  • June 17, 2025, 03:26:46 PM
Author Topic: O S L A 40  (Read 892 times)
Offline Bootlegger
O S L A 40
« on: July 17, 2018, 07:31:13 AM »
 I know that this horse has been beat to death, but when I try the search, I get a lot of other info, so I'm gonna ask again, please bear with me..
  I have an OS LA 40 engine as for as I know it is stock, with a .257 venture, one stock head shim T/Bolt idle bar plug, turning an A P C 11x4 prop, 5-10% n 22% oil, and on the bench it runs well. It turns in the 9500-10,000 R P M range, so I am asking how you have yours set up, and THANKS a One other thing I forgot it has a R Smith P A 40 Needle assy in it also...lot.
« Last Edit: July 18, 2018, 08:16:46 AM by Bootlegger »
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bootlegger
Re: O S L A 40
« Reply #1 on: July 17, 2018, 07:35:50 AM »
Gil Causey
AMA# 6964
