Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
June 22, 2025, 02:39:04 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
la 46
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: la 46 (Read 1106 times)
charles west
Trade Count:
0
New Pilot
la 46
on:
May 31, 2008, 01:33:57 PM »
I want to install the needle valve on the venturie,what do I need to do? Thanx ,Charlie
Logged
RandySmith
Administrator
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Re: la 46
Reply #1 on:
May 31, 2008, 01:54:00 PM »
Quote from: charles west on May 31, 2008, 01:33:57 PM
hi Charlie
You will need to make a venturie that is a bit thicker, mill the sides flat above the case and drill for a NVA that fits the span. This is the way Super Tiger does the ones on the ST 51 and ST 34. I do not care for it at all, especially on a built up ship.
Or you can turn down a ST 34 venturie to fit into teh OS
Logged
don Burke
2014 Supporters
Trade Count:
0
Admiral
Re: la 46
Reply #2 on:
May 31, 2008, 03:06:06 PM »
If it is an LAS all you need is a needle assy. The OS one works.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCR49&P=ML
If you want to use a Super Tiger type needle you'll have to drill the hole out as the OS stock diameter is .136, ST being 4mm (approx. .155). This will also take some cross-section away from the OS venturi.
If it is an R/C conversion you will also need a venturi, Tower has those also. Or if you need a smaller diameter than OS supplies you'll need to sleeve it down, make one, or get one from one of the specialty suppliers.
Logged
don Burke AMA 843
Menifee, CA
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
la 46
