Hi
You can wear any engines out quickly, and there is a huge difference from hooking up a drum of fuel and running an engine, and flying an engine where you
1- do not have control over the needle
2- launching from the ground and sucking up dirt sand debris etc
there are more but this is the 2 main things, you can suck up sand and ruin an engine in 1 flight, or over dozens, You can also get a lean run and toast a rod or piston sleeve fit
AS Far as the Nickle plated OS 46 LA and others you can wear them out, I have seen 100s worn out and many many dozens with peeled plating, With that being said most Control line guys treat them better, and you CAN get good life out of an LA 46 or other engines by running good fuel, setting the needle correctly, and very important, keeping sand and dirt out of the engines, an Typical OS LA will run about 500 flights before the piston wears thru to the brass if taken care of,
and really that is a long life , any longer I would tear it down for inspection and at least replace the wrist pin
They are an excellent VALUE for what your paying for
