  • July 23, 2025, 10:12:07 AM
Author Topic: La 46 vs ST G51.  (Read 1894 times)
Online John Rist
La 46 vs ST G51.
« on: October 13, 2014, 09:59:54 PM »
Is the LA 46 a good replacement for the ST G51?  Not worried about bolt pattern    Just performance.
Re: La 46 vs ST G51.
« Reply #1 on: October 13, 2014, 10:12:38 PM »
Not even close.  They're completely different engines.  The G51 will fly most .60 size planes, while the LA 46 is more of a .40 on steroids.
Offline Martin Quartim
    • StuntHobby
« Reply #2 on: October 17, 2014, 10:58:17 PM »
The  Enya SS50 is the best ST G51 UPGRADE!. It has the same size and same engine mounting holes of ST G51. However the Enya SS50 is a lot lighter then STG51 and lot stronger!
You can use a cheap APC 12.25x3.75 or APC 13x4.
I have tested this engine with no pipe with 12.5x3.75 3 blade CF prop and it performed amazingly well stock.
Martin
« Reply #3 on: October 20, 2014, 07:49:56 PM »
The Supertigres a detuned 1.6 horse 2 16000 rpm  wadio injun . The OS isnt .
The K&B 40 mounts similar . The COMO 51's the same - bar 1/8 shorter nose .
these come up s/h regularly from the radio types . Though youve got to have the
Early plug in head ringed one . p.d.p. baffled . 40s same . were a few ABC baffled .
if the writing & head arnt identical , its the wong won . ABC stamped on side of lug , for abc ones . much like a late ST V60 ( lite ) K .
this one went for 16 bucks , on ebay .
51 for a staggering $ 52 , n.i.b. .
intakes as per 60 lite & G-51 . DONT get the ' S ' on the bypass unless you want a schneurle .
http://www.ebay.com/sch/i.html?_from=R40|R40|R40&_sacat=0&_nkw=como+engine&LH_Complete=1&rt=nc
completed listings , for price comparison .
« Reply #4 on: October 20, 2014, 08:00:13 PM »
http://sceptreflight.net/Model%20Engine%20Tests/Como%2040.html
Brickhaus ran a 40 in a Miss Dara profile ( Flying Models ) with a .16 sprinkler venturie it sais , & I think a 11 1/2 ex. 12 x 5 .
there both 40 & 51 identical bolt pattern to the G 51 / G 40 / G 45  etc .
