today I noticed that my Fox 35 (50th Ann. edition) needle valve has a bit of side to side free play. Is this normal? The little stopper thingy stops it from turning, but I'm guessing it could vibrate from side to side affecting the tune of the engine.
See pic attached.  Also attached is a pic of my new Stooge that I made on Sunday.
Cheers
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Online James Lee
Re: Fox 35 Loose Needle Valve?
« Reply #1 on: February 26, 2007, 06:16:40 PM »
Warren
That side to side motion is not uncommon with the usual Fox QC....   It does tend to make an air leak which is not good....  Typically a piece of silicone fuel line over the needle just slightly longer than the distance between the wheel on the needle and the nva body will make a decent air seal.  Maybe not great but it will work.   ;D
FWIW
Jim
Online Paul Taylor
« Reply #2 on: February 26, 2007, 06:23:21 PM »
I think most replace the Fox NVA with a ST type.
I like the stooge and the plane, but I really like the green grass. Still winter here and all the grass is brown. :-\
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: February 26, 2007, 06:23:42 PM »
As Jim said, not unusual at all, even have fuel tubing on the OS needle in my Saito 40 with UHP manafold.
Offline Jim Thomerson
« Reply #4 on: February 26, 2007, 06:44:48 PM »
I put one of my 1970's Fox stunt 35's back together with the plan of using it in an OTS airplane.  I ran it on the bench with a Fox NVA.  It now has an ST NVA.
Offline Marvin Denny
« Reply #5 on: February 26, 2007, 08:21:48 PM »
  I took some of my stunt 35 needles to a plating establishment, and had him plate about 0.003 inch per side of silver on them and it cured all the side to side play.
  Marvin Denny
marvin Denny  AMA  499
Offline Shawn Kuntz
  • Ringmasters Forever!
« Reply #6 on: February 27, 2007, 07:55:35 AM »
ST Needle Valve Assembly?  Is this Super Tigre?  Where do I get one?
Shawn Kuntz
Bismarck, North Dakota USA
« Reply #7 on: February 27, 2007, 08:04:31 AM »
I have always found the "little chunk of fuel tubing" to be a great help with the Fox 35 Needles.
Less than a 1/4" piece on the needle and thread it in.  Seals the assembly real nicely!
Bill <><
  • AUS-14782
    • My Home Page
« Reply #8 on: February 27, 2007, 08:16:08 AM »
Shaun,
You can get genuine ST NVAs on eBay from time to time for around $20 but you can also get after market ones from Leonard Neumann at http://www.clstunt.com/products.htm for about $12
Bill,
I have already put a small piece of tube (about 1/4" long) seems to work fine. Much more consistent running now. I think I may have also had a pin hole in my home made tank. Fixed now.. will see how it goes tomorrow, weather permitting...
Cheers
Warren Leadbeatter
AUS-14782
Offline L0U CRANE
« Reply #9 on: February 27, 2007, 01:12:06 PM »
Warren,
The piece of fuel tubing seals between the inner knob and the spraybar, of course. It also puts some tension on the threads IN the NVA, which aids seal and somewhat further snubs vibration.
Aside to Jim Thomerson: I find the ST spraybars a bit large diameter for my liking. OS and ENYA CL NVAs are available, and both are between the ST and the Fox spraybar diameter.
...Ah, but then, at my home altitude of ~5000', I need a bit more airflow over the spraybar, don't I?
\BEST\LOU
« Reply #10 on: February 27, 2007, 02:10:28 PM »
Shaun,
Bill,
Cheers
HI
You can also get ST  NVA  from Aero Products,  and  the better  PA  NVAs   the Stainless steel ones that are made to fit the FOX 35  require  NO  grinding, sealing , washers or  filing  the sides  flat.  just bolt them in and  they work
« Reply #11 on: February 28, 2007, 10:58:33 AM »
I have several PA NVA for the Fox 35.  The spray bar looks just like the Fox one, except it is stainless steel.  It has a collet to lock the needle "similar" to the ST style, but this one has a *nylon* (???) insert that seals the needle completely.  It also means that the collet only needs to be finger tight.
This NVA is definitelty the best of both worlds with out a doubt.
Bill <><
Offline Terry Bolin
  • Havin' the time of our lives!
« Reply #12 on: February 28, 2007, 12:12:16 PM »
I was running a NEW Fox 35 on the test stand last night to break it in and not have to clean a airplane up afterwards. During the first run I noticed the engine RPM Was inconsistent but then I realized that I forgot to install the short Silicone piece on the needle valve. I have done this since the 70's and it really works well plus, helps hold your adjustment. That fixed me right up last night. Try that before you spend the money for a ST NVA.
Good Luck!
Terry B.
Offline Tom Perry
« Reply #13 on: February 28, 2007, 05:09:05 PM »
Has anyone else tried the teflon tape sold for plumbing to solve this problem?  Streched very tight it effectively seals any air leaks and keeps any side to side play to a minimum.
 H^^
Tight lines,
Tom Perry
 Norfolk, Virginia
