  • June 27, 2025, 04:33:59 AM
Author Topic: blank  (Read 2595 times)
blank
« on: November 01, 2018, 08:14:32 PM »
blank
« Last Edit: September 12, 2021, 09:06:27 AM by Motorman »
Offline dennis lipsett
Re: LA 46 Wear
« Reply #1 on: November 01, 2018, 08:30:36 PM »
I ran one reasonably hard for over 6 year with no appreciable wear. Compression was excellent when I passed it on to another friend to use. Treat them with the care they deserve keep it clean and decent fuel and they will last long enough to make you better than you were  when you started.
Offline Dane Martin
  • heli pilot BHOR
Re: LA 46 Wear
« Reply #2 on: November 01, 2018, 09:10:31 PM »
My first "big" engine was an LA 40. Yeah, I'm not very old. Lol. They came out when I got into rc on my first trainer.  Anyway, it's survived 3 planes and is currently on my TEOSAWKI. Mostly for nostalgia. It had one when I got it. Just wanted to see if I'll ever wear out mine.
Re: LA 46 Wear
« Reply #3 on: November 01, 2018, 10:01:28 PM »
How many gallons of fuel or how many full pattern flights would you go through before your stock LA 46 is worn out? I'm building a couple of planes now that I'm going to fly the wings off of next spring and I'm wondering if I should get more piston/sleeves.
       I have no specific information, but I have never found wear to be a serious issue on OS ABN engines without very extensive use. I wore out *one* 40VF in the entire time I ran it, and even then, I finished 8th at the NATs with it on one of its last flights - it had to be peaked out lean, that is, as fast as it would go, to get the proper launch RPM. That was after at least several thousand flights. Paul Walker had a similar story.
    Having spares never hurts anything, but I wouldn't worry about it, myself. Use an air filter, don't run it in a gravel pit, and you will probably get tired of flying it before it gets tired of you.
Offline Brad LaPointe
Re: LA 46 Wear
« Reply #4 on: November 02, 2018, 09:33:11 AM »
LA .25s on the other hand wear out liners very often . I have several with just the brass showing on the bottom portion of the liner . Combat and sport race are a lot more demanding than stunt .
The toughest 25 I’ve found is the Thunder Tiger. The TT .40 is probably longer lasting than a LA but for stunt you might find the LA is tough enough.
Brad
Re: LA 46 Wear
« Reply #5 on: November 02, 2018, 11:28:06 AM »
I can't speak in general, but I campaigned for about 3 solid years with a Twister with a 46LA.  I put between four and six flights a week on that for those three years -- so 600-900 flights (OMG!).  The engine ran just fine when I hung it up; I think I could pull it off the wall and fly it again and it'd be just fine once the dried-up castor oil worked it's way out of the needle valve.
Note that this is with nylon mesh over the intake, and a fuel filter.
Re: LA 46 Wear
« Reply #6 on: November 02, 2018, 11:49:03 AM »
Brad
Brad, I had an LA 25 with a worn out liner with brass showing around the bottom.  I got a brand new piston and liner that worked fine for a long time(for combat) that had a similar patch of brass showing at the bottom of the liner.
I think if the brass showing is limited and below the ports it doesn't make any difference.  Us combat flyers do more damage by crashing than any other way.
Offline Larry Renger
Re: LA 46 Wear
« Reply #7 on: November 05, 2018, 01:18:23 PM »
Duke fox ran 55 gallons of fuel through a stunt 35, and gave up at that point since it still started and ran just fine.
Cox did a similar test and ran a Tee Dee 049 for 400 hours.
In a clean environment with good lube, you will pretty much never wear out an engine.
Re: LA 46 Wear
« Reply #8 on: November 05, 2018, 01:51:24 PM »
Any engine?  Even one of these?
Re: LA 46 Wear
« Reply #9 on: November 05, 2018, 02:11:34 PM »
   You certainly can wear out engines in realistic conditions. But it takes *a long time* if you don't do something to speed it along.
Re: LA 46 Wear
« Reply #10 on: November 05, 2018, 02:48:47 PM »
Hi
You can wear  any engines  out  quickly, and there is  a  huge difference  from hooking up a drum of fuel and running an engine, and  flying an engine where you
1- do not  have control over the  needle
2- launching from the ground and sucking up dirt sand  debris etc
there are more but this is the  2 main things, you can suck up sand and  ruin an engine in 1 flight, or over dozens, You can also get a lean run and  toast a rod  or  piston sleeve fit
AS Far  as the  Nickle plated  OS 46 LA and others  you can  wear them out, I have seen 100s worn out  and  many many dozens  with peeled plating,  With that being  said  most Control line guys treat them better, and  you CAN  get good life out of an LA 46 or other engines  by running  good fuel, setting the needle correctly, and very important, keeping sand and dirt out of the  engines, an Typical OS LA  will  run about 500 flights before the piston wears thru to the  brass  if  taken care of,
and  really that is a long life , any longer  I would tear it down for inspection and at least replace  the  wrist pin
They are an excellent  VALUE  for what your  paying for
Re: LA 46 Wear
« Reply #11 on: November 05, 2018, 09:10:55 PM »
    In a discussion like this one, you need to define the difference between "wearing out" and "abuse." Some would never wear out an engine because they never really get used. Some can just look at an engine and cause problems!
Re: LA 46 Wear
« Reply #12 on: November 05, 2018, 10:55:35 PM »
It is sorta a new thing that people are using air filters and  taking better care of their motors, and  I still see  the VAST majority of pilots NOT using them, I also see  lots of improper fuel being used.  So the main problem is  abuse is a normal thing for  many pilots, and  they do not really think that they are abusing them, just flying like they always have. There is  really no surface  you can fly on that  does not have  sand  dirt debris, that can do damage. The air filters  are  good, but  really are not that effective, best case  is to double up and use something like a Bru-Line filter, with a piece of  panty hose  underneaath it.
Then there is  fuel.  I have personally seen over my years many dozens of engines like  FOXES   McCoys   OS  S engine  ruined  very quickly by using  RC Sport fuels  with  12 to 15%  total oil content,  these can wipe out a  rod in 1 run on some motors.    The pilots  did not know this, as many  were told that  these were the best fuels  out there !
