  • July 07, 2025, 08:16:37 AM
Author Topic: LA .40 rpm  (Read 873 times)
Dwayne
LA .40 rpm
« on: April 06, 2008, 04:33:40 PM »
Hi all
I know this has probably been asked a zillion times but what is the take off rpm for a th LA .40, I'll be using an 11/5 prop.
Offline Joe Messinger
Re: LA .40 rpm
« Reply #1 on: April 06, 2008, 09:46:08 PM »
 I don't rely on a tachometer too often to tune (mixture) my engines.  I usually try to adjust the needle to where I think the exhaust note -sounds -about right.  Fly the plane and make more adjustments if necessary.  After awhile, you can recognize the exhaust sound that produces the best engine run.
That being said, I have checked rpms and on the LA.40 engines I have, 10,000 rpms + or - a few seems about right.  I use APC 10.5X4.5 props on most of the .40s.
I'm sure others have differant methods that work for them.
Joe
Joe Messinger
Offline Alan Buck
Re: LA .40 rpm
« Reply #2 on: April 07, 2008, 06:54:00 AM »
I launch my la40 at 8800 to 9000 with 11/5 zinger on a cardinal 5% nitro . 62ft lines 46oz in weight and a tongue muffler
ALAN E BUCK
Re: LA .40 rpm
« Reply #3 on: April 07, 2008, 08:39:49 AM »
Dwayne,
It makes some difference whether this is a profile or built up airframe. profiles tend IMHO to pick up more rpm as you launch as a result of the head pressure in the tank changing, because the pickup tube is farther outside the needle valve than on a built up.  That said, My LAs launch on my profiles at about 9800 with a 3.75 pitch prop and a .282 venturi, Note however this is a .46
